Question about RCA P52939 52" Rear Projection Television
Pincushin effect when converging
I can converge in the center portion of the screen. But outer portions top, bottom, left and right form a pincushin. The curvature doesn't allow for convergence even though I can move the three colors. Please help
  • 1 more comment
  • Anonymous Dec 03, 2007
    Picture is warped, in the center vertically it is smaller or concaved and on the ends it's larger like a sidewise hour glass. Like when on a computer, screen pincushion affect. Can this be fixed by adjusting a resistor or like adjusting a computer screen.
  • earl mccain Dec 28, 2008
    My problem is simular, except top & botton is ok,but both left & right bows in exactlly the same amount about 6" Any suggestions? Thanks ,rioconcho
  • Anonymous Jan 08, 2009
    do you have wiring diagram for the p52939?
    President:
  • 4,402 Answers
But there are two
quick things you might be able to do. If it is a PTK195 you can most
likely install the updated power supply board. If you can solder and
know safety (like discharging caps) you can update the PS chip from an
STK730-??? to an STK730-180 (IIRC). I found that simply replacing the
chip with an equivalent fails most of the time. The 180s seem to hold
up.
Posted on Dec 19, 2007
Mitsubishi WS-55605 TV has covergence problems
advanced settings and click on convergence then you need to muve manualy there soud be a big cross to ajust wit your remote contro u have to muve it with the arrows up and down or right to left good luck
Nov 05, 2009 | Mitsubishi WS-55805 55" Rear Projection...
Projection HDTV Pansonic 47" Curving blue and green colors on top and bottom of screen.
You will need to replace your two convergence I.C.s.They are two large IC mounted on a large aluminum heat sink.Replace both,look for any burned resistors near them,replace those if needed,and readjust your convergence. Good Luck
Let me know if you need any further help
Mar 29, 2008 | Panasonic PT-47WX42 47" Rear Projection...
Convergence will not align The white grid lines used to align the red and blue is broken and wavey at the top left and lower portion of the screen
The convergence it dead,U know how to solder right?Buy the convergence kit,use what in that kit.Tries these websites.Tv Repair World.com,Ebay.com.
Oct 03, 2009 | Hitachi 57F500 57" Rear Projection...
Sony rear projection kp-51ws510. color alignment
sounds like bad convergence IC---not uncommon on this set-both convergence IC"s need to be replaced and the set adjusted
Aug 07, 2009 | Televison & Video
JVC AV56-WP74 Convergence problem
Hello saduchan,
I think that your ICs are ok, What you need to perform is what is called dynamic convergence, This involves using the internal convergence controls to align the outer edges of the screen. I am assuming that the center of the screen is ok? it's just the edges which are misaligned, right? Now for the bad news, this task is not easy in fact the job takes a pro about 6 to 12 hours to do it right. I think you should have a qualified TV technician attempt the static convergence setup followed by the dynamic convergence setup.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Dec 29, 2008 | JVC AV-56WP74 56" Rear Projection...
51MP392H/17 Blue convergence wont move not IC chip
You could have some opened resistors low ohms that are bad go back and ck them around convergence ics.
Nov 20, 2008 | Akai PT4298HD Rear Projection Television
The tv you sold me
pin cushion is gone.
time to get a new one.
don't try to fix it. not worth the time of the money.
Sep 24, 2008 | Mitsubishi WS-55859 55" Rear Projection...
RCA P52939 52" Rear Projection Television Logo
78 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
