Question about Kelvinator Dishwashers
I want to change the color of my panel
It came with a panel that is different colors and I don't know how to change it
SOURCE: front panel color
I have the use&care guide for this unit. It explains how to change the panels - I also notice in ebay that you can order generic stainless ones. I'm going to remove my white panel to install the stainless.
Posted on Nov 02, 2008
woobie dog
  • 1273 Answers
SOURCE: I have an
Hi, W/D here.
Your panel may be able to be changed. Look at the top of your panel for a trim piece held in place with screws.. Remove the screws and try to slide your panel front up and out. If it will come out like this, you can change your color very easily. In fact, some dishwashers came with 2 panels with each side painted a different color (harvest gold or avocado green anyone?). If your panel will not come apart, all is not lost....
I have seen panel covers available on EBay, in the dishwasher section. Some are sheetmetal and some were like sticky backed foil. If you're going stainless, this might be the route to take.
If you are artistic, you can mask and paint the panel with either a spray enamel, or one of the newer plastic paints. Not crafty? remove the door and take to an auto painter. I know for a fact that most of them will paint a refrigerator (ahem), so a dishwasher can be done as well.
Hope that this at least sparked a few ideas! Best regards, --W/D--
Posted on Aug 13, 2009
  • 246 Answers
SOURCE: Need to change color of front of dishwasher
Try Applianceart.com. They have a ton of options in colors and desings
Posted on Jan 14, 2010
  • 246 Answers
SOURCE: How to change front panel on whirlpol dishwasher to
you can check out www.applianceart.com. They have options where you don't have to remove your panel, you can even turn it stainless.
Posted on Apr 11, 2010
  • 246 Answers
Check with www.applianceart.com, the have options that will help you change the look without changing the panel
Posted on May 25, 2010
Fix color on my computer
Click start control panel display desktop you can select a different desktop from the drop down list
or a browse button where you can select different pictures this may vary depending on your operating system
also you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal
size, larger size or custom settings
Always click APPLY after making any changes
windows 7
Open Personalization by clicking the Start button, clicking Control Panel, clicking Appearance and Personalization, and then clicking Personalization.
Click Window Color and Appearance.
Under Window Color and Appearance, click the color you want, and then click OK.
Note
If you see the Appearance Settings dialog box instead of the Window Color and Appearance
window, the theme might not be set to Windows Vista, the color scheme might not be set to Windows Aero, or the computer might not meet the minimum hardware requirements for running Windows Aero. For more information, see Troubleshoot problems with Windows Aero.
Hope this helps.
Nov 23, 2012 | Dell Computers & Internet
Change resolution notebook
click start control panel display desktop you can select a different desktop from the drop down list
also you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
always click APPLY after making any changes
windows 7
Note
hope this helps
Aug 14, 2012 | HP 431364-001 PAVILLION DV6000 AMD CPU...
Laptop screen problem
windows 7
Note
hope this helps
Aug 08, 2012 | Dell Studio XPS 1645 Laptop
How do i change desktop back drop
windows 7
Open Personalization by clicking the Start button , clicking Control Panel, clicking Appearance and Personalization, and then clicking Personalization.
Note
hope this helps
Jul 28, 2012 | ASUS Accessory 90-XB2UOKSL000B0 Epad...
I have problem with color setting
· open Control Panel and select Display menu and open it
· Then select Settings Tab from where you can change resolution and Color quality as 32 bit /64 bit
· ]Or you can click on Advance where you can set DPI
If you want to switch in 256 color
Some games and other software programs require that your monitor be set to 256 colors, or they run better in 256 colors. Many of those programs will switch your monitor to 256 colors automatically when you start the program. For those that don
May 22, 2011 | Computers & Internet
My computer is changing his contrast by itself what should i do?
click start control panel,display,desktop you can select a different desktop from the drop down list also settings you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general
don
Feb 07, 2011 | Computers & Internet
I cant get color with my cable, but i do get color through my game system. how do i change the black and white to color on cable? i have tried all different scenarios with cords. rezga 32'' 08'
Cable isn't on color?... Could it be that its on a different format than your TV supports? (I.E. Your cable is NTSC but your tv is PAL)
either that, or Cable on your TV is set to the oposite Video Format. Check your user's manual just in case. and if you don't know what NTSC or PAL are, go HERE:
http://en.wikipedia.org/wiki/PAL
Oct 02, 2009 | Toshiba 37CV510U 37 in. LCD HDTV
I have an "older model" Maytag dishwasher (WU202). Can the panel be changed to a different color?
Hi, W/D here.
Aug 13, 2009 | Dishwashers
Front panel color
Jul 28, 2008 | Whirlpool 24 in. DU1100XTP Built-in...
Dishwashers Logo
48 people viewed this question
Top Kelvinator Dishwashers Experts
P Scarbs
Level 1 Expert
paul
paul
Are you a Kelvinator Dishwasher Expert? Answer questions, earn points and help others
