Question about Home
HAND SANITIZER, THE SHARPER IMAGE - I PUT THE 3 AA BATTERIES AND THE LCD IS ON, BUT THE MOTION SENSOR NOT WORKING
2 Suggested Answers
  • 1212 Answers
SOURCE: i have a sharper image s1212 no hands deluxe can opener, ive replaced the batteries and it still doesnt work...any ideas on how to fix it? thanks!
Is the optical sensor clean? Try rolling the batteries in place, this should wear through any oxide layer that may have formed.
Posted on Feb 03, 2012
I don't know how to play videos on my dr. Tech hddv5520 camcorder
use the video cord that came with it,or buy one,
This digital camcorder has a flip-out LCD screen that swivels for front and back viewing. A five megapixel lens records at 30 frames per seconds for high-resolution fun. Includes 2GB Micro SD card.
  • Color options: Red
  • High-resolution, full-motion VGA quality
  • Records at 30 fps
  • 5MP CMOS sensor for extra-sharp images
  • LCD 2.4-inch TFT LCD monitor
  • Display swivels 270 degrees with front and back rotation
  • Omni vision 5-megapixel CMOS sensor
  • Zoom: 8x digital zoom
  • Power on the go with two AA-size batteries (or rechargeable AAA battery)
  • System requirements: Windows XP/Vista, Mac OS 10.x or above
  • Dimensions: 4.25 inches deep x 1.25 inches wide x 2.25 inches high
Package includes:
  • HDDV5520 5MP 2.4 inch LCD Digital Camcorder
  • Two (2) AA alkaline batteries
  • 2GB SD card
  • Video and USB cable
  • Camera pouch
  • Wrist strap
  • Quick start guide
  • CD, user manual, software and drivers
Jun 30, 2015 | Video Cameras
6 AA Batteries generate how many amps
If this is a battery powered CD player,
we are talking mA not amps.....6 x 1.5volt batteries give you 9 volts
I would recommend something like this:-
http://www.ebay.co.uk/itm/New-AC-DC-Universal-Travel-Adapter-Input-110-220-Volt-7-Output-500mA-/251316939793?_trksid=p2054897.l4275 This will have more than enough power for the CD Player.
Feb 06, 2013 | Sharper Image Audio Players & Recorders
I have a sharper image s1212 no hands deluxe can opener, ive replaced the batteries and it still doesnt work...any ideas on how to fix it? thanks!
Feb 01, 2012 | Sharper Image Air Purifiers
Megabrite model mb-dlm-82. It sometimes work and then not. The batteries are good and turns on with on-off switch. Is there an owner's manual? I think I've done everything correctly. Had...
From MegaBrite Lighting website:
http://www.amerasiaenterprises.com/P_faq.htm#p1
Why does my light keep flashing on and off when nobody is around?
There can be a number of reasons why this problem occurs.
A) It's possible that the battery life is too low after some time of usage. Please replace all 3 batteries with new ones.
B) Your product needs resetting (very similar compared to rebooting up your computer). Please follow directions below:
  1. Rotate the motion sensor white ball facing at a 45 degree angle downward.
  1. Use at least 3 pieces of black tape and place it over the photo sensor completely to simulate darkness. The photo sensor looks like a small circle located on the top right hand side of the 8 or 10 LED's.
  1. Turn the Light ON and then OFF. Please repeat this process 3 times.
  1. Then switch it to AUTO.
  1. Place the Light against the wall on the floor. Make sure the Light is facing upward leaning against the wall. The LED's should be facing towards you.
  1. Step back at least 25 feet away from the Light. Do not move otherwise the Light will turn on. Wait until the Light starts to dim down and turn off (approximately 20 seconds).
  1. When the Light turns off, wait for approximately 4 seconds and then approach the Light waving your legs and arms. The motion sensor should be able to detect your movement and then the Light should turn on.
You have just completed the resetting process. Now you may return the Light back to where it was installed. Be sure to leave the switch at AUTO and remove the black tape.
Jun 27, 2011 | Costco Megabrite Wireless Motion Sensor...
I have a Sharper Image No-Hands deluxe auto can opener model # SI212 I no longer have the manual and need to change the batteries.
http://www.onetouchproducts.com/pdf/CanManual.pdf
This is really simple. Put your finger in the middle of the bottom (flat side) and slide the WHOLE bottom towards you. I had a problem figuring it out too because it seemed like they were indicating you only slide the one little section back. Good luck.
May 25, 2011 | Sharper Image Kitchen Appliances - Others
What is it features ?
MPN Capture 1300 Key Features Resolution 1.3 Megapixel LCD Screen Size 1.5 in. Digital Zoom 2x Lens Interchangeable Lens Not Interchangeable Lenses Focus Type Fixed Focus Image Quality Image Sensor Type CMOS Camera Resolution 1.3 Megapixel Image Resolutions 640 x 480 • 320 x 240 • 176 x 144 Exposure Control Aperture Range f3 (w) Storage Memory Type CompactFlash Card Type I Built-in Memory Size 8 MB Compression Modes Fine • SuperFine • Normal Compression Type JPEG Flash Flash Type Built-In Flash Functions Flash Off • Auto Flash • Fill-in Flash Viewfinder / Display Viewfinder Optical LCD Screen With LCD Screen LCD Protected Position Without LCD Protected Position Interfaces Interface Type USB Power Supply Battery Type 4 x AA Batteries Included Features Built-in MP3 Player Unknown Built-in Microphone Without Built-in Microphone Built-in Speaker Without Built-in Speaker Tripod Mount With Tripod Mount System Requirements Operating System Microsoft Windows 2000 • Microsoft Windows 98 • Microsoft Windows ME • Microsoft Windows NT • Microsoft Windows XP Warranty Warranty 1 Year Miscellaneous Included Accessories 4 x AA Batteries • Software • USB Cable • Hand Strap UPC 647499779101
Mar 22, 2011 | Veo Capture 1300 Digital Camera
My sensor no longer works. It use to turn on the porch light when someone entered the carporch. How do I open the sensor so that I can put new batteries in it? I know that it uses AAA batteries.
Manual for this sensor is not available.
In the Zenith I have installed The motion sensor battery slot was h at the back side of the sensor, you had to remove the sensor from the wall sliding it on one side to access the battery. It mounted two AA batteries, not AAA.
Aug 17, 2010 | Heath Zenith 270 Degree Replacement Motion...
Seth thomas autoset wall clock not functioning. replaced both sets of batteries (AA and CR2032), still not working.
I wish I had a solution... I'm in the exact same situation. I put in new batteries, and all I get is a faint reading of gibberish from the LCD screen, and that's it. I've tried following the instructions, but I can't set the time in the LCD clock, since it's unreadable, and almost completely gone. Seththomas.com has a web page indicating that "they will be back with info", but no support or FAQ pages. Disappointing... I have three of these clocks, and they are all behaving the same way.
Apr 10, 2010 | Seth Thomas Radio-Controlled Howard Wall...
Looking for manual or DC adapter
I have may an adapter as my unit recently stopped working. However, you mention a reset button and I see no such button. I would like to try that first before giving up.
Dec 09, 2008 | Audio Players & Recorders
Sharper Image Beetle projection alarm clock/radio-need ac adap.
You can just buy a regular AC adapter in any store, just ask for a universal AC adapter to make sure it will fit. (you can try Radio Shack, Walmart etc.)
In a universal AC adapter there are multiple plugs and there's switch to set the volts, just find the right plug that fit you Alarm Clock and make sure you set it to 6V and that's it.
Hope it helps
Daniel
Nov 18, 2008 | Sharper Image GT113 Clock Radio
Home Logo
448 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
