Question about Maytag Washing Machines
Yes I am running to change the coin amount to a lower amount on my Maytag extra large commercial Neptune washer model# is MAH21PDAWN
    Genius:
  • 1,167 Answers
Sorry but what make is the coin op on the machine, there are several makes
Posted on Apr 06, 2015
  • Heather Jeffers
    Heather Jeffers Apr 06, 2015
    It's not a coin slide machine its one that showsu digitally the amount but the quarters go i n one at a time and the only thing I see on the coin thingy E.S.D.
SOURCE: whirlpool coin operated washer and dryer
you need to take the coin slot out by using a socket wrench. then you need to flip the slot over and take the screws off. there is going to be two more screws to unscrew. take off that piece and also the claw like coin catcher. form here on out you should be able to remove as many slots as you need to.
Posted on Feb 15, 2008
  • 1294 Answers
SOURCE: RE: MAT12PDBAQ Maytag top-load washer (Commercial/Coin-op)
Click on 'washing machines' (below FIXYA) on this website, & search for your brand. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, u hv your manual on line. If available that is....................
Rate me pl if helped...................
Posted on Apr 10, 2008
sdmc73
  • 121 Answers
SOURCE: maytag neptune washer display showing FL
fl is a over fill. clean the pump out and the sump near the pump is in the back the dran hose goes to it
Posted on Nov 30, 2008
SOURCE: major shaking during spin cycle
I have the exact same washing machine with the same problem. It is a poor design and Maytag knows it. We should be entitled to a refund. This was a very expensive machine.
Posted on Jul 25, 2009
  • 16 Answers
SOURCE: my maytag neptune washer smells musty. what is
I owned a maytag neptune washer and had to run dishwashing liquid thru it occasionally to get the smell to go away. Finally we learned about a new gasket retrofit that they were doing which was covered by the maytag company we called and they installed it for free and the smell stopped. I had that washer for about 10 years and probably spent as much fixing it over the years as it cost. I now have a whirlpool duet front loader and love it. no smell and not problems. Try the electric dish washer soap.
Posted on Aug 02, 2009
How to run a spin cycle on maytag neptune coin op washer to get out extra water
You cant? the machine is set withing the panel and the control board, if ur having a problem with water in clothes then Id look at the belt if belt driven, the clutch and motor coupler if direct drive, and maybe even a bad transmission spring
Jan 08, 2015 | Maytag Washing Machines
Change the number of coins to operate
you need to take the coin slot apart take pictures as you go to put back together the parts to change amount are hidden inside it in hidden compartment if they wheren't removed by some one. your machine didn't come with the coin mech so if you don't have the parts you will need to take it with you to the parts house to get right parts. open the top of the coin mech box there are 2 long rod screws holding it in place usually 5/16 inch wrench fits may need to wiggle the heck out of it to get it out
Dec 31, 2009 | Maytag Neptune MAH5500B Front Load Washer
We have a maytag neptune washer and on evey setting, it's telling us d5 - what does it mean?
D5 means blocked coin 1 or coin drop control circuit failure, coin recognition and price display disabled while blockage persists.
Nov 07, 2009 | Maytag Neptune MAH5500B Front Load Washer
Need to reset price for washer and dryer
if its not working board might be bad
May 18, 2009 | Maytag Washing Machines
Water leak from bottom of Maytag Neptune washer
The water pump is cracke,. replace the water pump. Peter
Mar 18, 2009 | Maytag Neptune MAH5500B Front Load Washer
Replace coin box locks
I just called Great Lakes commercial for my old Maytag locks. About $20
616-531-8810 I spoke to Sue.
Feb 23, 2009 | Maytag Neptune MAH5500B Front Load Washer
My maytag neptune washer will not perform the final spin cycle. Therefore the clothes are still wet. Any solutions
Maytag washer parts, GE washer parts, and other brand names on the market are all designed to work interdependently with each other. This system starts to break down if even one part begins to encounter difficulty. Your washer's spin cycle flings a large amount of water out of the clothes, but if the water can't drain, the clothes will soak it all back up, defeating the purpose of the cycle. Excessively wet clothes after the spin cycle may not be caused by faulty washer parts, but rather a blocked drain is a very good bet. Check the drain line for a blockage and try again. If your hose is kinked or bent, this can also cause a drainage problem. The failure of one simple part creates a larger problem for all the washer parts. What can cause a blockage? A number of items; paper left in the pockets of your jeans, coins or other debris, even socks. Check your hoses, and make sure your laundry has empty pockets for future loads.
Feb 18, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag coin-op top load wont spin, motor runs, belt burns.
it not a belt, there is a $20 plastic and rubber coupling between the motor and the transmission that has broken.  It needs replacing.
Dec 25, 2008 | Maytag MAT12CS Top Load Washer
Washing Machines Logo
61 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
