Question about Oregon Jonsered 13" Chain Saw Repl. Chain Model 2050, 2050 Turbo, 2051, 2054, 2055, 2149, 2149 Turbo, 370, 410, 420, 425, 435, 45, 450, 451, 455, 49, 50, 51, 510, 52, 521, 525, 535, CS2145, CS2149, TURBO, CS2150, CS2152 W, CS2153, CS2156, CS2159, CS2159C
How to adjust the bar & chain oiler on 49SP Jonsered chainsaw?
Is there a oil ajustment for the bar oiler on a homelite chain saw
Homelite XL auto oiler - YouTube
? 2:44
https://www.youtube.com/watch?v=PnNTJ3xI_wo
Mar 24, 2012 - Uploaded by 343HFD
Refurbished, carb cleaned/adjusted, new filter, fixed automaticoiler. Anyone know the nut size for the bar ...
HOW TO REPAIR CHAINSAW OILER - YouTube
? 6:38
https://www.youtube.com/watch?v=kmUkieIP-vw
Jan 20, 2012 - Uploaded by gregthegardener
lf your chain saw isn't lubing the chain it can cause serious chain ... How to Replace the Bar & Chain Oil ...
Dec 03, 2015 | Homelite Garden
Can the chain oiler be adjusted on a 141?
No adjustment possible.
But that can be good news when you got good oil as you can run a longer bar and chain up to 20" The shorter the bar the more oil present on the chain and bar during operation
Jan 08, 2015 | Husqvarna 36 41 50 51 55 136 141 154 254...
Hi,i,m prtty sure the oiler for jonsered chainsaw has conked out
remove the chain and bar look twords the oiler and clean out that oiler port it works on gravitation thats all
Apr 24, 2010 | Hammering
How to adjust chain and bar oiler flow on a jonsered 49 sp chainsaw
The chain should be adjusted so that the chain can be pulled by hand fairly easily, but doesn't droop from the bar underneath. Oil flow should be set so that a running engine (chain moving fairly fast) will send a thin line of oil off of the tip of the bar (onto a piece of cardboard) with a few moments of running. Hope this helps!
Feb 27, 2010 | Garden
Jonsered cs 2250 fixed flow oiler can the oiling rate be increased i think its not getting enough as the chain is running almost dry
Remove the housing that covers that bar and sprocket. There are two plates on each side of the bar that set over the studs.They may be identical or slightly different depending on the saw but at least one of them will have a hole in it for the oiler. If you remove the bar and both plates you will see the oiler hole on the saw housing. This oiler injects oil through the plate and into a small hole in the bar where the chain picks it up and carries it around the saw. If this hole becomes plugged with sawdust it will keep your saw from oiling the bar proplerly. This hole should be cleaned out periodically. It's not a bad idea to remove the whole chain periodically and clean the chain guide all the way around the bar and get any sawdust buildup out so the oil can flow better.
Dec 03, 2009 | Garden
Husqvarna chainsaw 440e - enough chain lube?
That seems low to me. Page 15 in your manual is the only oil discussion I found. Usually there is an oil pump adjustment reference somewhere. I didn't see one beyond return it for service on page 15. Are the chain and bar hot after cutting a while? I recommend you not get a longer bar without an oiler adjustment. I think the hand of the EPA has been here.
An IPL (exploded parts list) for a 440 can be found here:
http://weborder.husqvarna.com/order_static/doc/USA/2009/I09000/I0901018.pdf
There is no oiler adjuster listed. HTH
Lou
Might be a good idea to copy the IPL,
Oct 07, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
How to adjust chain bar oiler
The Stihl 026 PRO does have an adjustable oiler and it is located on the bottom of the saw just below the clutch drum.
Stihl also builds an 026 "Standard" without the adjustable oiler, however, the hole location for adjustment is still there.
The 026 PRO will also have a decompression valve on top of the saw to make the rope easier to pull during startup. If you have the DECO valve you should also have the adjustable oiler. Hope this helps.
Sep 26, 2009 | Standard Oregon Chainsaw Chain For Stihl...
Chainsaw chain oiler not working
There is probably a filter on the bottom of a hose within the oil tank. Go through the tank fill cap with a blunted rod. Move it slowly you should find the hose. Draw it gently toward the opening. You can probably find a new filter at a Husqvarna (parent company) dealer if you don't have a Jonsered dealer handy. Oil pump replacement is complicated. Any good chainsaw mechanic can replace it regardless of what saw they sell. Arboristsite dot com is a buch of chainsaw nuts (Eye r 1). They will give you better guidance. Please do a searh in the chainsaw forum before asking "how do I fix my saw", the answer has almost certainly been asked. Spike60 is a Jonsered dealer and is always helpful. HTH Lou
Sep 01, 2009 | Garden
Chain oiler
Depends on the vintage, turn the saw upside down and you can see a screw to turn, 3 settings, right under the clutch and shaft. use a screw driver if it is adjustable. I like to keep mine set on high, oil is cheaper that new chains and bars. Use a bar oil, not old used motor oil.
Nov 01, 2008 | Husqvarna Chain Saw 20" Bar
Oregon Jonsered 13" Chain Saw Repl. Chain Model 2050, 2050 Turbo, 2051, 2054, 2055, 2149, 2149 Turbo, 370, 410, 420, 425, 435, 45, 450, 451, 455, 49, 50, 51, 510, 52, 521, 525, 535, CS2145, CS2149, TURBO, CS2150, CS2152 W, CS2153, CS2156, CS2159, CS2159C Logo
185 people viewed this question
Top Oregon Garden Experts
John Loiselle
Level 1 Expert
ray gallant
Tony Jazdziejewski
Level 1 Expert
Are you an Oregon Garden Expert? Answer questions, earn points and help others
