Question about Radio Communications
How do I pair the Bluetooth - Radio Communications
Can I pair my Bluetooth earphones to my iPad?
How to pair Bluetooth headphones to IPAD?
Most headsets have a power button or a switch to turn the device on. Press the "Pairing" button on your Bluetooth headset, if necessary. Select your headset from the Devices list on the iPad's Bluetooth window. Enter the passkey or PIN for your headset, if prompted.
Does the iPad Pair With Bluetooth Headphones? ' Chron.com
smallbusiness.chron.com/ipad-pair-bluetooth-headphones-62883.html Search for: How to pair Bluetooth headphones to IPAD?
Dec 05, 2016 | Radio Communications
Bluetooth cant searching another device? what i should did for that?
Depending on your computer and any bluetooth devices make sure both have bluetooth are either turned on or made bluetooth discoverable
Bluetooth Pairing
Bluetooth pairing is necessary whenever two Bluetooth devices connect to each other to share resources.
A trusted relationship is established between the devices using a numerical password, commonly referred to as a passkey.
Depending on how often one Bluetooth device connects to another, the user might opt to have the passkey saved for future connection attempts or prompt to enter the passkey each time the devices request communication with each other.
Bluetooth Pairing Service
In most cases, Bluetooth devices are paired only once, and the details of the relationship are saved for later connections.
The pairing service, an integral component of all Bluetooth devices, is responsible for maintaining a list of devices that have made successful connections in the past.
It is essentially a passkey manager remembers the specific details for other trusted Bluetooth devices.
If a user has a reason not to allow automatic connections for specific devices, the Bluetooth pairing service will not store passkey details.
Preparing to Pair Because Bluetooth is a standardized-communication method, making trusted connections between Bluetooth devices is a straight-forward and simple process.
Before attempting to pair two Bluetooth devices for the first time, it is recommended to have both devices fully charged, turned on and Bluetooth enabled.
At least one of the devices must be set to discoverable mode, which means for a short period, the device will be announcing its presence to other devices within its range.
Pairing Bluetooth Devices
Have the second device search for other Bluetooth devices.
There are many types of devices on the market and just as many ways to put your device into discoverable or searching modes.
It is recommended you view the documentation for your specific devices to determine how to enter these modes.
Within 30 seconds, you should see the devices have found each other and a prompt to enter a passkey will be presented.
Bluetooth Pairing Passkey
The passkey is a four-digit number you supply at the time you are establishing your trusted relationship between devices.
If a specific passkey is set by the manufacturer, you can try "0000," or you might have to find the passkey in your device's documentation and enter that instead.
After you enter a passkey, the other device might prompt you to enter the passkey you entered. When the passkey is verified on the other device, the two have been paired.
The Bluetooth device and passkey information are stored using the pairing service so future pairing attempts do not have to be made unless desired as a security precaution.
Bluetooth software
You may wish to check out Bluetooth Command Line Tools a set of console utilities designed to work with Microsoft bluetooth stack.
Other Bluetooth resources
Visit our free premoderated Directory of Bluetooth Resources.
Aug 04, 2013 | Computers & Internet
Bluetooth pairing codes
If you are familiar with Bluetooth wireless technology, you'll probably recognize the term "Bluetooth pairing". But do you actually know what Bluetooth pairing means?
Bluetooth pairing occurs when two Bluetooth devices agree to communicate with each other and establish a connection.
In order to pair two Bluetooth wireless devices, a password (passkey) has to be exchanged between the two devices. A Passkey is a code shared by both Bluetooth devices, which proves that both users have agreed to pair with each other.
This is the normal process that occurs with Bluetooth pairing:
Oct 06, 2012 | Radio Communications
E52 i want pair with my pc i do not know what is the pair password how to do it please clear
Hi, Read the owners manual for your bluetooth device. You will need to find the code to pair your headset to your phone. This code is usually 0000 (those are zeroes) but verify before you proceed.
Enter your bluetooth option on your cell phone. These can be found in your menu under "bluetooth," "connections," "settings," or something similar.
Turn on your bluetooth headset and put it in pairing mode. Pairing mode means the bluetooth is ready to be found by your cell phone. To pair your headset, follow the owners manual for your specific bluetooth model.
Select "add device" or "search for new device" from your cell phone. Your cell phone will then search for your bluetooth. Once it is found, or discovered, you will need to enter the pairing code (most likely 0000, check your manual to verify).
Select "connect" to finalize the connection if the bluetooth headset didn't connect automatically after the pairing code was entered. Make a test call with your bluetooth in your ear to ensure it is connected properly.
