Question about LG Washing Machines
I have a lg turbo drum, fuzzy logic 13,0kg. When i start the washing program, it s not retaining the water when its trying to fill it up
    Genius:
  • LG Master
  • 1,585 Answers
Presour switch?
Posted on Apr 12, 2015
heatman101
  • 43501 Answers
SOURCE: LG Top Loader Fuzzy Logic 5.5. The water
No you just need to get the drain hose up higher...the water is siphoning out and is either caused by the end of the drain hose still in water and not having an air gap or the hose is not going up higher then the top of your washer...
Lifting the hose up should give you an air gap and get the hose high enough to stop the siphoning...
heatman101
Posted on Apr 28, 2010
Testimonial: "I am extremely impressed that this won't cost a call out service fee. . . and looking like a bimbo. thanks, heatman!"
Dissolu
  • 221 Answers
SOURCE: I have an LG Fuzzy Logic top loader. it keeps draining water out
If it's really as you described, when draining at the same time filling up, then it's a problem in the main control board. You'll need some electronics knowledge to repair it, or just replace the main board
Posted on Aug 07, 2009
  • 11 Answers
SOURCE: Bowl keeps slowly filling with water when turned off.
I think your water valve is bad , change it
Posted on Aug 12, 2009
  • 257 Answers
SOURCE: LG 8kg Fuzzy logic top
Assuming the water is coming in even when unit is unplugged from wall. You should to replace the water inlet valves where the hoses connect to the machine. You need to unplug the power and remove the top, disconnect the hoses unhook the wire harness plugs, unscrew the hose valve hex nut and remove valve. Install the new one in reverse order.
Posted on May 16, 2011
areemshaji
SOURCE: how to start a LG fuzzy logic turbo drum washing
the water is going out during the wash? how to solve it ?
Posted on Feb 19, 2012
My LG Fuzzy Logic Turbo Drum 13 Kg Top Loader don't stop taking water at any level and then it overflows. What can be the problem or how can I sort this issue out
there is a pressure valve inside.........look around the drum with lid off.......look for thin pipe from bottom of drum to small unit.........that is the valve switch.........remove pipe blow and suck on the valve switch listern for a click.........no click.......replace the valve switch........
cheers
Nov 24, 2016 | LG Washing Machines
Why my washing machine won't spin? Lg fuzzy logic Turbo 8.5kg
Before the washer can start to spin it needs to drain the water from the drum. By you having to drain the water from the machine indicates that the drain operation is not happening. This in the majority of the cases is a bad drain motor.
Aug 08, 2015 | LG Washing Machines
I have lg fuzzy logic turbo drum 7 kg T6515TDPT01 water input is continous its not stopping
Check the water inlet valve for condition, replace if faulty.
The main control board could also be at fault, but it is not common.
Sep 07, 2014 | LG Washing Machines
Lg fuzzy logic washing machine
Sounds like it's stuck in rinse, try unplugging it for 5 mins then power up turn the selector to normal cycle and start, see what happens. There might be a reset cycle it has to do. Or a programming mode. LG 18002430000 customer service
May 15, 2014 | Washing Machines
Lg fuzzy logic wf t652
Front loader? Coins do get into the baffles. They may be riveted on. I would leave it alone, personally.
Dec 01, 2013 | Washing Machines
I have a LG 15.0kg top loading fuzzy logic washing machine. Machine does not empty water out. What could the problem be?
i have a lg fuzzy logic 15.0kg and on fuzzy mode , it continue to supply water and do not wash clothes
please can anyone help me what can i do .
Oct 26, 2012 | LG Washing Machines
How to start a LG fuzzy logic turbo drum washing machine
Apr 30, 2010 | LG Washing Machines
Aug 07, 2009 | Washing Machines
Washing Machines Logo
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
