Question about Belling Ovens
Can my Belling B160F single oven be plugged in and does it come with 13 amp plug?
barkencoa
  • 3463 Answers
SOURCE: belling oven door not closing fully
Hi. Yes, you will need to replace hinges, and possibly the hinge guides located inside the cookere.
Posted on Nov 20, 2008
barkencoa
  • 3463 Answers
SOURCE: fan oven wont heat up
If fan is workintg, but no heat, then replace oven element.
If no heat or fan, then make sure timer is set on manual and not on auto
Please rate my solution.
Thanks.
Posted on Jul 01, 2009
barkencoa
  • 3463 Answers
SOURCE: belling synergie oven grill comes on oven fan
I suspect tha the oven element is faulty.
To access it, you will find it located at the rear of the oven compartment behind a removeable cover.
Hope this helps you.
Posted on Dec 13, 2009
  • 157 Answers
SOURCE: i have just bought a bosh hbn 331 sob /12 single
double oven needs 30amp
Posted on May 14, 2010
  • 32 Answers
SOURCE: Neff B1432N0GB Electric Single Oven Circotherm.Does it need to be hard wired or 13 amp plug
If your supply is 220v you can use it off a 13A plug. If 110V No.
Posted on Sep 10, 2012
Remove fan motor
Have more children (I cant even hear myself think)
>> design problem, not going to fix it with new parts..... ear plugs?
Oct 16, 2013 | Belling Ovens
I have a belling b160f cooker, which blows a fuse after an hour of operation, I suspect the cooling fan? This is assuming the cooling fan kicks in when it gets too hot? I have checked the elements for the...
Put an AC Amp meter (preferably a logging type) on to the unit for when using it. See if it exceeds that of the circuit breaker or fuse. Most of these appliances pull about the maximum allowable load from the mains supply. If the Amps never exceeded the rating of the breaker or fuse, this means the problem is with the electrical panel.
I have seen a defective heating element in appliances cause the tripping of a circuit breaker in the electrical panel. With age the element becomes a little lower in resistance at times, and thus is drawing slightly too much current. Replacing the element fixed it.
Apr 02, 2017 | Belling Ovens
HOW TO WIRE A SINGLE INTEGRATED OVEN? Can it be wired into the mains cooker point?
An integrated oven that has a 13 amp plug can be wired into a cooker point without any concerns since you are wiring it into a feed that is capable of handling a greater power requirement than is needed.
For the avoidance of doubt, the other way around, if you are considering putting a 13 amp plug on a unit that is designed for direct hardwiring into a cooker point, you should think again because it is probably capable of drawing more current than the 13 amp socket could safely handle
Jul 19, 2011 | Ovens
Do all neff oven & hobs have to wired in using 6mm cable or can they be wired into a13 amp system
If it is a single oven on it's own then it can be used from a 13 amp plug and socket, the same with the hob, if it is seperate from the oven it can be used from a 13 amp socket.
If it is a combined unit, then it will have to be hard wired to a seperate circuit using 6mm twin and earth cable, and fused on it's own circuit.
Nov 07, 2010 | Neff B1421 Electric Single Oven
Belling built in fan oven (XOU60FP)is overheating
Have same problem, I am repairing our 648HM double oven. Top oven overheats. I am an electronics engineer. I found that top oven fan has failed, this is the first thing to replace. The grill element also failed which maybe due to the overheating oven. NIGEL
Apr 03, 2010 | Belling XOU174 Electric Single Oven
My Belling oven has no heat, but the fan &
If the fan is working o/k, then there is little doubt that the oven element has failed.
This is quite common with fan assisted ovens.
The element is usually located at the rear of the oven compartment behind a removeable cover.
Mar 29, 2010 | Belling XOU252 Electric Single Oven
Does the belling d841ss come with a plug or does it need hard wiring
If it is a single oven without hotplates, then it is o/k to use it with a plug,
If it is a twin compartment oven, then it needs to be hard wired.
Thanks.
Oct 28, 2009 | Ovens
Bosch hba34b520
Yes, it is o/k to have a single oven connected to a 13 amp power supply supplied with a 2.5mm cable.
A lot of single ovens already come with a 13 amp plug fitted, so you can plug it straight into a 13 amp socket.
If there is no covenient socket nearby, then you can wire the 2.5mm cable srtaight into the oven terminal block.
I must stress that this only applys to a single oven and not a double one.
Plz rate my solution.
Thanks.
Jan 13, 2009 | Bosch HBL 442 / HBL 446 Electric Single...
Ovens Logo
63 people viewed this question
Top Belling Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you a Belling Oven Expert? Answer questions, earn points and help others
