Question about Music
My key broke off the organ how do I order an F key?
Need an f key my key broke off need new key to repair it
    Top Expert:
  • Music Master
  • 3,107 Answers
Contact the manufacturer directly and speak with customer service.
Posted on Apr 07, 2015
Why lower keys dont come on , on a kimball model 700-775
I think you are speaking of an organ.
Your organ has electronics inside it, and I believe the circuit board for the lower keys has a broken connection.
You should find an electronic organ repair place.
I just looked online and found several places.
Since you may be near to none of these, relay on your computer to find someone who can repair this circuit board.
They will have to tell you how to take it out of your unit.
God bless your efforts.
Feb 24, 2017 | Music
I believe organ hasn't been played or even turned on in over 10 years. The top keyboard plays if I turn on a setting such as piano or trumpet however I can't just get the organ keys to play.
Since the organ has not been used for a long time, I suspect that there can be degradation of the electronics, specially with electrolytic capacitors. hence I request you to switch on the Organ continuously and allow it to warm up, it there is improvement , then it will be worth to remove the bottom panel and clean up the boards,dry the PCB with a hair dryer and reconnect the boards.
Hope this will help.
Jan 23, 2016 | Music
When I turn organ on, the power light comes on but no sound from any key. can it be repaired?
Without the organ in front of me, I really can't say for sure, but most any problem can be fixed. Really you need to have a repairman look at it in person to get a realistic estemate to determine if it's prudent to repair it.
Dec 16, 2015 | Music
QS8 keyboard. Why is volume in organ mode much louder than piano mode when I switch between modes without touching volume slide?
On organ mode, in general, almost all brands of the modern keyboard, velocity setting is not enabled. Setting velocity is used to determine how much the level of the sound that follows how strongly you press the keys. It is really just to imitate the sound of vintage organs, which in the past, electronic organ technologi not use the velocity on the keys. So, how strong / slow we press the keys, the sound level will remain the same.
At the Piano mode,modern keyboard using setting velocity. This also to imitate an acoustic piano, which, if we press the keys slowly, the sound level will be slow as well, and vice versa.
So, in your case,at the same volume slider, try to play on the organ modes, note level. Moving to the piano mode and press the keys securely powered (full power). Then the sound level should be equal to the organ mode.
On modern keyboards, also included organ sound that added velocity setting. Usually found on the user bank.
Sep 01, 2015 | Alesis Music
Alesis QS8 keyboard. The volume of the organ is much louder than the keyboard when I switch between both modes without touching the volume slide. How can I fix this.
How to replace broken Organ keys
It varies from one manufacturer to the other, and even from model to model from the same company. No matter what, it will require removing part of the organ's cabinet to get to the screws holding the plastic key to the metal key finger. If you are unfamiliar with the procedure, I would suggest hiring an organ repair man. It's too easy to cause more problems doing it yourself.
Feb 05, 2015 | Music
Have an older Lowrey organ with loud hum.
Of course it is repairable.
Find a competent repair person. You did not describe the "noise". If it is 60 cycle hum, the filter caps need replacing. If it is an organ tone, then probably a key contact is stuck.
May 05, 2010 | Music
Need owner's manual for Baldwin Cinema II organ
I have the original technical data for it, as if you wanted to build one yourself from scratch, but no owners manual. Did you ever find an owner's manual? Also, I have the organ itself.
Oct 07, 2009 | Music
Music Logo
16 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
