Printer shows Code 2220000 and 009-654. Will not print
Restart and will not print after several times with not results in printing. This message has been on the printer for over two weeks. No change in operation no matter what I do.
  • Terry
    Terry Apr 06, 2015
    Hi Charles A Brinkley, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Which model printer is it? See the link below that suggests a bad sensor requiring a replacement part:
    http://en.community.dell.com/support-for...
    New Friend:
I was able to resolve the dreaded 009-654 on my c1765cnw. I downloaded/installed the usb driver for the printer and connected the printer to a usb port on my computer. I downloaded the latest firmware driver. I started the printer with a toner cartridge removed. I ran the Dell firmware upgrade program and it recognized that the printer was connected and loaded the firmware. When the firmware installation completed, I restarted the printer and everything is working again.
This solution may work on all other Dell printers that experienced the same error.
Posted on Jun 29, 2015
    New Friend:
    Problem Solver:
  • 13 Answers
Try the following:
http://www.fixaprinter.com/dell-printer-error-009-654/
I hope it helps.
Posted on Apr 06, 2015
My CLP315 WON'T PRINT - IT HAS THE ORANGE LED LIGHT ON. HAVE CHECKED THE PAPER LEVEL, WASTE TONER CARTRIDGE AND REBOOTED SEVERAL TIME BUT ORANGE LIGHT REMAINS ON
Dear Hamad
Pl. run the application SAMSUNG SMART PANEL or SAMSUNG EASY PRINTER MANAGER in pc. get a test print it will notice the exact error massage. You may also download the application from the link attached, by searching your model code.
Printer Support SAMSUNG India
Thanks.
Mar 24, 2015 | Samsung CLP 315 Laser Printer
When putting it on all lights are flashing one way ,at the same time as a results the printer doesnot want to print because one light should be on to show that it can print.
All service errors are indicated by all lights flashing as the primary notification or code. Please press the continue button to display the secondary error message or code. The secondary code indicates an area or function which has the error.
For further assistance, please contact Lexmark Technical Support.
Jan 30, 2012 | Lexmark E232 Laser Printer
Print head error message
hi
if yr printer is under woranty u need to do company services system coz i think that u do what as u abov say that u do a initial stape or if yr printer not on woranty and if u know a normal clining system do cline pritner otherwise u need to replace head...
if yr printer show red light blink do press 5sec. then print it..may be it's help u if u have any quary tell me feel free...
thanks
jo_chinmay
May 04, 2009 | Canon PIXMA MP760 All-In-One InkJet...
Cancel print button freeze
Try this:
Start > Run > Services.msc
Look for print spooler, right-click on it and select Restart
Then:
Start > Control Panel > Printers and Faxes > double-click on your printer > Click on Printer menu and select Cancel all documents. Click on Yes.
Restart both PC and printer
Jul 27, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
2 Problems: 1) Unable to get printer to print from desktop; 2) Kodak SW won't install on laptop
Download and install the new software and printer firmware from kodak.com (link below - firmware and software is the same for all the 5000 units). Do not use the CD, and Uninstall all previous versions before installing the new software you download from the site.
http://www.kodak.com/global/en/service/downloads/dln_ekn033540.jhtml?operatingSystem=mac_os_x_10_5_x&downloadLanguage=en
I hope this helps. If you still have problems respond to this message with what happens and I will try and get you more help
SDtester.
Mar 04, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
CANNOT PRINT DOCUMENT
More information is needed! First check to see if the print job actually went to the printer. Click start-control panel - printers and doubleclick on the 2600n. Are the print jobs sitting there waiting to go out to the printer? If so, your problem is probably in the computer or the cable leading to the printer. Look for an error message in the title bar of that window. If present, it will give you a good idea what is wrong. While there, use the first menu item (printer?) to "cancel all jobs". That can take a while, even a restart. There should be a "pause printing" item. If this has a checkmark beside it, choose the item to uncheck it. In the same menu, check the "set as default printer" item. If that isn't checked, when you print you must choose the printer. So you can't just click a print icon, you have to pull down the file menu, choose print, and then the 2600n in the dialog before clicking the print button. HP printers have a utility program that can tell you what is going on. Click start, look for Hewlett-Packard or HP, then the printer name and finally something like "HP Laserjet utility". Look for error messages which give some idea what is wrong. Could be an empty cartridge, for example.
Sep 10, 2007 | HP Color LaserJet 2600n Printer
922 All-inOne ink Jet printer doesn't print
Lots of luck. I couldn't even get the printer to load the software or install the hardware. I was helped by Dell's tech support (Dell has one of the best tech support programs that exists, in my opinion) for at least 4 hours without any good results. They sent me a replacement for a replacement and I finally got the printer and the software to show by installing it differently. Now it will not print, and, like you, the light to the power button blinks all the time and the printer states that there is no color cartridge installed, even though I have re-installed the new trial cartridge sent by Dell several times. I am going to purchase a new Canon Printer.
Nov 14, 2006 | Dell 922 All-In-One InkJet Printer
838 people viewed this question
k24674
jasbo
jasbo
