Panasonic washing machine model no NA-F90B3 having spine problem ,
  • tom cassidy
    tom cassidy Apr 12, 2015
    Hi Muhammad Siddiqui, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
  • Washing Mach... Master
  • 5,323 Answers
No spin, or lite spin try these:
Using a multi meter check for continuity the door switch, which when bad may not allow agitation or spin. The lid switch assembly can fail either mechanically or electrically.
Check the clutch, brake assembly and transmission, one way to check for slipping is to get under the machine after a spin cycle ( this is if u get a lil spin but not much leaving clothes still wet) mix in a spray bottle a lil water and some dish detergent, then spray it on the clutch assembly ( the metal round pc. Connected to the tranny) if it sizzles and steams up then u know its bad and slipping. Another way to check clutch if u get no spin at all? Is to take it out and use ur hand to try and turn the inner spring assembly pushing it around the inside? If its very easy, it BAD should be hard to push by hand.
Next check the motor coupler which engages the tub and tranny to the motor. ( if its bad u usually get no wash or spin or very little of either)
Next check for a loose, worn or broken belt if belt driven.
On some front load models u may need to check the STATOR assembly.
The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Sometimes a no spin machine can be due to a plugged waterpump hose or obstructed water pump propeller. Check these by eye and hand.
Posted on Apr 13, 2015
Why the Panasonic Washing Machines error code "h 02" displaying?
Google "panasonic washing machine error codes"
I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
Jun 11, 2016 | Washing Machines
Panasonic model Na-f70b2 error. U12 and stop motor
Try this: it should give answers to the "self-diagnostics".
http://panasonic.ae/en/manuals/NA-F70B2-65B2.pdf
May 05, 2015 | Washing Machines
The error code H 01 in Shows my washing machine(panasonic na-f70gs)
http://www.ukwhitegoods.co.uk/help/fix-it-yourself/fault-codes/laundry-fault-codes/3328-panasonic-na-series-washing-machine-fault-codes.html
H01
Pressure sensor or level switch detected as out of range
  • Check wiring to level sensor
  • Check pressure switch is not defective
  • Replace pressure sensor
  • Replace main power PCB
Apr 06, 2015 | Washing Machines
Panasonic washing mashin NA-F65B2 is not getting drain while its spining process.How can i solve this problem?
The pump inlet may be blocked check the flinet fllter isent blocked i dont know about panasonic brand but phisher pikal the filter is inside the machine you have to take the front of to get to it make sure the belt has not come of that drives the pump
Feb 15, 2015 | Washing Machines
My panasonic waching machine model is NA F80B2 Error is U 11 U 14
See http://www.manualslib.com/manual/783539/Panasonic-Na-F78b2.html?page=13#manual
Feb 06, 2015 | Washing Machines
My Panasonic top loading washing Mch model NA-F70G5 has no lite or power tks
In most cases ,problem is main control board on most front load washer
Oct 03, 2014 | Panasonic Washing Machines
Error h51 panasonic front loader washing machine 8kg
What happen the washing machine model NA-148VG3 show H57 mean what happen?
Jun 02, 2013 | Washing Machines
Error code h41 on panasonic washing machine model na-168vx2
U11
The washing machine cannot drain
  • Check that filter is not blocked or obstructed
  • Check drain hose is clear of any blockage or obstruction
  • Check wiring to drain pump
  • Check drain pump is not defective
  • Check level sensor or switch
Feb 15, 2011 | Washing Machines
Please I have got error code H 43 on display monitor of Panasonic washing machine model NA-14VX1, If you please may I know what is meaning this code and where is the problem. Thanks in Advance
This is a code for an internal leak. Same happened to us today 2 weeks after buying the machine from John Lewis. We had a small pool of water appear in front of trhe machine. Waiting for Panasonic to sort out a repair.
Feb 05, 2011 | Washing Machines
Got error code u11
u11 is not a valid error code - please recheck.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 12, 2009 | Washing Machines
Washing Machines Logo
93 people viewed this question
Top Washing Machines Experts
