Question about Home
I have a J335 Hot tub , when i cange the water and turn back on i get white flakes coming from the jets, can any body tell me how to get rid of thm?
  • Nigel Lucas
    Nigel Lucas Apr 08, 2015
    Thanks for the advice from D. E. HEV. changed fillters and still get white flakes coming from jets.
    Genius:
  • 1,181 Answers
Did you check filter?
Posted on Apr 06, 2015
Testimonial: "Changed Filters for clean ones, still have white flakes coming from jets."
There is a sytem flush that I use when cleaning mine. Purchased it at Spadepot and it works well. You add it to the water and turn on the jets and let it cycle through. First time I did it, it grossed me out. Prepare for the nastiness you'll see, most of it is mineral deposits from the hot water.
Posted on Apr 21, 2018
What is the best and safest way to remove the bacteria flakes from a Kohler Purist BubbleMassage Air jet tub?
http://www.us.kohler.com/webassets/kpna/catalog/pdf/en/1198327_2.pdf
Call 1-800-4KOHLER 1-800-456-4537)
some parts are under warranty,call them b4 you do anything,they will help figure it out,the link is your manual
May 31, 2015 | Kohler K-1110-G-96 Purist BubbleMassage...
Galbocca tub with jets
You have some bacteria build up on the inside of your tubing of the tub.
Try some cleaning solutions per directions on the bottle of tub cleaner made specifically for this situation.
Cleaning Solutions
US Parts Center
Aug 22, 2013 | Whirlpool Home
Hot tub is leaking
How severe is the leak?
Is the water level dropping when the tub is not in use? If so you will need inspect the back (inside the tub) portion of each jet. There is a gasket and nut on the backside of each jet body, these may come loose for crack.
If your leak is only when you have the pump running, your leak could be on the suction or discharge side of the pump. Only leaking when there is water pressure.
A temporary fix is Fix-A-Leak - a water treatment that will temporarily repair any crack up to 1/8". Its no guarantee but might help.
Sep 27, 2012 | Pool & Spa
I have a walk-in jacuzzi-type bathroom tub. When the automatic blower comes on it sends out a mildew smell. How can I get rid of it?
First of all, after each use, refill the tub with warm water and run the jets for about 10 minutes to clear out any excess debris etc.
To eliminate the smell/mildew/mold. :
-Fill the tub to above the jet level with HOT (over 140deg.) water
-Add two tablespoons of low sudsing dishwasher detergent and five cups of distilled white vinegar
-Run the jets for 20 minutes
-Drain the tub and use a tooth brush or any small brush to gently clean inside and around all of the jets and nozzles, remove all foreign material you can from the areas inside (disassemble the outter rings to do so) and around the outlets. Be as thorough as possible.
-Rinse and refill the tub with CLEAN COLD water and run the jets for another 20 minutes.
-Drain the water and the smell and mildew should be eliminated.
To prevent future mildew build up/odors once a month fill the tub with HOT water (again) and four to five cups of vinegar (no detergent) and run the jets for 20 minutes. Drain and fill with clean cold water running jets another 20 minutes. If the tub is used very often you can increase the scheduled flushing of the system to every two to three weeks. The mildew/mold flourishes in the warm wet areas inside the jet tubing and nozzles. Diligent maitenance is the best way to make sure you're not bathing with any unwanted guests in your bathwater!
-Take care
Mar 01, 2012 | Washing Machines
Water runs very slowly when trying to fill jet tub.
Check to see if there are any screen type filter to the tub as debris may be clogging it. Also air lock can occur but it should not be causing problems as 90% clear them selves.....
Feb 15, 2010 | American Standard AMERICAN STD Savona...
I am getting lots of brown flakes in valves
The brown flakes are most likely rust from either the tank or associated metal piping. They could also be from the anode used in hot water tanks to combat electrolysis. Does the water have a Sulphur" or "rotten egg" smell to it? Are you on a well? There shouldn't be so much, as to plug up the valves. Turn off your heat source to the hot water tank. At the bottom of the tank is a faucet. Hook a garden hose to it, run it out side where the hose lays lower than the faucet if possible and flush the tank untill you have clear water again. You may want to do this a couple of times to be sure you get rid of any sediment in the tank. When you are done flushing, make sure you have the air out of the tank by opening a hot water faucet until it runs clear with no "spurts" of air. Shut the faucet off and turn the gas back on, light the pilot light and see if the problem persists. Also have your water tested. Sears does this for free -just take a sample in and they will tell you what the hardness is.
Jan 15, 2010 | Noritz 7.1 Gpm Natural Ng Gas Tankless Hot...
Please help me I have a American Standard whirlpool tub. I have flakes coming outta the tub when the water level reaches the jets.I have bleached the tub turned the jets on, drained the tub and did the...
Are they white flakes? Sounds like you have lime deposits turning loose in the plumbing.
Was the unit purchased and installed new? Maybe the privious owner had a hard water problem.
In either case, you may have to invest in a water softener.
HTH,
Mike...
Dec 07, 2009 | Water Heaters
Whirlpool tub, jets come on and won't shut off. No water in tub.
Is it a jetted tub, or a air bath tub with holes or jets in the floor? If it has holes or jets in the floor, the control box is bad and needs replaced. If it is a jetted tub, there may be a water level sensor, if so the sensor may be bad causing the tub to turn on.
Jun 13, 2009 | Whirlpool 5"x36" White Bathroom Drop-in ...
Home Logo
342 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
