Question about Toshiba E-studio 281c Copier
What can i do for toshiba 281c is giving me error code c010?
  • 79 Answers
I don't think that's a valid code. Perhaps CD010? In which case there's a problem with the cleaning brushes.
Posted on Apr 06, 2015
ERROR CODE C010 OF TOSHIBA ESTUDIO230
Main motor is not rotating normally. May need to check and clean the belt drive system.
Jul 13, 2016 | Toshiba Office Equipment & Supplies
What can i do for toshiba 281c if it not giving clear copies?
replacing the drum is usually the most effective way of regaining print quality on laser printers with no extra marks on the paper.
Apr 04, 2015 | Toshiba E-studio 281c Copier
Error code c010?
it is main motor problem
Jul 08, 2013 | Toshiba E-STUDIO 450 Copier
Copiers
Not sure what you are looking for here. You are correct c010 is error code for main motor drive. You might check to make sure everything is able to move freely in the paper path. Check for paperclips, staples, crumpled paper anything that would hinder the movement of the components connected to the drive motor. If everything checks out and you can verify the motor is getting power then you are likely looking a replacing either the drive motor itself or the electronics that drives the motor. It may be prudent to have a qualified service person look at it before you spring for the board or motor though. Good luck have a fabulous day.
Dec 06, 2012 | Toshiba e-Studio 350 Copier
Call service c010
Hi and welcome to FixYa.C010 is a motor drive failure or abnormality. Check for a major paper jam in the drum area or any problems with belts or rollers AFTER your remove the drum. Look for any foreign objects in the belts or plastic gearing. The C101 code usually will appear right after the unit reaches operating temps. After checking for any jams and re-installing the drum. Use your manual and perform the motor output test. 03-101 (Motor on) / 151 (motor off) If the motor runs during this test you may need to change the LGC board. You will see this response for almost every Toshiba C010 error here at FixYa.
Thanks for choosing FixYa,
Aug 12, 2012 | Toshiba E-STUDIO 450 Copier
C010
Hi and welcome to FixYa. I am Kelly. C010 is a motor drive failure or abnormality. Check for a major paper jam in the drum area or any problems with belts or rollers AFTER your remove the drum. Look for any foreign objects in the belts or plastic gearing. The C101 code usually will appear right after the unit reaches operating temps. After checking for any jams and re-installing the drum. Use your manual and perform the motor output test. 03-101 (Motor on) / 151 (motor off) If the motor runs during this test you may need to change the LGC board. You will see this response for almost every Toshiba C010 error here at FixYa.
Kelly
Nov 04, 2010 | Toshiba E-STUDIO 450 Copier
Que significa el error C010 en toshiba est 280 por favor alguien se lo sabe, gracias i.b
C010 indicates main motor is abnormal.
Is the main motor working? (Perform the output check in the test mode: 03-101/151)
If main motor working, check the feeder's clutch, whether it is hard.
Oct 23, 2010 | Toshiba e-Studio 350 Copier
Call service
error code c010.
What can i do now? Please send me a soliation.
Mar 06, 2010 | Toshiba e-Studio 350 Copier
My Toshiba e-studio 3511 gives me a C010 error, what does that mean??
C010 indicates main motor abnormality.
U need to perform output check 03-101(ON)/151(OFF) to off the main motor. If main motor not running under output test, probably u need to replace it.
If motor working, u might need change the LGC board.
Jun 24, 2009 | Toshiba E-Studio 3511 Color Copier
Toshiba E-studio 281c Copier Logo
112 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
