My little one threw juice where the pilot is and it is not lighting up. There is no pilot light .. Ive lit it with a bit of paper and then had to stand there holding down the button...
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 83 Answers
I can't tell by your description what type of pilot you have, it sounds like a standing pilot with a 30 mv thermocouple or a 750 mv pilot generator most likely on a wall furnace since a baby was able to throw to its vicinity, going with that I would say the pilot orifice is likely caramelized with burnt sugars or otherwise obstructed as a result of this mishap. If I am not correct please include make, model, serial # and what type of fuel if propane or natural gas and what type of unit you have, the more info the better result you will get.
Turn the gas off at the flex line gas valve and remove the pilot assembly and clean it ,
Posted on Apr 07, 2015
My jotul 200 direct vent gas stove pilot light won't stay lit. The pilot lights normally, and fires when the thermostat calls for heat. But when it turns off the pilot goes out as well. We cleaned ou
There's a little screw that adjusts the pilot light. It is usually on the block with all the other valves. Follow the pilot lite supply line to where the screw probably is located.
Nov 22, 2013 | Stoves Heating & Cooling
Pilot lights will not stay lit on stove top or oven. Can light burners with match. Crosley c3100paw
You need to clean thermocoupling off it what the pilot lit uses to stay lit. you canuse sand paper or brush May need to replace, clean gas tubes on pilot also could be that
Dec 12, 2011 | Crosley Kitchen Ranges
Pilot l.ight will not stay lit
The pilot light jet may have got a little bit of dirt or grit in it which is preventing it from keeping alight. Try probing the jet with a fine piece of wire to see it the blockage can be dislodged. You may have to unscrew the jet to clear it by blowing air through it. Make sure gas is turned off first before removing any parts.
The pilot light also has a thermocouple that allows gas to the pilot light while the flame is burning. If flame goes out it shuts gas off to the pilot jet. The thermocouple is bypassed by a switch during the initial ignition and once the thermocouple warms up after a minute or two of holding in the bypass switch, it should maintain the pilot. If, after cleaning, the pilot light keeps going out, it would seem that your thermocouple is faulty and needs to be replaced
Oct 20, 2010 | Whirlpool Water Heaters
I have a GE smart water heater model GG40T6A. the pilot light will not stay lit. what can i do?
Oct 08, 2010 | General Electric GE SmartWater Household...
HOW DO I LIGHT THE PILOT LIGHT FOR THE OVEN?
First pull out the broiler pan and look into the boiler and in the very back you will see there is the receptacle or the pilot light assembly. You will simply stick a match up to the pilot light and "poof" the pilot light is lit. Now if it doesn't light, sometimes you can just move this a little bit and get a little bit gas flow through there and in this case, it did light properly. And then now test the oven. Push in on the valve and turn it.
Kindly rate my help+++ Thank you
May 09, 2010 | Ovens
M# 640HORT4 s# H07A090378---MY Pilot Light wont
First thing is to replace the thermoscouple. When you light it you get it a bit hotter then normal. You turn on the main burner which keeps it hot. Then when it goes back to just pilot the flame is not hot enough to hold the pilot valve in.
Replace the thermocouple and you will be fine...
heatman101
Mar 26, 2010 | Water Heaters
Blower but no heat, no gas or no pilot ignition?
The pilot has to be lit.And to do so turn the knob to pilot.Then press it down and gas will come threw the pilot,then light the pilot,and hold the button down for about 45 seconds,count slow.The pilot has to heat the thermocouple up before the pilot light will stay on.Once it stays lit,turn the knob to on.
Oct 20, 2009 | Heating & Cooling
Pilot light on pool heater
One possible problem to that is a bad pilot generator, not a real common problem but often happens. To test the pilot generator, unhook the to wires that comes from the pilot assembly and hook to the gas valve. Wedge a screwdriver or something in the knob that you push down when regularly lighting the pilot so that gas will continue to flow to the pilot, if you dont hold it down it wont stay lit. Use a multimeter set on DC voltage and put prongs on the ends of the wires. If it is above 600 then it is good, a little bit below will still allow it to work, the pilot only needs like 100 millivolts to stay lit. If it is somewhere down around 500 or lower, then it should be replaced. Another cause, if the pilot generator is not bad, is that a switch in the circuit could be acting up and drawing all of the millivolts from the source before it gets back to the gas valve, in turn the pilot is not supplied with proper millivoltage to stay lit. This usually is the case if you use your heater and it works for a while but then shuts off, and the pilot goes off with it. You can test each switch without removing wires. Each switch should use 5-10 millivolts max. Put one prong on a ground, or just stick it in the ground, the guys i work with dont believe me that it works. And test one side of the switch with the other prong and then the other side to measure the millivolt drop across the switch. If all switches are good. Bad news, probably a gas valve issue. Although take the time to inspect the connections made at the gas valve and all other switches for that matter. A little rust, a little corrosion, can eat up millivoltage very quickly and this can be fix by using some sand paper or emory cloth to clean the terminals. Also check for loose connections, if you can wiggle the wire where it is connecting to the terminal, take it off and crimp it down a little tighter with some channel locks or something. Millivolt heaters are a pain in the but, that is why everybody makes and sells electronic ignition ones now.
Aug 10, 2008 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Unable To Keep Pilot Light Lit!
I have a Williams top vent gravity wall furnace (model 5009622) and I had the same problem. I had to take the cover off the furnace -- screw on top and two at the bottom (open the access door and there is one screw on each side) to get to the reset button for the vent safety shutoff system. On my furnace it's on the left side toward the top of the unit. I pressed the little red reset button and it's been working ever since. If your furnace is properly installed and doesn't have bird's nest in the chimney, it should work fine. Good luck!
Mar 04, 2007 | Williams 2509612 Ceramic Mid-Size Heater
Heating & Cooling Logo
50 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
