Question about Fitbit Flex Wireless Activity & Sleep Wristband
How close does my tracker have to be to my phone to sync? I've lost my Fitbit but my phone says the battery is full so I'm revisiting places it may have fallen off with no success to get it to sync.
I need to update my fit bit blaze and correct the time how
Blaze-If you shut down your tracker or the battery drains completely, the time will be wrong until you sync.
https://help.fitbit.com/articles/en_US/Help_article/1877
How do Fitbit trackers sync their data
Jul 04, 2017 | The Computers & Internet
My fitbit flex died - cannot wake it up; also it's tied to my cell phone and that doesn't respond - totally blank!
How to fix broken Fitbit - sync Fitbit with phone app - PC ...
www.pcadvisor.co.uk/how.../how-fix-broken-fitbit-sync-image-3499292...
May 15, 2015 - Fitbit Flex, Fitbit One, Fitbit Zip, Fitbit Force or Ultra not syncing with the Fitbit app ... To get the Fitbit app sync working again restart the Fitbit tracker. ... charger, has a battery charge but is not lighting up, or isn't tracking your steps. .... I've already done all the obvious stuff: turning off my phone, turning off and ...
Fitbit Flex review - The disappointment we've all been ...
blog.hyperexpert.com/fitbit-flex-review-the-disappointment-weve-all-be...
May 5, 2013 - My wife and I are both in good shape, we both wanted the Flex just to ... app, wait for the device to finish connecting and syncing to your phone, ... to sleep mode, I have to do all of this? and then again to wake it up? .... Also, doesn't the manual say "not" to wear it in the shower? ..... I appreciate any response.
Jan 06, 2016 | Fitbit Flex Wireless Activity & Sleep...
How do I set the time on my fitbit?
After you charge it back up, you will need to sync your Fitbit, this Sync will update the steps
May 20, 2015 | Fitbit Zip Wireless Activity Tracker,...
How do I delete my info form the FitBit flex? I want to return my new flex to buy a FitBit Surge.
HOW DO I DELETE PROFILE DATA FROM MY TRACKER? Fitbit uses your height, weight, and age measurements to properly calculate your stride length (which helps determine your distance), calorie burn, and active minutes.
To delete your profile measurements from your tracker, the tracker must be set up to a different account. Once a tracker is set up to a different account, it will automatically unlink itself from the dashboard and all of the tracker's stored data will be permanently deleted from the tracker. You can find instructions on how to create a new account in the following articles:
May 14, 2015 | Fitbit Flex Wireless Activity & Sleep...
My battery is charged but showing empty on computer. I restarted it but still showing empty.
with computer turned off take out battery and wipe off contacts then reinstall battery. If it is still empty after letting it sit a bit to see if it is charging you either have a bad battery or the charger in the computer is bad . that is an expensive fix. usually not worth the money unless you have an expensive computer and then that probably would not happen.
May 07, 2015 | Fitbit Flex Wireless Activity & Sleep...
How do I setup my fitbit force
Does your Force show up on the Dashboard?
If not then
http://help.fitbit.com/articles/en_US/Help_article/How-do-I-set-up-my-Fitbit-tracker-on-a-computer/
If your having problems syncing then
http://help.fitbit.com/articles/en_US/Help_article/I-m-having-trouble-syncing-my-tracker-to-my-dashboard
Of course without knowing what you Sync through I can not be much help.
Dec 16, 2014 | Fitbit Force Wireless Activity Sleep...
How do i connect my fitbit device to my verizon tablet.
Syncing Your Data
  • The Tracker will upload your data every 15 minutes provided you are within range of any plugged in base station (about 15 feet for direct line of sight), the computer is on and not in sleep or hibernate mode, the software is installed and running, and you have an active internet connection.
  • While out of range, the Tracker will look for a base station every minute until it syncs your data, after which it will wait 15 minutes before searching again.
  • You can see when the last successful sync occurred by viewing your main page at www.fitbit.com. Near your profile picture, you will see Synced with a time and date of your last sync.
  • If you want to force the Tracker to upload its data, place the Tracker on the base station.
  • While we recommend you sync your data regularly, the Tracker has the ability to store 7 days' worth of detailed, minute by minute data. It will store summary data (calories, distance, and steps) for the trailing 30 days. If you wait longer than 7 days before syncing, you will not see your minute by minute graphs (except on the most recent 7 days).
  • Your Tracker is able to sync from multiple computers, as long as each computer has the Fitbit software installed and a working base station is plugged in. You don't need to physically connect the devices. Simply down load the app and upload your info.
Sep 17, 2014 | Fitbit Ultra Tracker
Fitbit force manual
have you tried restarting your phone? Most of the time this fixes sync issues. Make sure you check out a bitbelt to protect your force from loss.
Sep 06, 2014 | Fitbit Force Wireless Activity Sleep...
Lost fitbit,bought new one and it will not sync
You must use the app or Fitbit Connect to set it up. The Bluetooth settings screen on the phone or computer will not work.
Mar 03, 2014 | Fitbit One Activity Tracker, Black
Fitbit Flex Wireless Activity & Sleep Wristband Logo
87 people viewed this question
Top Fitbit Exercise & Fitness Experts
L Pfaff
L Pfaff
ray gallant
Are you a Fitbit Exercise and Fitnes Expert? Answer questions, earn points and help others
