Question about GE Dryers
How to install a heating element in the GE wall mount dryer
Dryer model PCKS433ET1WW type MD2A with the WE25M27K element kit
    Scholar:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 100 Answers
GE Dryer design (Most or almost)....
Heating element access is from the front.
1. Remove the Front Door
2. Remove the belt.
3. Remove the Drum.
You see the heating element. Very simple design
Posted on Apr 25, 2015
  • 19 Answers
SOURCE: how to get to heating element on ge dryer
Most heating elements can be accessed by removing the back cover of the dryer. Please unplufg the dryer first before starting this project.
Posted on Nov 09, 2007
  • 1028 Answers
SOURCE: replacing Kenmore dryer parts
that one is old enough to vote..if filter on top remove back find small hole on right just below top may be hidden by pasted on tech sheet..through hole insert long socket 5/16 or reach up from underneath with short ratchet and socket remove screws and attached wires lift element housing up slightly and pull bottom of housing out and down..5/16 screw on backside holdes element in
Posted on Jun 19, 2008
  • 10865 Answers
SOURCE: how do i get to gas valve to install lp gas
call your lp provider as they often will send out a tech to do this conversion for free. after all you will be buying the gas from them.
Posted on Aug 17, 2009
hektor1961
  • 70 Answers
SOURCE: GE DRYER HEATING ELEMENT
Yes, the whole drum needs to be removed:
Before you go trough this make sure you know for sure your elements need replacement by checking for continuity at both element terminals.
Make sure you do the same with your high limit thermostat on housing.
How to remove the drum?:
Disconnect the power source to your dryer before you begin to remove the drum. Either unplug the unit from the wall outlet, remove the appropriate fuse from the fuse box, or flip the appropriate breaker in the circuit breaker panel.
Pull your dryer out from the wall. Behind it, on the bottom, you will find a lower panel that will give you access to the unit's belt tensioner (also known as an idler pulley arm). Remove the screws holding this panel in place, and then remove the panel itself. Reach inside and release the belt tension by removing the belt from the motor pinion.
Older GE dryer models have a small drum bearing inspection plate in the center of the back of the dryer. This drum bearing inspection plate provides access to the dryer's circlip (also known as an e-ring). This clip holds the rear drum shaft in place. Newer models do not have this circlip or the drum bearing inspection plate.
If yours is an older GE model with an inspection plate, remove the plate now. It will be held in place with a single screw. With the plate removed, you will be able to see the drum support shaft and the e-ring (circlip) holding the shaft in place. Use a small screwdriver to remove the e-ring. You may also want to use a magnet to keep the circlip from falling into the dryer. You will also find several metal and nylon shims between the bearing and the e-ring, inside the bearing, and between the bearing and the drum. Take careful note of how they come off so that you will be able to put them back on again in the right order.
Now remove the front panel of the dryer. There are a couple of different ways this is accomplished. Whichever method you use is dependent upon your model. Some older models have two spring catch clips under the cabinet top, one on the left side, and one on the right side of the front. Use a putty knife, or some other flat and thin object to wedge in under the cabinet top. Release both spring catches and lift the cabinet top off the dryer. In some newer models, there will be screws joining the cabinet front panel to the cabinet top. You will have to open the door in order to find these screws. Once they are found, remove them and then slide the cabinet top forward and lift it off the unit.
Next, there are two screws located in the bottom of the front panel, one in each corner. Loosen these, but do not remove them just yet. Locate and remove the two screws at the top inside of the dryer's front panel. Again, there is one screw in each corner. Proceed to remove the other two screws you have just loosened. Disconnect the door switch wires and then lift the front panel off your dryer. With the front panel removed, lift the drum and slide it out of the dryer.
NOTE: In some models, you will have to remove the dryer drum glides before you can remove the drum. Also, now that the interior of your dryer is completely exposed, it might be a good time to vacuum out all of the dust and lint that has built up in there.
  • 1015 Answers
SOURCE: my GE Dryer, model number Model# DSXH43GV1WW
First make sure that the gas valve is on. Then verify that the gas connector is not kinked or restricted. then remove the connector at the back of the dryer and make sure there is gas pressure. Then visually inspect the pipe at the back of the dryer. Use a flashlight to inspect inside the pipe and make sure there is no debris inside the pipe that could restrict gas flow. On this dryer there is no removable burner door cover on the front or inspection window so you will need to remove the back panel of the dryer. Once the panel is removed you can turn on the dryer. You should first hear a click sound. That is the first gas solenoid valve opening. Then the igniter should start to glow. Once the igniter reaches 2200 degrees the secondary gas solenoid valve should click and the burner will come on. If you do not hear a click when the dryer is first turned on you will need test the first gas solenoid valve. Make sure it is getting voltage with a fluke meter. You can also touch a piece of metal to the top of the valve and the top should be magnetized when active. If you hear the first click but no igniter glow then verify the igniter is getting voltage and test the igniter with a fluke meter. You will need to test the ohms and most should be 500 to 700 ohms. If the igniter does not get a good reading or none it is probably defective and needs replacement. Usually most places that sell appliance parts will test the igniter for free. Just because the igniter glows does not mean that it is good. It can glow but not reach the 2200 degrees needed for the proper operation. Now if the igniter is good and you hear a second click then there might be a restriction somewhere in the gas line between the solenoids or the gas orfice at the burner. The sensor Gort was talking about is the flame rectification sensor and can detect the flame. It is rare for this to be faulty but not impossible. If you get flame for a couple seconds and then it shuts off it could be this sensor. Blow the burner assembly and this area off with compressed air and lint can block the sensor's ability to detect the burner flame. Also I believe your dryer has a larger fan blower than standard dryers. If this blower motor is not working the rest of the system will not come on. make sure the assist fan is working and that the vacuum switch is working and not stuck. Also check the vacuum line is not disconnected or restricted. And always remember that there are exposed power connections inside the dryer that could shock you and cause injury. use caution and if you do not feel comfortable working on this you might want to call a professional.
