Question about Stoves Ovens
Will a main oven door from a stoves 059050373 model fit a stoves 059050724 model?
shaggyrat
  • 1224 Answers
SOURCE: Cannot re-fit middle glasss into main oven door
this is a new one too me but ill give a shot
ive never seen an over where the supports were all intack
they should be screwed in at least to of them by what i call the hidden screw or plug either the 2 bottom come out or the 2 top ones come out to where the glass slides into position and just put the supports back into place
i was reading reviews on this particular item and clearly by what there describing this is not a very good functioning machine all out of tune from the older style
Posted on May 09, 2008
barkencoa
  • 3463 Answers
SOURCE: Oven door isn't closed tightly on both sides.
If it is a door that lifts up and down, then the only solution is to replace both door hinges, as they are not normally adjustable, it is the springs that are weak.
Plz rate my solution.
Thanks.
Posted on Jan 06, 2009
SOURCE: Frigidaire gallery stove, oven not working,
Morison,
The same thing happened to me about a week ago. I was preheating our electric oven, heard a very loud bang/pop. Checked and the oven had PF (power failure) I went downstairs and the breaker was tripped. Came back upstairs and to look at stove, the burners are working fine so I continued to preheat oven after a half an hour the oven was only slightly warm. Did you ever find out what was wrong?
Posted on Aug 07, 2010
  • 250 Answers
SOURCE: I have a Stoves 720
Try espares. If the part is not listed, there is a contact on the website to obtain a quote for a part. Of course once you have the part number you can try elsewhere.
Posted on Nov 18, 2010
barkencoa
  • 3463 Answers
SOURCE: stoves main oven door stays slightly open
You need to replace the oven door hinges as the springs are probably weak.
Posted on Nov 28, 2010
I had the oven on and I heard a loud popping noise, now the stove doesn't work (eg. the letter Fy1 comes up , the stove makes beeping noises, the stove door locks and unlocks etc.) The model # is...
rwere
Hello, and sorry to read about your problem.
Sounds like you have a general main board failure,
I suggest you call a service company
I tried to help you. Please help me and vote/rate my response thanks.
Dec 24, 2010 | Frigidaire Ovens
I have a Stoves 720 ef cooker model no 059040415. The main oven door hinges need replacing but I can not find a replacement set for this model anywhere. Can anyone help? ...
Nov 13, 2010 | Stoves 720EF Electric Double Oven
I have a Stoves double oven and after a power cut the clock has stopped working and the main oven is not working either. the clock is completely off. the small top oven is still working though. what can...
The clock controls the ovens. In other words, directly you set any time on the clock, a contact operates within it to provide power to the ovens. (Normally the grill remains operational). You may need a new clock/timer. Before you do so, try switching the power off at the main isolating switch and leaving it off for a few mins, then switching it back on, to try to get the clock to operate. You may need to do this a few times.
Normally Stoves stick a label identifying the model on the left hand edge of the lower oven. You see this when you lower the main oven door. it will probably start with a 05 and be 9 digits long. With this number you can identify the oven and obtain parts.
Nov 07, 2010 | Stoves 720EF Electric Double Oven
Morison,
May 04, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
F2E1 on stove after cooking on temps of 425-450 for 20mins stove shuts off and can not restart even if power is turned off and then started. must wait for stove to cool down and then press cancel and stove...
Is the background cooling fan running? Also, look under the oven and if possible take off the kick panel and clean all the rubbish out to ensure the cooling fan can circulate air round. As a check, when you turn any part of the oven on ( Main/top/grill) the cooling fan will run and you will feel a cool draft of air coming out of the gap just above the top of the main oven door. If the fan is not running, this will cause the unit to overheat and the overheat thermostats to kick in, turning the oven off.
If the fan is not running, you will have to take the whole unit out to gain access to the back panel.
Nov 28, 2009 | Stoves 720EF Electric Double Oven
Stoves 720EF - main fan not working
When you say the main fan, do you mean the background cooling fan or do you mean the circulating fan in the bottom oven?
Do you have the handbook for this oven as the wiring diagrams are included in it. If you haven't, you can take a copy from my BT Digital Vault - all I need is an email address to register you.
Looking at the diagram, the power for the cooling fan comes via the timer board. If, as you say, the fan doesn't work at all, the timer board could have gone faulty.
Nov 15, 2009 | Stoves 720EF Electric Double Oven
I own a Kenmore stove model #639539J2. The glass
yes. open the oven door to the first "click". it kind of stops about a quarter of the way open. most ovens you grab both sides of the oven door and pull up. some models have a couple of screws you have to take out before you can remove the oven door. then lay it down with the insie of the door facing up and take out all the screws holding the oven door together. some may be on the sides or the top and bottom of the door. when apart, clean first with easy off, then clean several times with windex till streaks are gone. assemble door in reverse and put back on stove.
Oct 10, 2009 | Kenmore Ovens
Kenmore gas stove Model 790
It could be that the sensor wire that controls the main gas valve is out of position. It should sit in the pilot light flame.
Look, and adjust if needed.
If it's ok, then you need a replacement main gas safety valve.
This should only be fitted by qualified personnel.
They do give up eventually after years of heating, and fail safe.
Dec 31, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Open Questions:
Ovens Logo
Top Stoves Ovens Experts
ashburton
Dan Webster
Dan Webster
Are you a Stoves Oven Expert? Answer questions, earn points and help others
