Question about Starbucks Coffee Makers & Espresso Machines
This is the part of my el60 Starbucks coffee grinder that I was able to pry out but can't get it back in. Any suggestions?
    Top Expert:
  • Starbucks Master
  • 51,186 Answers
Sure buy a new machine .
Posted on Apr 06, 2015
  • Dianne Greene
    Dianne Greene Apr 06, 2015
    Yes, of course, have thought of that but trying not to add to landfill waste. Thanks though!
5 Suggested Answers
JohnnyBeans
  • 223 Answers
SOURCE: Grinder reassembly
Email me your email address and I will send you a pdf of the grinder cleaning instructions that will explain how to align your grinder.
Email: support@cerinicoffee.com
Johnny
Posted on Oct 12, 2007
  • 1089 Answers
SOURCE: i plug in my starbucks coffee machine and it blows th circuit
Hi
If it is blowing the circuit breaker, you have a reputured heating element.
Posted on Jan 06, 2010
espressonist
  • 1711 Answers
SOURCE: Our Starbucks Italia Digital just stopped working
You can follow the instruction on the following like how to clean your grinder.
http://www.fixya.com/support/r5572092-saeco_italia_automatic_espresso_coffee
Good Luck and thank for your vote
Posted on Aug 12, 2010
  • 11800 Answers
SOURCE: WATER WAS POURED IN THE
The grinder is completely clogged with crushed coffee beans that have been clumped together by the humidity - the teeth on the rollers that were supposed to grab and smash the beans are filled and the new beans just jump around.
All you can do is to dry the mechanism with a hair dryer and then clean the teeth with a long needle. Ideally the entire mechanism will have to be removed from the unit and dried and cleaned thoroughly.
Posted on May 24, 2011
Need replacement part for Starbucks Barista Blade Grinder! Please help? Went to grind as I usually do but there is apparently a plastic circular part under the blades (I imagine that keeps the blades in...
your best bet is probably to search ebay for a dead one you can strip, cheaper grinders tend not to be supported with parts, personally id recommended throwing it away and getting a better grinder, blade grinders do not give a consistent grind, they are just about acceptable for grinding for a french press but anything else youll be far better off with a burr grinder
May 10, 2011 | Starbucks Barista® Blade Grinder
I took my Starbucks Barista Conical Burr Grinder apart to clean it, and now I cannot seem to get the top burr back on. This is an old model, purchased in 2000, and has been running great. I used to manage...
I think when you fix the front burr then you need to loose the middle screw. Then it will fix easily.
But don't run it right away.gently tighten the screw and tight until you feel some tightness .Then start the grinder and tighten or loose it according to your grinding specification
thanks
please rate me
Apr 02, 2011 | Starbucks Barista Burr Grinder
Starbucks barista burr grinder: the motor runs but the beans won't grind
The drive mechanism from the motor to the burrs has failed in some way. It is necessary to disassemble the machine down to the basic components to determine the fault. Good luck!
Apr 06, 2010 | Starbucks Barista Burr Grinder
My Barista Burr Coffee Grinder suddenly grinds too fine.
If it is any consolation, mine just did the same thing, now takes too long to grind and it is way to fine dispite a thorough cleaning by disassembly.
Jun 07, 2009 | Starbucks Barista Burr Grinder
Non-working Starbuck's Barista burr grinder.
Hi
Remove bean hopper
Remove grounds hopper
Remove timer knob on the side
Turn the grinder upside down
There are 4 slits on the outside edge.
Insert a screw driver into the **** and pry gently outward with a
little downward pressure on the outside until the side slips a bit.
Repeat on all 4 slits and the shell should slide off.
There is a fuse on the side of the motor that will blow and stop the motor. It is a thermal fuse and should be replaced by a qualified tech.
The thermal fuse is to protect the motor its a 104C
May 12, 2009 | Starbucks Barista Burr Grinder
Starbucks Barista Burr Grinder (Solis 166) motor does not run
Hi
Remove bean hopper
Dec 21, 2008 | Solis Maestro Electric Burr Grinder
Does not grind
Sorry no answer ...i have similar problem described
Mine... sounds like it is working but nothing grinds. Any suggestion no this issue
May 14, 2008 | Starbucks Barista Burr Grinder
Coffee Makers & Espresso Machines Logo
65 people viewed this question
Top Starbucks Coffee Makers & Espresso Machines Experts
eyecam
ray gallant
Are you a Starbucks Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
