Question about Exercise & Fitness
What does an error code E7 on a trojan stamina 310
It switches of a few seconds after switching on and gives E7 error. the belt does not turn at all.
5 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: How to bypass the incline motor set up on the Trojan stamina treadmill
Dear Sir:
Adjust the sensor speed and clean see diagram
After that RUN the software calibration for easy diagnose and troubleshooting.
See my personal TIPS for diagnose and Help.
Do not Bypass any motor this machine is very advance electronic computer system. IF you do it, only will complicate the system and damaged.
sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a.
Posted on Mar 10, 2012
ercupa190
  • 12223 Answers
SOURCE: The treadmill gives a E7 error message and the belt is not moving.
this error has 2 options:
1) The display board see the diagram attached,adjust the reed switch , clean and tigh the wires connector.
2) The elevation motor problem a) adjust the potentiomenter b) lube the gear and shaft c) test the motor if need replace or repair.
try to run the software calibratin for diagnose, troubleshooting.
Posted on May 08, 2012
ercupa190
  • 12223 Answers
SOURCE: Treadmill KETTLER PACER have error E7 when starting run. How to eliminate it?
see the following indications and fix it. God bless you
ERROR CODE # 7
E7- 1) Alternative Elevation Motor
1)Cause: Elevation Motor not moving Solution:Check Elevation Motor connection
2)Cause: Elevation Elevation Motor screw binding Solution: Clean screw and lubricate
3)Cause: Elevation Motor Motor out of Range Solution: Check motor out of elevation
4)Cause: E-Motor Potentiometer: Solution: Replace Elevation Motor
2)Alternative:
Display Doesn't Light Up: a)Cause: On/Off switch Solution: Test unit is turned on b)Cause: Insufficient Power Source Solution: Plug dedicated120V, 20Amp Outlet
c) Cause: Line Cord Damaged Solution: Replace Line Cord
d)Cause: Fuse Solution: Check Fuse on MCB
Posted on Nov 28, 2012
ercupa190
  • 12223 Answers
SOURCE: error code e7 on trojen staminia 310 - already tried switching off and on again
see the next steps. God bless you
ERROR CODE # 7
2)Alternative:
Posted on Nov 29, 2012
I have a tunturi t40 treadmill an error code e7 appears And it cuts out after 5 seconds have tried to calibrate the elevation motor but it won't stay at 9 mm gap when it powers up the gap closes
please test the 2 alternatives for error 7. God bless you
see the diagram attached.
ERROR CODE # 7
2)Alternative:
Jan 08, 2013 | Tunturi T40 Folding Treadmill
ERROR CODE # 7
2)Alternative:
Nov 28, 2012 | Kettler treadmill Pacer
Error code e7 on trojen staminia 310 - already tried switching off and on again. I washed machine and mistakenly got the motor wet.
ERROR CODE # 7
2)Alternative:
Nov 16, 2012 | Exercise & Fitness
Error Code E7
To fix the error you have to put the safety key in start it it and wait for it to say E7. Now press stop and incline( up) together and hold for 20 seconds. Your treadmill will start to incline up. Take out your safety key. You just restarted your treadmill and can now put the safety key back and your problem will be fixed.
Apr 22, 2012 | Exercise & Fitness
Dear Sir:
ernesto cuadra
Mar 05, 2012 | Exercise & Fitness
E7 problem
E7 codes deal with the optical scanner unit and or the laser unit. It could also be the lamp in the scanner unit. The E7 is the main code. There is a sub code associated with it. To view the sub code hold down the start button. Below is a list of specific codes and their meanings:
E7-02: LSU trouble
E7-10: Shading trouble (Black Correction)
E7-11: Shading trouble (White Correction)
E7-12: Shading Trouble
E7-16: Abnormal laser output
If it is a laser (LSU) issue then the LSU may need replacing.
If it is a shading error the first step is to remove the platen glass carefully (with the power off because the inverter board). There is a thin white strip on the bottom side of the platen next to the slit glass. Clean this white strip with a soft cloth and a small amout of isopropyl alcohol.
Dust on the optics can also cause shading reference errors so gently blow off the mirrors with canned air.
Perform the following key procedure to reset error:
"#" key, Interrupt key, "C" key, Interrupt key
"1" key, "4"key
Start key, "CA" key.
See if unit cycles and comes back up. If not turn off and then back on the main power.
If error reappears on site technical service may be required.
Jan 06, 2008 | Sharp AR-5316 Advanced Digital Imager...
Exercise & Fitness Logo
134 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
