Question about KitchenAid KGSS907SSS Gas Kitchen Range
Back left burner does not lite There is a spark, the gas come out but it wont turn on
  • KitchenAid Master
  • 2,160 Answers
Can you light it with a match?
Posted on Apr 07, 2015
    Champion:
  • KitchenAid Expert
  • 220 Answers
Call for service based on model# this unit cannot be that old as a tech have seen alignment problems with the ignitor causing it not to light usually on the triple burner problem could be the ignitor the ignitor wire or spark module that module averages appx. 200.00
Why wont the left and right burners lite using the electric ignitor?
Are the igniters for those burners sparking?
Aug 29, 2014 | Grilling
Kenmore gas range when no clicking when turning the oven on
Get FREE Standard Shipping on orders of $100 or more. Details
Range: Gas burner won't spark or ignite A surface burner igniter switch and a spark module activate the spark electrode when a burner is turned to the "Lite" position on a gas range's cooktop. If the surface burner switch, spark module or wiring in that circuit fails, the spark electrode won't work, and as a result the gas burner won't light. If those components work but the electrode won't spark, the problem could be that the spark electrode is coated with spilled food of is bent or broken. In addition, the electrode won't spark or ignite the burner properly if the ceramic insulation sleeve below the tip of the electrode is cracked or broken. If the gas burner isn't lighting, these repairs may help.
Range 101
See all articles These repairs may help solve your problem:
Replace the spark igniter electrode
1396454293470.jpg The spark igniter electrode-also called the surface burner igniter-is an insulated electrode that provides an ignition spark to light a surface gas burner. It sparks and makes a ticking sound when the burner switch is turned to the Lite position. Replace the spark ignition electrode if it fails to spark or if the ceramic insulation sleeve is cracked or chipped. How to Replace a Spark Igniter Electrode in a Gas Range Find This Part
Replace the surface spark module
1377098014986.jpg The surface spark module is in the ignition circuit for the gas surface burners. When a surface burner control knob is turned to the "Lite" position, it provides voltage to the spark electrodes on the gas surface burners. If the surface spark module fails to provide the electrodes with voltage, then it should be replaced. Find This Part
Replace the spark igniter switch
1396454315355.jpg The igniter switch is an electrical switch on the stem of the gas surface burner control valve. This switch completes a circuit to the surface burner spark module, causing the burner igniters to spark when the burner switch is turned to the Lite position. Replace the burner igniter switch if the burners don't spark when you turn the burner control knob to the Lite position or if igniters spark constantly even when the burner knobs are in the Off position.
May 27, 2014 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Burners will not light
Hello bdrillbit - Is the electronic igniter aligned properly? Ensure that tip of spark igniter is aligned with metal point or "nib" located on underside of burner cap after the burner mounting screws have been tightened. (Not all burners having mounting screws). When the burner control knob is set to the "LITE" position do the igniters spark? Can gas be heard or smelled coming from the burners when the control number is turned on? However, if you smell gas, I highly recommend turning the unit and the gas off if you can reach it and contact your gas provider. The range itself does not have a switch or regulator to relight it. Keep in mind that it may be experiencing an issue with the spark module, electrodes, wiring or EOC.
Feb 12, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Sears Kenmore gas stove, the front left and the left and right rear burners turn on when the knob is turned to the lite position. The right front burner doesn't turn on when put lite position. N
If there is no clicking sound like you hear when you turn on the other burners than I'm going to say that either the electrode is bad or the spark switch, which is what you turn to turn on the burner to begin with. Both parts are cheap so it may be a good maintenance thing to change all of the burners. Make sure you have your model and go to www.repairclinic.com and order both parts, and if you don't need one send it back for a full refund even if you installed it. good luck
Apr 29, 2012 | Kitchen Ranges
My Viking Range top has 4 burners and the automatic ignition on the left two burners do not wok. Can hear clicks and gas but no ignition. Can manually lite them. Any ideas?
Sorry to read about your problem, I hope this helps you out.
your lite tube may be clogged, or take a needle and clean the hole's next to the lite tube on the range grills..
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 19, 2010 | Viking Cooktops
I have a Kitchenaid superba gas range slide in, model #KGST307HBS9. The nob of one burner, only, the left rear, will initiate the electronic spark that will light burners. When that nob is turned to...
Pull out the bottom drawer and you will find the spark module. I strongly suspect it is weak. Here is a video that shows operation:
This one shows the module on the backside but I looke dup yours and it is below in the backside of the bottom drawer. Ok here is what i think The igniters could be dirty and I have a video showing how to check that plus another video to show how to remove those pesky switches on the top burners and spark module operation.
TOP BURNER SPARK IGNITION
SEALED BURNER SCREWUP
Jan 02, 2010 | Kitchen Ranges
Dead burner on kitchenaid gas cooktop?
it is strange that you have no gas and no spark! if you held a match to the burner and turned the burner valve on it would lite di spite a failed ignitor,but for it not to lite, the burner valve[its what the knob attaches too] would have to be blocked[thats rare]or ........i got it .....the knob is broken.thats the only thing the burner valve and the spark ignitor have in common.try a knob from another burner................again.you have spark,because others are working.spark on troubled burner would work if valve blocked at orifice outlet,and if spark failed you would still get gas they work independent of each other,[but in unison].thats why im thinking knob.its the item that works both .when you turn the knob it opens the gas valve and as the gas valve rotates by turning the knob it activates or turns the spark switch so it closes the curcit allowing the electricty to the spark moduel.hey i hope that helps a little. God bless ,tom
Feb 13, 2009 | KitchenAid Cooktops
GE Gas Kitchen sealed burner
I unplugged the wires from each end and re-attached the wires. Stove working great, no more clicking.
Dec 29, 2008 | GE Kitchen Ranges
CONSTANTLY SPARKING
ONCE BURNERS HAVE LITE TURN THE BURNER KNOB BACK THE OPPOSITE WAY A LITTLE BIT AND SEE IF THR IGNITER QUITS SPARKING, HOPE THIS HELPS.
Oct 22, 2008 | Frigidaire FGF316 Gas Kitchen Range
All burners won't ignite when knob turn to LITE
how lite a eletric gas oven when power lite dont work
Jul 03, 2007 | Whirlpool GLT3014 Gas Cooktop
KitchenAid KGSS907SSS Gas Kitchen Range Logo
60 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
