Question about Westinghouse Televison & Video
My screen goes black after about 1/2 of watching. It starts to blink and then goes black. I still have sound. Is there a fuse or something I can change?
Model LD-4258
    Top Expert:
  • Westinghouse Master
  • 74,136 Answers
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Posted on Aug 13, 2015
SOURCE: screen goes black but still have sound
MINE TOO AND SANYO TOOK THIS TV OFF ITS SUPPORT WE SHOULD ALL SUE THIS COMPANY gcolella@snet.net
Posted on Jul 31, 2008
VOTIT
  • 2071 Answers
SOURCE: screen goes black,with sound
No picture sound ok
Note 1 a Raster is the name for a screen made of lines of brightness
Note 2, A Blank raster has no snow or picture, its just a lit up screen
Sound ok but no raster.
First increase tube's first anode voltage (knob on the loptx) to see if the screen is just too dark.
if after you have turned up the bottom knob on the loptx, there is still no brightness,check, for crt heaters, and EHT 25kv and focus voltage (2kv) and A1's/Screen/G2 voltage is 300-600v.
and check for field timebase (height), the next thing to check is the sandcastle pulse.
If it's present, colour decoder chip is probably faulty or lacks supply from the LT regulators.
NO LINE DRIVE If it's absent,check the line driver, locate the loptr(big and usually has heat sink).
follow the print from the base back to the driver stage , where you will usually find a tiny transformer with 4/5 pins
resolder it, even if it looks good,then with power on, check for voltage on all its pins, 2 should have LT(12v to 32v) or HT (90v to 150v), if not there follow the print back and look for either a transistor(linedrivetr), or the feed voltage line (maybe regulated),
If the voltage is ok on two of the driver transformer(drvtx) legs, the look from the base of the driver transistor to locate the timebase chip
and check round its pins for a 12v supply line, if there ,replace the timebase generator chip
Method of testing line drive, remove line output transistor, and connect a normal red led, across the B/E (longest leg to base), and when you power up the led should lite up.
Trace the pcb back from the BASE leg to find the line driver stage,
Its usually a very small transformer (4/5 legs) and a transistor connected to it,
The driver transformer legs(pins) will be two with voltage and two without
The two with power will either be about HT level (110v=145v) or about LT level(25v)
If not then trace back and look for a biggish 3w resistor.
If the voltages are correct the look for line pulses from the Timebase oscillator chip to the base (some overvolts protection circuits remove pulses if ht is too high).
If the voltage is low and the feed resistor is getting hot then check the base of the driver transistor if its HI over 0.5V then its being turned on by the timebase oscillator chip (protection ?)
If the voltage is zero check the feed resistor
If all seems normal check that 12v is getting to the timebase oscillator chip (IC) (12v regulator?)
Hope it may help you;
Regards,
VOTIT
Posted on Oct 10, 2008
welcomejee
  • 10594 Answers
SOURCE: HELP! KDFE55A20 watching TV and screen goes black and loses sound
Yes, its most probably lamp issue.
Please but original Sony lamp from Sony store and replace it in TV.
Posted on Mar 07, 2009
SOURCE: power led blinks but no picture or sound
Had the same problem myself. Took some doing but I managed to find a service bulletin that I downloaded. The problem is with the siene module and all you need to do is unplug connector JP63A from the main board and your TV will work again.
Take the back off the TV (there are a lot of screws) and look on the left hand side of the main circuit board that is mounted in the center of the TV. You will see a small white connector that is labelled JP63A, simply unplug it. Plug the TV back in and let it reboot. That's it, should be able to watch immediately.
Posted on Mar 15, 2009
  • 15557 Answers
SOURCE: video flickers on and off
Bad capacitors in the unit that are in the signal board.
Posted on Sep 09, 2012
Testimonial: "Guess this means if warranty is active, send it to get fixed, otherwise buy new TV. OK, thanks!"
Picture blinks on an off an has no sound how can this be fixed
TV pic blinks on/off when connected to satellite via hdmi - Forums ...
www.cnet.com > Forums > Sony
CNETApr 7, 2013 - We have a sony bravia LCD tv, model KDL-60EX500. ... The tv then started "blinking" on and off - no sound, black screen - for a half second or ... Samsung Series 3 (330), won't show any picture/no sound?
Jun 11, 2015
DLP Twon't turn on, blinking green lamp light then shuts dow ...
Jun 11, 2015
LG TV : Picture not coming on screen, but TV is on.
Jul 14, 2014
How many have 'blinking' issue with Samsung led tv
Jan 26, 2011
More results from www.cnet.com
VIZIO flickering Tv screen easy fix( no money ) - YouTube
? 1:58
https://www.youtube.com/watch?v=oWSFwS3FH_c
Aug 28, 2012 - Uploaded by Bill GatesBestfriend
VIZIO flickering Tv screen easy fix( no money ) .... I left town unplugged the Tv. When I came home home ...
Jan 26, 2016 | Televison & Video
Plasma TV
did you hear the sounds? or maybe you have defective power source in hot side..
Oct 02, 2007 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Sony kf 50e200a screen goes black and sound turns off for min...
TV has gone into "protect mode" to do just that to protect against the damaging failure that has been detected, you will need a servicer to diagnose the failure. Good luck and Merry Christmas!
Dec 25, 2009 | Televison & Video
Mar 07, 2009 | Sony KDF-E55A20 55 in. LCD Television
Screen goes black, 5 blinking red lights, screen back on for 20 seconds....cycle continues
Let me first say that if you are getting 5 blinks its not the thermal fuse. Your problem is your Lamp. You have what we call an intermittent Lamp. The only way to fix this is to replace the lamp. Part Number A-1085-337-A. Average cost $217.00
Circuitcity
Dec 09, 2007 | Sony KDF-E55A20 55 in. LCD Television
Watching tv and screen goes black w/no more sound!
you can check only for the fuse if it is busted or not
locate the fuse. check if it open using a tester.......
if you have no experience yet on electronic servicing then you can fix it.
Nov 13, 2007 | RCA TruFlat 27F520T 27" TV
Televison & Video Logo
48 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
