Question about Garden
Cant start engine - Garden
    Top Expert:
  • 10,875 Answers
Shear key needs to be replaced on flywheel
Posted on Apr 07, 2015
    Top Expert:
  • Garden Master
  • 12,819 Answers
Check for spark - if no spark then it is probably an open igniter.
If spark is good then the hassle is carburation and the latter has to be cleaned out.
My 2005 model Nissan Xtrail cant start but just cranks. i parked it fine
removed the two 'Fuel Pump' fuses from driver side fuse box located underneath the steering wheel. one is 10A (Red) and other is 15A (Blue). Then started the car, car started for couple of seconds before the engine went dead again. put back both the fuses, cranked the engine and it started fine, there was bit of smoke for first few minutes but it all cleared up.
Feb 16, 2016 | 2005 Nissan X-Trail 2.5i
My Isuzu kb250 diesel engine model 2008 it doesn't want to take gears when running
YOU probably have a problem with the clutch not fully releasing when you are driving.
Clutch Drag Kills Synchros
Feb 02, 2016 | Isuzu Cars & Trucks
Old M70-130067 Sno Thro my Dad says it just conked out cant pull the pullstart at all and the electric start doesnt even make a sound ...... oil looks fine ..... suggestions ?
assuming you have already tried to remove all external drive belts from blower (to remove all load from engine) try removing the spark plug from engine , and try pulling engine over with pull start (it cant start) if it still fails to move at all or is real hard to pull look farther for an internal engine fault , if it does move then you have an "Hydraulic" problem most times is caused by motors oil inside cylinder , most times caused by head gasket failure or turning engine on it's side will do it too
Apr 06, 2015 | Garden
Can an overheated transmision make the car to fail to start. my isuzu bighorn cant start
no,
run at full speed, yes, can fail
the engine must crank to start, (a/t cars only) and if cant crank it cant start.
so if it cranks,(old post) then next is spark
then try test fuel if spark is good on unstated engine
its not a diesel is it?
Dec 22, 2014 | Isuzu Cars & Trucks
I cant start my van
I would recommend someone check the engine computer for trouble codes.
Jan 22, 2014 | 2002 Mitsubishi Colt
Engine cant start because they is no spark.isuzu kb 220
welcome to USA
the country with NO KB trucks
that means no books to match.
books are necessary.
no year stated or country or size engine. ok its petrol got that.
spark , are all sparks dead or just one or a pair.
wow, engine cant run on 1 cylinder can they.
if spark is dead on all cylinder you must scan the PCM to see why.
cam belt snapped.
CMP sensor dead
CKP sensor dead.
coil pack dead. (how many does it have, I cant see our engine or spark wires, so can never guess )
Dec 23, 2013 | Isuzu Cars & Trucks
Dies when started cant find check engine light
The service engine light is the check engine light. Different name for the same thing.
Feb 22, 2010 | 2002 Ford E350
I cant get it to start i replaced spark plug
Does the new plug spark outside of the engine? Put the base on an unpainted part of the engine with the plug wire on and kick it through a few times. Does this engine require a battery to run or is it a self-contained ignition system? Remove the fuel tank and check for loose wires or other parts. If it requires a battery, check the connections at the battery for corrosion or looseness. Is the battery charged?
Sep 02, 2009 | Honda CRF 230 F Motorcycles
Vehicle cant start fuel supply ok ingnition ok engine comprassion is ok
If oyu have spark, fuel and compression the engine should start.
Nov 07, 2008 | 1996 Lexus LS 400
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
