Question about GE Monogram ZE2160SF Convection / Microwave Oven
Opening the door tripped breaker a few times, now microwave will not power on.
We have had this microwave 5 years now. The door being opened started tripping the breaker last week. This happened a few times, now the microwave will not power on even after resetting the breaker. I've got the security TORX bits and plan on opening this up tonight. I'm guessing I'll need a new fuse and one of the door switches. Any advise on how to diagnose which one? Thanks!
  • GE Expert
  • 220 Answers
Sounds like a bad switch should have three primary, secondary, and monitor switch after 5 years change all 3 they are not the same primary and secondary are NO ( normally open ) and the monitor NC ( normally closed ) unit will not come on the fuse on the filter board is blow this usually shorts out the filter board change the switches first and replace fuse may not have to replace filter board hopes this helps.
Posted on Apr 07, 2015
How can I stop my G9115SL microwave from tripping my circuit breaker?
I run into this problem when people are running their microwave off a 15amp line. Especially if it is sharing the line with another appliance like a refrigerator or large over head light or in my wife's case...the vacuum cleaner. Step one is to count the amps on the line. Step 2 is to replace the breaker. They do go bad but not often. Good luck.
Mar 27, 2015 | Emerson MWG9111SL Microwave Oven With...
We have a GE Profile microwave and every time we open the door it trips the breaker. We turn the breaker back on and use the microwave and as soon as the food is done cooking and we open the door - bam,...
For a breaker to trip, you have to have an over voltage condition that is usually referred to as a short. Since your unit works in the cook cycle and only trips the circuit breaker when you open the door the short has to be in the door latch switch or reset circuit. So it wouldn't be that hard to repair, but since it is 7 years old and not the most energy efficient unit, if you aren't able do the repair yourself, then I would replace it!
You can get an idea of how hard the repair would be by going to the web site and putting in the model # off the ID TAG. Then look for the door latch assembly and that will give you an idea of the cost of the parts and get an idea of how hard it is to replace.
Aug 07, 2011 | Microwave Ovens
Advantium 120 blew breaker when door was closed. I reset breaker and it worked for three weeks. Breaker is blown again...when i open the door and reset breaker it works, but as soon as you close the door...
I'd suspect the interlock monitor switch is stuck, or its mounting bracket is out of adjustment. This is designed to blow the fuse if you try to run the oven while the door is open. The switch is supposed to open when you close the door. This switch is replaceable, but you should have this oven repaired by a professional. There are lethal voltages present with the cover off, and the possibility of microwave leakage is the repairs aren't done correctly.
Mar 20, 2010 | GE Advantium SCA1001SS Convection /...
Smeg Microwave SA-971C2
the door protection circuit needs attention, the door catches operate microswitches, but there is also a third which is a crowbar microswitch. if all three do not operate in the correct sequence then the safety switch or fuse will go.
Feb 18, 2009 | Smeg FMC24 850 Watts Convection /...
Microwave fuse mystery
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
We're happy to help and we appreciate your thoughtful rating of our answer.
May 28, 2008 | Microwave Ovens
Breaker tripping
Make sure it is plugged into a 20 amp circuit. If it is in a kitchen it should be a 20amp breaker if it trips a 20 amp breaker it needs to be replaced. If it is a new house and you plug it in in the kitchen and it trips a 15 amp breaker then the house does not meet code. ref Article 210.52(B)(1) NEC
Jan 18, 2008 | Emerson MW8107WA Microwave Oven
Tripping of circuit breaker
Check what other appliances are on your circuit. What goes off when the breaker is tripped. You may need to relocate the microwave to a different circuit. Try to stay away from the refrigerator or AC circuits.
Nov 03, 2007 | GE JVM1440 Microwave Oven
Microwave blows fuse
The most common suspects are the high voltage transformer and the magnetron. It's also possible you have a flaky door switch or loose door switch mount. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: You can find helpful exploded view diagrams and order parts by entering your model number here:
Jun 07, 2007 | Roper MHE14XKB Microwave Oven
GE Monogram ZE2160SF Convection / Microwave Oven Logo
387 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