Feb 13, 2011 | Nokia BH-104 Bluetooth Headset
How pair bluetooth Jabra vbt2050 with a blackberry storm 2
In order to pair a BlackBerry device with a Bluetooth device, the Bluetooth device must be in pairing mode. Most Bluetooth devices are not set to pairing mode by default. Therefore, refer to your Bluetooth device manual for instructions on how to set the device to pairing mode.
Mar 04, 2010 | RIM BlackBerry Storm2 9550 Smartphone
Lg 8700 can not get to pair with any blue toogh device ,my phone has no other devices added
You Need To Type In A 4 Digit PassCode To Get Through To Another BlueTooth Device. Pairing Bluetooth Phones Is Kind Of Complicated. If You Are Pairing 2 Phones... Here Are The Steps:
1.) Find The Other Phone By Searching For It On BlueTooth
2.) Select The Device/Phone You Want To Pair With
3.) Enter The Last 4 Digits Of The Phone Your Trying To Pair With's Phone Number
4.) The Other Phone Should Be Asked If It Wants To Pair With Your Phone, Say Yes
5.) Type In The Last 4 Digits Again Of The Phone Your Trying To Pair With's Phone Number, Except This Time ON The Phone You Are Trying To Pair With
6.) You Should Get A Paired Successful
Pairing With Any Other BlueTooth Enabled Device:
1.) Search Through BlueTooth For The BlueTooth Enabled Device You Want To Pair To
2.) Select The Device You Want To Pair With
3.) Read The Instruction Manual That Came With The BlueTooth Device You Are Trying To Pair With, You Should Find A Pair Key In There Somewhere
4.) Enter The Passkey You Found (OR Already Know) And You Should Be Ready To Go
If All Else Fails, The BlueTooth Is Obviously Broken On Your Phone... Exchange It For A New One
Jan 30, 2010 | LG VX-8700 Cellular Phone
How di I pair my motorola H720 bluetooth to my ,
On the PHONE
Turning on and pairing a Bluetooth device
To turn on and pair a Bluetooth device, perform the following steps:
1. At the Home screen, press the Menu key.
2. Touch Settings.
3. Touch Wireless controls.
4. Touch Bluetooth to select the check-box and turn on Bluetooth.
5. Touch Bluetooth to select the check-box and turn on Bluetooth.
NOTE: The device searches for Bluetooth devices and display a list under Bluetooth devices.
6. Touch the Bluetooth device that you want to connect to.
7. If required, enter the PIN and touch OK. the Pin/passkey: 0000
On Bluetooth headset
Step A - ENSURE HEADSET IS IN PAIRING
MODE
Power on headset by sliding the Power switch
towards the microphone to initiate easy pairing. After a few moments, the indicator
light will be steadily lit in blue to indicate headset is in pairing mode.
Select OK.
Oct 25, 2009 | Apple iPhone 3G
How can i set the em227pk bluetooth up for pairing? plz help.
In order to pair a BlackBerry smartphone with a Bluetooth enabled device (e.g. a Bluetooth enabled headset), the Bluetooth enabled device must be in pairing mode. Most Bluetooth enabled devices are not set to pairing mode by default. Refer to your Bluetooth enabled device manual for instructions on how to set the Bluetooth enabled device to pairing mode.
To pair the BlackBerry smartphone with a Bluetooth enabled device, complete the following steps:
1) On the BlackBerry smartphone, click Options > Bluetooth. If you cannot find the Bluetooth option,
2) Open the menu and select Add Device. The Select Device list appears and lists Bluetooth enabled devices that are in range and available to be paired.
Note: Only BlackBerry smartphones enabled with Bluetooth technology that are in range and in pairing mode will appear in the available Select Device list.
3) Select the Bluetooth enabled device with which you are pairing. The Enter passkey dialog appears.
4) Type the passkey to authenticate the Bluetooth enabled device. Most Bluetooth enabled devices contain a hard coded passkey. See your Bluetooth enabled device manual for the passkey.
Note: 0000 is the universal passkey for pairing any Bluetooth enabled device with a BlackBerry smartphone.
Note: Once a Bluetooth enabled device is paired, it appears in the Paired Devices list. The Bluetooth enabled device will no longer appear in the Select Device list.
Bluetooth devices are manufacturer specific. Please refer user manual for instructions on how to pair with other devices.
Oct 24, 2009 | RIM BlackBerry Storm 9530 Smartphone
Help pairing my H12 bluetooth
I successfully paired my bluetooth by going into the connection phase, just using my common sense on what to do next once I turned the bluetooth on. Since it was not paired to anything, it automatically went into pairing mode. Thanks anyway!
Dec 29, 2008 | Motorola Mobility Motopure H12 Bluetooth...
Radio Communications Logo
53 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
