Question about Uniden BC340CRS 100-Channel Clock Radio Scanner One Size
Can i listen to rr channels - Uniden BC340CRS 100-Channel Clock Radio Scanner One Size
  • 2,760 Answers
Well maybe , it depends on what rail road your near , some use a new trunking radio system and unless you've got 20 scanners going your never hear the whole conversation (google how trunking radios work to see why) but in most cases the block controllers talk to the trains via radio that can easy be scanned to find the frequency , now the block controllers talk to one another via a land based data line so you'll never hear them talk to one another as they hand off a train to another block
also if your close enough to a mains yard you'll hear the switchmen and the drivers converse as well but you gotta be close as there radios are low power so don't go very far (1 mile maybe)
Posted on Oct 23, 2015
I bought a set of 2 way radios to keep touch with hiking partners. I've never used 2 way radios before and I'm clue,es as to how they function
If you tell us make and model, you may get a better answer. The instructions may have a better answer too.
Basically:
  1. Charge or put in batteries.
  2. Turn both radios on.
  3. Turn the volume up.
  4. Tune both radios to the same channel. Pick a channel that is quiet. Quiet means very little chatter and very little white noise. You can make a channel more quiet by increasing squelch but increasing squelch decreases range.
  5. Both radios are now listening.
  6. When you want to talk, press the talk button and say what you want to say.
  7. Remember you are just talking to anyone listening on that channel, so be nice.
Sep 03, 2015 | Radio Communications
Subwoofer
go to audio set up and configure the system for 5.1 or higher sound output.then only all the speakers ll work
Jan 03, 2008 | Yamaha RX-V640 6.1 Channels Receiver
STR-DE835. White noise coming ferom right rear speaker when DVDs are played. Twise the word "PROTECT" has been displayed.
IF any other source plays fine with the RR speaker, and IF it only happens with the DVD player and IF you're using the 5.1 analog audio feeds to the STR, maybe the audio on that channel is **** from the player. You could prove that by temporarily swapping the RR input from the DVD to any other channel input and test it at a medium level.
If it stays with the DVD RR output, the player or the cable would be suspect. Swap in a different cable and make sure it is not routed uniquely near any sources of magnetic fields, motors, UV or track lights, etc.
If you're using digital input all that advice was a waste of time to create as there is nothing external to the chipset that could affect one input channel. Try a different digital input on the STR.
Jan 30, 2011 | Sony STR-DE835 Receiver
How to listen to music in 1 channel and listen to another channel in the phone jack
I'm not entirely sure what you are trying to do here. Using the left/right panning capability, you can send one mix to the left output and another to the right. You can use the "pre-fade listen" to hear a channel in the headphones without effecting the output.
If you can explain in more detail what you are trying to do, I shoud be able to describe how to do it.
Dan
Jan 11, 2010 | Mackie 1202vlz3 12 Channel Mixer
No sound from RF & RR speakers
run new wire to the speakers is what i would do but u have to do it to all due to there possibly being a pre amp in the vehicle.
Oct 24, 2009 | 1999 Dodge Ram
I have a handheld uniden bearcat BC60XL T-1. It got some kind of dampness on it from an air conditioner vent. It worked fine until then. I have removed batteries and let them dry out but still won't...
fire that trunking scanner up,the uniden is damaged,there should be no difference in signals since june 14,they are all still there,just get a new copy of the codes from radio shack,or use an online scanner,http://www.broadcastify.com/listen/?rl=rr
Apr 22, 2017 | Uniden Office Equipment & Supplies
I want to install the recorder panasonic RR-us360 but I don't have the cd to install. Is it possible t make dowlonging of the program?
Panasonic RR-US360 Driver. No driverguide.com registering, no fees, just download the driver. Took from my original CD. Enjoy.http://depositfiles.com/files/beb7hvsnj
Tested for viruses, trojans, spyware - CLEAN. Kaspersky clean.
If you need the software cd image, contact me and i'll upload it for you.
This driver will only let the pc recognise the recorder, but if you need to listen, change, or copy the records, you'll need the software.
Mar 07, 2009 | Panasonic RR-US360 Digital Voice Recorder
Jumping channels
My best guess is that there is a priority channel or channels marked, and it is jumping to that priority channel as soon as someone keys up. Look on your readout for a channel marked with a P. You might have to step thru the channels manually to check them. Hope this helps,,, Mechanic
Oct 21, 2007 | Uniden BC72XLT Handheld Scanner
Uniden BC340CRS 100-Channel Clock Radio Scanner One Size Logo
150 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
AnyMHz.com
AnyMHz.com
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
