Question about RCA Televison & Video
How do i trouble shoot my 55 inch rca tv its stuck on stanby an wont turn on
    Genius:
  • 1,179 Answers
Have you tried the switch on the tv or just the remote?
Posted on Apr 06, 2015
techman
  • 3130 Answers
SOURCE: tv wont turn on
This problem very well could be a DM board problem. I have a how to fix file if this is indeed your sets problem. Leave your email and I will send it to you. Good Luck
Posted on Jun 15, 2007
  • 2920 Answers
SOURCE: hitach 55 inch 1998
have the poser supply checked sounds like it went out
Posted on Aug 25, 2008
ladywinn
  • 5138 Answers
SOURCE: rca d52w14 53 inch wont turn on
CK 3 capacitors on the deflection board cp150 2200uf 16 if it is puffed up on top it is bad so replace cp114 and 120 220uf 35v also.
Posted on Apr 02, 2009
techman007
  • 1112 Answers
SOURCE: 55 inch mitsubishi rear projection tv red lamp out of adjustment
Have convergence IC's replaced. I believe this unit uses STK-392-570 convergence IC's Only one has gone bad but replace them both, because if one has failed then the other is not far behind, for Blue and Green. One handles Red, One handles BLUE and Grn. There are only two of them in the set, They are the two largest IC's in the entire set.
Posted on Oct 01, 2009
BeckiB_DISH
  • 286 Answers
SOURCE: i won a rca scenium
Hello. I do hope that you have gotten this resolved. But if not, here are some simple steps.
If you are at TV1, where the receiver box is located, the tv needs to be on channel 3 or 4. Depending on the cable that is running between the receiver and the tv, the tv may need to be on an input, such as video 1 or 2. If you are at the TV2 location, where there is no receiver, then the tv needs to be on channel 60 or 73.
If you are using an HDMI cable- the TV needs to be on an HDMI input
If you are using component cables-the TV needs to be on a component input usually
If you are using RCA cables-the TV usually needs to be on a VIDEO like Video 1 or2
If you are using coax cable-the TV needs to be just on channel 3 or 4.
Becki Barned
DISH Network Customer Service
Posted on Feb 23, 2011
55". RCA smart TV new out of box yesterday HELP!!!
you might not have found the correct code for the tv+ remote .
Oct 17, 2015 | RCA Televison & Video
No sound
one thing to check is to see if your model has a speaker swith on the rear panel and see that it didnt get bumped to off
other wise check speakers in the menu to see if there turned off
if not there then you will have to trouble shoot the small signal board
Nov 09, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Oct 01, 2009 | RCA HD52W59 HDTV Projection Television
Color seperation but still have a picture
Problem with tv is convergence-unit is made by samsung.You can eithor replace the convergence board or trouble-shoot it yourself.
gonna need to replace both ics STK392-040-then check all the 3.9 ohm resistors
Sep 10, 2009 | Akai PT5598HD 55" Rear Projection...
Bush lcd 37 inch tv keeps going to stanby
my bush lcd tv keeps staying in standby mode and wont go on if it does go on its only for a minute or two....
Help please
Mar 04, 2009 | Televison & Video
Hitach 55 inch 1998
Jun 28, 2008 | RCA P52926 52" Rear Projection Television
Mitsubishi WS-55809 55 inCH tv
best way i would trouble shoot this would be to get a can of freeze from radio shack and spay the tuner if the problem comes back you know it's the tuner if not spray IC one at a time till the problem happens.
Dec 11, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Televison & Video Logo
43 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
