Drain pump for logic L712WM13 - Washing Machines
    Genius:
  • Washing Mach... Master
  • 1,585 Answers
E spares england
Posted on Apr 12, 2015
E31 error on zanussi ZWD 16270w1
Sounds like a slow drain problem.
It would be suggested to check the drain hose, the filter and pump, and maybe replace the pressure switch if that does not work.
Sequence:
1. open up the filter and clean it
2. check the drain hose, and let it drain out freely into a bucket
3. run the machine without clothing to see if it starts working again
4. check if the pump runs
5. replace the pump line pressure switch.
If it still does not work, consider buying another machine, since the cost of the logic board is significant. (maybe the machine is old enough and needs to be replaced)
Sep 05, 2017 | Zanussi Washing Machines
My samsung sdc1a809 dryer always giving drain water. Althought the water tank is empty. Checked the draining pump working properly. Any ideas !??
The sensor or logic board could be defect, when the logic board thinks there is still water in the tank. I would look there.
Apr 13, 2015 | Samsung Washing Machines
HAIER ENCORE WASHING MACHINE MODEL GWT750AW WONT DRAIN
Most likely pump but could be logic board not calling for machine to drain.
Nov 20, 2014 | Haier GWT750AW 4 Cu. Ft. Encore Top Load...
Logik L712WM13 error e30
On a Logik L712WM13 E30 means there is something stuck in the door.
Feb 21, 2014 | Washing Machines
I have LG fyzzy logic 6.5 kg WFS65AO1DCT and it keeps loading and draining water even when in spin
see this causes and fix it. God bless you
This happens on new installations usually. The drain hose must be higher than the highest fill height of the washer. If the drain hose is to low it will create a siphon effect and drain the machine. Next is the drain hose is to tight in the standpipe. The standpipe is your homes plumbing. If the drain hose does not have an air gap aroung it, it can cause a siphon effect and start draining your machine as it fills. If none of these are the problem and your drain pump is running at the same time it is filling you will need to replace the control. For top load machines follow this video and for front load machines follow the tutorial.
Sep 30, 2012 | Washing Machines
Dishwasher will not drain and it is not in the drain line, would the next logical thing be the pump?
Dishwasers usally have a gravity feed on the drainage. Make sure there is not a clog fron where it drains
Dec 30, 2011 | Frigidaire Dishwashers
Drain pump goes ON when ON-OFF button is pressed, even if the know selector is in OFF position and the machine is dry. There is no fault codes and the dishwasher complete the washing cycle OK, but when...
Seems that the drain pump circuit in the main program controller unit power and keeps on as there is no logic feedback to cut off the power. It can be that the drain is clogged and so the water level detect keeps sensing due to a fault. check the sensors , check the drain filters , check the machine LEVEL so that the water drains clearly to the drain pump.
Aug 08, 2011 | Miele G7856 24 in Dishwasher
Will not drain the water and spin
this unit will not spin until the water is drained. your pump is jammed or faulty.if u r confident, remove and clean pump.please turn off power b4 u work on it do want any accidents . please reply if u need more help
Apr 08, 2010 | LG Washing Machines
Water can't drain out properly
hi
i think all the fuzzy logic machines have an electric pump so it is maybe not running to pump the water out or i have had problems with the electronics that run the pump
cheers grantsreps
Sep 29, 2008 | LG Washing Machines
Servis easi logic 1600 washing machine not working
my servis eai logic 1300 will not rotate half way through the wash but will still spin and dry etc please advise.
May 09, 2008 | Washing Machines
Washing Machines Logo
117 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
