Question about Jamo DVD-593 DVD Player
Door won't open
Put in dvd and it would not play. went to open and it is stuck. just nakes a quick buzzing noise when i hit open and close, but nothing happens
  • 515 Answers
Usually, the gears either become misaligned, or they will break on you - since they are plastic, this is a common issue. There really isn't much you can do. Even opening it up might not do much for you, as it's very hard to get the gears back into place, or to see what is causing the jam in the first place. If you take it to a service center, they shouldn't charge you much if the gears are out of whack. But if something is broken inside, that's a different story. You'll need to find out what caused the error in the first place.
Posted on Nov 14, 2007
It won't play for one of two reasons:
1. There is something inside the DVD player, which keeps it from playing.
2. The DVD player's battery has run out of juice and can no longer play, meaning the player needs to be replaced.
Aug 06, 2012 | Curtis Sylvania SDVD7037 7-Inch Portable...
Zenith dvd/vcr model ABV341 DVD WON'T STAY IN TO PLAY...VCR WORKD FINE
If the door does not close either something ( a coin or anything) got inside or there is a issue with the mechanism= alignment or possible bad part in that mechanism that loads and positions the disc.
A suggestion when door opens try to take a quick look inside with a flashlight to see what you can.
Apr 04, 2012 | Zenith Televison & Video
Disc door won't open. DVD in will still play. How can we make the door open
try to re start the power first to reset the supply in which the door unable to open and then push the open/close button to open the door. if still won't open maybe their is an stuck up at mechanical part, so turn off the player then use a Phillip screw driver to loosen the screws and to remove the cover of the DVD player .you can now access the disc mechanical assembly of your DVD player, remove the CD first and then check if the plastic gear is mis aligned or the the drive belt is broken.much better if you can apply silicon grease in plastic gear for smooth operation.then make sure the open/close button is ok, good luck and good day.
May 03, 2011 | LG Televison & Video
I apologize for the silly email address. My problem concerns the xbox 360 and the "open tray" error. I would like to add that I am an intelligent individual and not just some child pounding on...
well if its getting stuck its a physical problem which is not generally fixable without having someone be able to look at it and diagnosing the problem not to mention you opened it up and prolonged the problem which can be a worse (my ex: 360 red ring towel trick) sorry i could not be of more help but you should get it looked at
Jan 15, 2011 | Microsoft Xbox 360 Console
My dryer makes a buzzing noise when I push the start button
My Hotpoint dryer is seven years old and did the exact same thing. When I got over the anger and the thought of spending 4 or 5 hundred dollars to replace it I started messing with it. I finally decided that since it buzzed when I tried to start it there was current there. The only other thing it could be was the drying cycle knob.
I held the start knob and let it buzz while I slowly turned the dryer cycle knob to the right. As I turned through each cycle it would hit "off" and the buzzing would stop and then resume as I moved past the "off " setting. On the third trip around the dryer "started" and has been working since. Maybe something got out of kilter. Apparently the problem was in the knob that controls the drying cycles.
Mar 24, 2009 | Hotpoint NVL333EY Electric Dryer
DVD Eject tray stuck
I took a stake knife from the kitchen and pried open the tray door as I hit the eject button this got it to open, I then cycled eject and close, eject close a few times and this did the trick, I even played a DVD and that worked fine also. I had the problem with the tray not opening, and the display would read OPEN when I hit eject and I could hear it trying to open. So I wanted to make sure the tray wasn't just stuck or wedged before I took the system apart and looked for sripped out plastic gears or the belt being broken. GoodLuck
Aug 24, 2008 | Zenith XBS344 System
Buzzing noise when pressing start button
does the buzzing noise sound more like a hum, if so could be a bad motor or possibly something stuck in blower wheel.
Jan 05, 2008 | Dryers
DVD stuck in my Panisonic VCR/DVD Combo
try unplugging the power, plug back in, quickly hit the eject button.  You might be able to get it to eject that way.
Oct 14, 2007 | Televison & Video
Durabrand pdv-702
changes are good that there is a disc stuck in the dvd player
Aug 24, 2007 | Durabrand PDV-705 Portable DVD Player
Jamo DVD-593 DVD Player Logo
127 people viewed this question
Top Jamo Televison & Video Experts
Greg Cann
Greg Cann
Adorjani Laszlo
Are you a Jamo Televison and Video Expert? Answer questions, earn points and help others
