Question about Shopnbc Big Boss 7" Seven-Egg Electric Egg Cooker
How do I clean the stainless steel heating plate because of bad water conditions
How to take care of stainless steel sinks?
Here I show you how to care stainless steel sinks:
  • Clean stainless steel at least once a week.
  • Always apply stainless steel cleaner/polish with a nonabrasive cloth or sponge, working with, not across, the grain.
  • Do not use steel wool, wire brushes or abrasive sponge pads. Use only non-scratch cleaning pads.
  • Cleaners containing chloride (bleach) are not recommended. If used, rinse the surface immediately to prevent corrosion.
  • Most stainless steel products will scratch from everyday use. However, these scratches will blend over time to create a unique finish.
  • Do not store open containers of cleaners or chemicals such as acids, bleach, sodium chloride, lye, toilet bowl cleaner, drain cleaner, or hard water stain removal products under your sink.
Cleaning directions listed pertain only to their corresponding material and don't seem to be meant for regulator cleansing. regulator cleansing directions for chrome and vitreous china.
Success with cleaners and procedures depends upon such factors because the hardness and temperature of the water, using exact measurements of ingredients, changes in cleaning formulas and therefore the condition of the merchandise being clean. Since there are variations at intervals these factors, Kohler cannot guarantee the effectiveness of the formulas mentioned.
Allowing water to evaporate on metal will form water deposits. To avoid this and keep your product looking beautiful, it is important to wipe the sink clean with a soft cloth after each use.
Apr 05, 2018 | Home
How do you take care of stainless steel sinks?
Here i show you how to care stainless steel sinks:
Cleaning directions listed pertain only to their corresponding material, and don't seem to be meant for regulator cleansing. regulator cleansing directions for chrome and vitreous china.
Apr 03, 2018 | Home
Plates do not feel smooth stainless steel not shiny
could be the quality of the cleaning detergent you are using, the temperature of the wash water or other factors that you are not mentioning
Aug 09, 2016 | Stainless Dishwashers
Samsung get stuck at 40 minute cycle
I think the dishwasher gets stuck at the point where it is supposed to heat the water. If it can't heat the water (because the heating element isn't working, or because the heater relay inside the controller is bad), then it may stay there indefinately. In other dishwashers, the timer/controller will give up after 3 or 4 hours and finish the cycle. In others, the dishwasher will shut down and indicate an error condition.
Sep 20, 2014 | Samsung 24 in. DB5710DT Stainless Steel...
Samsung dishwasher sprays gunk all over my glasses. When the cycle is over they are coated with dried bits of gunk. Dishes are dirtier than when they went in.
I have the same problem with gunk and spots on dishes. I took apart the parts at bottom covering the heating element. There is all sorts of gunk on everything. I cleaned it all, even under gaskets and filter screen. I am neither sure what caused it nor how to prevent it. My thinking maybe the water source. Water in my town has gotten worse in quality and has bad smell. I use a major water filter system for drinking water. My thought is that the heating element is drying the water up and leaving sediment from water.
Sep 29, 2012 | Samsung DMR57LFS Stainless Steel Builtin...
Clean stainless steel grates with wire brush
wire brush, heat up grill to warm and clean with wire brush. After you get the built up food and grease off remove grates and clean with soap and water to finish the job.
Sep 03, 2009 | Grilling
My Rowenta iron seems to be scortching my white clothes, the plate is stainless steel but seems to look iridescent
if its a light brown appering on the whites, its just to hot, lower setting. also make sure the plate is clean. the stainless changes colour from heat after a while, this is normal
Aug 08, 2009 | Rowenta Professional DM890 Iron with Auto...
F1 ERROR
This is a water heating error.
There are a few possible causes:
  1. Bad heating element
  2. Bad connection of wires to heating element
  3. Bad control board
Be sure that water hookup for dishwasher is hot water.
Unplug electrical connection to unit.
Remove front bottom cover.
Check wires to heating element for burning and that they are connected properly.
You may need a multimeter to check power to element and to help trace the circuit if necessary.
Apr 15, 2009 | Asko D1776 Stainless Steel Built-in...
How to clean stainless steel
You say your new oven...and DW have stains...I will assume (if that's OK) that you have a stainless steel oven...and are washing stainless steel in the DW...but you are having streaks and or white...spots or deposits...Sounds like hard water...you may try a localized..(just for the DW and kitchen sink area) filtration system...to reduce hardness of water...(is this well water)..if so you definitely need filtration...if you don't already have it.
Here are some issues and or cleaning techniques for stainless steel.
stainless steel is known for its ability to be a clean surface that resists corrosion and rust. Dirt, dust and grime, however, put stainless steel at risk for corrosion and rust. Luckily, stainless steel responds well to cleaning, never wearing out from excessive cleaning, as long as certain rules are followed. 1. Water and a cloth.
Routine cleaning can be accomplished by using warm water and a cloth. This is the least risky option For cleaning stainless steel. Dry with a towel or cloth to prevent water spots. Wipe in the directions of the polish lines.
2. Mild detergent, (dish washing liquid) and cloth.
For cleaning that needs more power, mild detergent and warm water can do a great job without damaging the stainless steel. Make sure you rinse the surface thoroughly to prevent staining and spotting. Towel dry to prevent water spots which can be caused by minerals in water.
3. Glass cleaner for fingerprints.
Fingerprints are one of the biggest complaints about stainless steel, but can be taken care by using glass cleaner or household ammonia. Rinse thoroughly and towel dry. There are some newer types of finishes for stainless steel that resist fingerprints, a must if your pint-sized helpers leave their mark on your stainless steel appliances.
4. stainless steel Cleaner.
If you’ve had staining or scratching, or need to polish your stainless steel, a stainless steel cleaner may be a good option. Some of these cleaners and polishes can help minimize scratching and remove stains. They also can polish stainless steel surfaces nicely. Read the directions on the stainless steel cleaner and test in an inconspicuous spot. Be sure to rinse thoroughly and towel dry.
If this does not help please clarify...with specific model #'s and walk me through (step by step) what the specific problem is and how you address it....Thank you and I hope this helps.............
Good Luck...........The Fang.
Mar 06, 2009 | GE Nautilus 24" Built-in Dishwasher
Combi boiler no DHW
if the boiler fires when the tap is opened then the diverter valve is working ok it must be a blocked plate heat exchanger which is the stainless steel rectangular block inside the boiler connected to the pump and the mains cold water.
it will be blocked on the central heating part probably with black scale. it is possible to clean out but sometimes it is better to just change the plate. but remember to flush the system as well or the same thing will happen.
Dec 14, 2008 | Water Heaters
Shopnbc Big Boss 7" Seven-Egg Electric Egg Cooker Logo
455 people viewed this question
Top Shopnbc Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Shopnbc Kitchen Appliances - Other Expert? Answer questions, earn points and help others
