Question about Frigidaire Washing Machines
Hi, I am looking for a tub seal for frigidaire model# BW225ES1. Does anyone know which part works for this machine?
    Top Expert:
  • Frigidaire Master
  • 45,332 Answers
These guys possibly have it http://erepairparts.com/
Posted on Apr 12, 2015
    Genius:
  • Frigidaire Master
  • 1,585 Answers
Try e spares england
How to remove agitator from Frigidaire washer - grime coming out from under agitator.
that most likely is coming from the tub seals and not dirt under the agitator,the tub seals are made from black rubber and metal.send the model number off of the washer or go to this site and look up your machine and it will have a breakdown on the agitator and you can see how to get it out.
http://www.searspartsdirect.com/partsdirect/index.action
Apr 07, 2013 | Frigidaire Washing Machines
Why is water leaking from the bottom of the the washing machine?could the drum be to full?
It could be a bad tub seal, hole in a hose, or even the drain pump.
I would need your model number to be able to tell you how to check these parts.
Sep 27, 2011 | Frigidaire Washing Machines
Hi, My Frigidaire Clothes Washer, Model FES445RF, which has developed a leak around the shaft seal where it enters the outer tub. Is it possible to repair and can I get to it by removing the outer tub from...
Hi, what you are experiencing is problem with the Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
You can get the parts by contacting appliance help on 1-800-470-7119
Oct 06, 2010 | Kitchen Ranges
Water leaking out of bottom of machine, nothing clogged and found a bolt head in tub
if you found the bold head in the tub chance are that the trunion bolt has broken off and cause the tub to become unsecure from the agistatir shaft and has torn the seal below the inner tub. remove the agitator and you will see the trunion and two bolts.the tub ring has to be removed and then the inner tub has to come out in order to replace tub seal.the tub seal part number is 5303279394 it cost around 45 dollars. the screws need for the locking plate are 131192800 and they caost about 4 dollars a piece.i hope this has helped you out.let me know how things go and if you need any more help let me know.
Jan 22, 2010 | Frigidaire FWSB5700DS Top Load Washer
Very loud on high speed spin cycle Sounds like jet turbine Frigidaire Model FWSB67RGS0 almost 10 years old. Was given to me. Don't know if it has always been this loud.
Most likely the tub seal on the bottom is starting to leak water onto the bearing under the tub and now the bearing is starting to go bad.
Jan 01, 2010 | Washing Machines
Machine leaves greasy looking streaks on clothes
tub bearing water seal gone ,needs new bearings and seals.
Jun 11, 2009 | Frigidaire GLTF2940ES Front Load Washer
Leaking tub seal, slow spin cycle
It's not worth fixing!
If it's 10 years old or more, better off replacing it with a newer machine which will be much more efficient!
Not worth the money to fix!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Try You should call service.:
A&E Factory Service
1-800-905-9505
Nation wide / 7days/24 hours
Good work
Please give me a "Solution Solved Rating", in this site!
Thank You
Neil
Jul 31, 2008 | Frigidaire FEX831CS Top Load Stacked...
Washer leaking from bottom of tub
If you have the tub out the seal can be removed by taking the brass ring off the shaft, its on top of the seal, then grab the seal with a pliers or pry it out with a screwdriver etc. The new seal will cost about $40-$50. when you put the new seal in put the rubber part on first, careful to not tear it on the slot cut in the shaft to mount the basket. Next put the old brass ring on top of the new one, use this to push the new ring on, this will help get it over the notch for mounting the basket. When the new ring is ontop of the seal remove the old ring, reassemble, check for leaks.
Jun 08, 2008 | Frigidaire FWS833A Top Load Washer
Bimmis repair
the small seal set on top of the large seal in the tub, lubercate the seal with some dish washing liquid and slide it down the agaitator shaft the brass side goes facing down
Apr 23, 2008 | Frigidaire CWS3600AS Top Load Washer
Washing Machines Logo
49 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
