Question about Eureka Whirlwind LiteSpeed 5843 Upright Vacuum
Why does the Eureka 5843 duster does not spin
Can it be easily fixed
Belt
Un plug unit, turn unit over,remove screws on panel covering the belt. ,first start belt on large pulley and then start it on small pulley turn brush by hand to wind the belt on. Google the model number or go to Wal-M and look in their "bags and Belt" book located next to the Vacuum cleaners.
Apr 19, 2014 | Eureka Whirlwind LiteSpeed 5843 Upright...
Eureka lightforce 300 poor suction, power paw doesn't spin and self cleaning duster doesn't clean its self when the button is depressed.
When this happens to me I do two things. The first is to empty the cannister but when you do (with the vacuum unplugged) stick your hand up inside of where the cannister goes.Sometimes that is filled with debris. Pull as much as you can out. There is another part inside there that you can twist and pull out - this will help you pull out more of the trapped debris. Replace that part and the cannister - usually there's a blockage and just removing some of that debris will cause a bunch more to dump in to the cannister. You may have to repeat this process two or 3 times untill no more debris comes out when you turn the vacuum back on.
The second tip solution is to clean the filter which can be found on the front of the vacuum.There's a clear plastic cover, a black rectangular this that hold the filter sponge and inside of that, the filter sponge. I just rinse the little sponge inside and shake off the thing that holds the sponge (Sorry, don't know the technical terms). Put it back together and you should have suction - viola.
Hope this helps.
Oct 28, 2012 | Eureka 4718AVZ LightForce 300 Bagless...
Owners manual
Here's a link to the owners manual for your Eureka 5843 Vacuum:
http://www.eureka.com/service/manuals/71496B.pdf
Please be sure to rate a thumbs up if this was helpful! Thank you.
Oct 08, 2011 | Eureka Whirlwind LiteSpeed 5843 Upright...
The bristles aren't rotating. Is there an easy solution to this?
The belt probably broke. Simply purchase another belt and replace. These belts are made for much stress, and if you've had the vacuum for even a month, they can easily break.
It may also have slipped off the motor shaft, causing the brush to spin freely.
Aug 22, 2010 | Eureka Whirlwind LiteSpeed 5843 Upright...
My Eureka Lite speed whirlwind has a bad odor when it runs.
It is either the filter or on the roller or belt.
  1. Eureka Parts Storewww.Eurekapartstore.com Unbeatable prices on Eureka Parts Largest site for Eureka parts.
  2. Eureka Partswww.ThinkVacuums.com/Eureka Eureka Central Vacuum Accessories Find Hoses, Tools, Nozzles & More! Google Checkout
  3. Eureka Part Storewww.vacuums24x7.com/Eureka-Parts Bags, Belts, Filters, Repair Parts. Complete Selection Eureka Parts.
Jul 06, 2009 | Eureka WhirlWind Litespeed 5844 Upright...
Eureka 5843 belt keeps slipping off of drive spindle.
Tough one. Typically the only 2 things that the belt contacts is the motor drive spindle and the brush roller. Anything else would only be there to protect the belt from debris. Can you turn the brush by hand and see why the belt is coming off? Is the spindle wobbly? If so, you may need another motor as I don't think it is easy to get parts for the motor. Hope this helps and good luck!
Mar 22, 2009 | Eureka Whirlwind LiteSpeed 5843 Upright...
Eureka 2971 vacuum
The duster on this unit is just that a duster the holder for it is to vacuum it off when your not using it it doesn't have anything to do with the vacuum cleaner really. As for the power pawl it is a air driven upholstery nozzle the suction air passes through a turbine which in turn spins the brush agitating whatever it is your cleaning ie. sofa,steps. Simply attach it to the end of the hose and your off just be sure to try and clean any hair or debris for the unit it will not work if the air flow is cut off. For any questions or parts for this unit or any other visit www.stevessewandvac.com
Jul 30, 2008 | Eureka 2971AV EZ Kleen Bagless Upright...
Telescopic duster
Just pull straight up. They're a bit stubborn at first, but there's no real lock or anything in there, so trying to get it to release by twisting or pushing on anything won't help. (I know this because I spent quite some time not wanting to break a customer's duster, so I wasn't willing to just yank, and was coming up with all kinds of crazy theories on how to release it. But yeah, just yank.)
-R
Jun 22, 2008 | Eureka 2971AV EZ Kleen Bagless Upright...
Eureka Whirlwind LiteSpeed 5843 Upright Vacuum Logo
51 people viewed this question
Top Eureka Vacuums Experts
JoeVacs
Irene Tulloch
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