Posted on Sep 25, 2009
Ge dryer pcks433et1ww, does not heat
  • Check your circuit breaker
Feb 26, 2015 | GE Dryers
That is a bad model number. Are you getting it off the tag in the machine?
Dec 09, 2013 | General Dryers
DWSR483GG WONT START
the thermal fuse located on the inside rear wall of the dryer to the right side of the heating element behind the drum is open,on any GE dryer of this type if this fuse opens it kills the whole dryer operation..........no nothing,nada
Dec 09, 2012 | GE DRSR483EGWW Dryer
Hotpoint dryer (nvl333eyoww) not heating
The thermostat and element are mounted on the back wall of the dryer. To gain access you must remove the drum. Here is my home movie:
My home movie and repair photos for GE hotpoint dryers
Dec 02, 2012 | Hotpoint Dryers
My dryer turns on and runs but the clothes are not drying. its a crosley dryer and relatively new. checked lint filter and vaccumed up dust and lint and made sure that the screen and exhaust were clear
Sounds like the heating element or a fuse for the heating element. Impossible to tell you how to troubleshoot though unless I have the model type. Use google to type in your type and model number along with heating element (i.e., GE XXXXXX heating element troubleshooting) and you'll likely find some instructions for troubleshooting.
Sep 07, 2011 | Dryers
Should you have continuity on the cut off switch?
4239059.jpgcheck this out: If either one of these limits mounted aside the heat chamber check open the dryer will not heat but it will run. These come in a kit with both limits and both limits need replacement.
Apr 11, 2010 | Dryers
I have a GE profile 3 years old. It won't heat
There are many things that can cause a no heat symptom in an electric dryer, here is a list of possible causes in order of likelihood or ease of access.
1. An open fuse/breaker in the house fuse panel.
There are 2 fuses or breakers for the dryer, both must be good in order for the dryer to function properly. If one is open, it is possible for the dryer to run but not generate heat. In the case of breakers, try resetting them as sometimes one of the two can open but not physically tip the mechanical lever.
2. An open thermal fuse in the dryer.
Some models use a thermal safety limiter or thermal fuse which could open the circuit to the heat element. These are used to prevent a runaway or over heat condition and are often found mounted to the blower or heater element housing (see the links below for examples). These devices are a fairly current development and may not be found on very old dryers.
Note: If this is the cause of your current problem (pardon the pun), I strongly suggest you check the vent for obstructions and ensure its length meets the manufacturers recommended limitations, the shorted the better. Failure of this part could be the first indication of a potential fire hazard in the dryer!
3. The element coil is burnt out.
Dryer elements are bare wires coiled like springs, when they fail the wire will break opening the circuit. This breakage could be intermittent, only opening as the element expands as it heats. Sometimes the element coil has to be physically checked for breakages, especially where the coil goes through ceramic insulator which could hide a breakage from plain view. Depending on the brand and style, the replacement element may be just the coiled wire that has to be mounted into the original element housing. On other models the element assembly comes already mounted on a frame that then in installed into the element housing or directly into the dryer. Whichever the case, the element coil has to be replaced not just joined together using connectors.
4. A burnt wire or wire connector. Replace the burnt wire connector and/or wire and inspect the component terminal it was attached to. If any sign of charring or discoloration are visible on the component's terminal or repeated failures occur at that same location, replace the component the terminal is part of. Such items can include the main power junction terminal block (very common), thermodiscs (thermostats), heat selector switch, centrifugal switch (on the motor) or the timer.
Feb 20, 2010 | GE Dryers
How do you replace the thermal fuse?
The kenmore fuse mounts on the dryer blower housing.On a gas model this fuse when blown will allow the dryer to run however on an electric model this fuse will kill the dryer. The maytag fuse mounts on the right hand side of the heater. Note: the 2 fuses that come in the kit are rated for gas or electric dryers. When this fuse blows the dryer will be dead. The GE fuse mounts in the rear on the heater element pan. When this fuse blows the dryer will continue to run but their will be no heat. Dryer duct fuses are used on various brands of dryers as a back up they usually come in pairs with one mounted on the heater and another near the blower. The kenmore hi limit will kill the heater element but not kill the machine, it mounts on top of the heater housing. The bottom limit comes with it, always replace them both when repairing the dryer.
Dec 22, 2009 | Dryers
No heat from the dryer
if your dryer has a lot od lint buildup inside it, some of that lint will fall onto the heating element in back on th wall and cause a hotspot. To examine your heating element you must gain access to it innards. Open the door to the dryer and remove the screws that are holding down the top first.Raise the top or yank the top out yer way depending on the model (no I didn't look up your model)Next remove the screws holding the front panel on and lift it out yer way. Take the idler loose from the bellt and get the drum out. You will then be able to see the heater.The problem will become almost immediately recognized as a broken heating element. Please keep in mind you can buy a restring kit instead of a complete heater pan and assembly already restrung. Just do not leave large gaps that would cause premature breakage in the coils of the new restring kit. Be sure to get all the junk out the back of the drum before reinstalling it. How difficult is this job? It will take a strong will, detirmination, parts and a 6 pack. Send me the 6 pack. LOL
Apr 08, 2009 | GE Profile Harmony DPGT750EC Electric...
Dryers Logo
150 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
