Question about Danby DTT420W Portable Washer
Lost manual clean lint traps
    Genius:
  • 1,181 Answers
  • D. E. Hev Apr 06, 2015
    Has a link at the lower part
Csn you remove trap where lint filter goes
How To Clean Your Dryer's Lint Trap, Screen And Vent ...
greenlivingideas.com/2014/08/14/clean-dryers-lint-trap-duct-screen/
Aug 14, 2014 - Cleaning your dryer's lint trap, screen and vent is a great way to keep it using energy efficiently. ... (Of course, if you can hang your clothes to dry, you'll not have to go ... Now use the vacuum to remove any lint from the lint trap.
Stackable Dryer-Lint Screen-Where is it? - YouTube
? 3:09
https://www.youtube.com/watch?v=-qu0OF9V2vA
Dec 27, 2011 - Uploaded by OcRefrigeration & H.v.a.c.
This Video Shows Where a " Lint Screen " is in a Stackable Washer Dryer and How to Remove it. Clean it ...
How to Clean a Dryer Lint Screen ' Cleaning Guides
www.howtocleanstuff.net > Cleaning Guides
Jan 11, 2016 | LG DLE5001W Dryer
How do I retrieve a stick dropped down the lint chute?
if there is no water any where I would first use the wand of a vacuum cleaner that is going ( not the head just the pipe section)
Oct 11, 2015 | Dryers
I have a kenmore elite model 110.8586 or 8587 anyway I cleaned my lent screen put it back as I always do after every load and know it say check lint screen
Possibilities
The sensor is dirty..remove the lint trap and clean the orifice with a Swiffer duster. Dryer sheets can clog the lint trap use a tooth brush and detergent to clean the lint trap. Alternately see if it presents the same issue operating it without the lint trap. If you have an air compressor blow out the slot too. Make sure the main exit hose is cleared also *vent duct*. Tip the unit and blow the air in too.
Or a melting type fuse mounts on the blower housing and is tied into the same circuit as the door switch. When it melts it shuts down everything and this keeps the lint from catching fire.
Also check the belts.
You can turn off the beeping if you would like. Instructions are in the manual. By Pressing the buzzer button it has Loud medium low and off positions.
Remove the rear vent and try the unit...
I'm thinking that your sensor is probably the issue here.
Jun 10, 2011 | Kenmore Dryers
Water leakage after cleaning lint trap
make sure that when you replace your filter that there is no obstruction in the filter thread(small stone), i have had many problems with this,if the drain light keeps comming on then check the waste pipe stand.
Apr 07, 2010 | Miele W1926A Front Load Washer
I can't put the lint trap back into the slot it is supposed to be in. Have been using this dryer all day. I cleaned the lint trap out and it still won't slide back in. The lint trap is on top of dryer....
You probably have lint buildup inside the machine. try reaching inside it with a brush or something to clean it out. Also, it may be dusty, but run it for a few seconds with the lint trap out. That may blow the obstruction out.
Mar 07, 2010 | Dryers
Smelled like something burning, then quit working
clean lint trap out more often after every load and try to vacumn inside lint trap lint tends to slip down below the trap and yes it will ignite from time to time My gas dryer did it once and yours it smoked and stunk but because I was home it never went furtherif you open bottom front panel if your machine has one you can get a lot of old lint cleaned out there as well...and most dryers post in their manuals the risk of lint fires
Dec 18, 2009 | Dryers
Same Problem.. not able to find the lint filter on EWD1477
Lou, thanks for your answer, but I think that the original question is to do with the 'mysterious lint trap' that is mentioned in the manual but isnt actually a part of the machine (ie, its a typo / incorrectly edited manual - copied from another model)
The thing we are trying to find is the lint trap for the condenser unit, which is not the same as the drain pump/filter/trap on the bottom right of the unit (or, at least, shouldn't be - if it existed).
I think this model has a specially designed condenser unit that somehow cleans itself from the action of the washing clothes (in your next run), and flushes the lint from any previous drying cycles away with the rinse water during the next wash.
To help keep things clean, you could try to dissolve or at least break up any gunk buildup inside your machine (likely if your not using the 95 degrees C wash temp setting) by using lots of concentrated bleach (at max temp). However, this could damage the machine, but in my experience it is OK. I am not a employee of electrolux nor am I a service person :)
Jun 20, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Danby DTT420W Portable Washer Logo
Top Danby Washing Machines Experts
shaun taylor
Jim Y
Jim Y
Samyfam
Samyfam
Are you a Danby Washing Machine Expert? Answer questions, earn points and help others
