Question about Vision Televison & Video
After a few minutes on or as it warms up ,the vision goes all blurry and white lines. identified the both slave and master boards in the back,but do not know which one would I replace to rectify fault
Have supplier of both boards
    Sergeant:
  • 330 Answers
It is not a backlights inverter problem; if you do have vertical lines on screen, it is a defective LCD panel, if it is horizontal lines, it may be defective LCD panel, or defective main digital board.
Posted on Apr 06, 2015
    Genius:
  • 1,181 Answers
If you have the back off and have identified boards in question, after it warms up and starts malfunctioning take either canned air(preferred because it comes out cold) or the blower end of a vacuum cleaner and blow all over one board at a time to see if problem corrects. If cooling of a particular board corrects then that is your bad board. May not be the boards
Blurry at first then when it warms up the distortion goes away
Most of the Toshiba sets of this age had problems with a board inside that gives lines/noise left to right for several minutes and then clears up--as time goes on the warmup takes longer and longer---bad Hyper board with about 10 tiny surface mounted filter caps that dry out.
Part is not available and two options--either have a shop repair it or try it yourself---takes above average skill to remove board and replace all ten caps.
Shops will if they will attempt this usually get over 200 for the repair.
Oct 25, 2012 | Toshiba 50HX81 50" Rear Projection...
Hello, my 55513 tv when turning it on was blurry. after a few minutes it became clear. shut off and came back about 3 hours later and it was blurry again for about 10 minutes. about 10 minutes later it...
in the customer menu select convergence when set acts up---look to see if grid of lines is skewed, see some photos and let me know if your problem anything like this..........
Apr 08, 2012 | Mitsubishi WS-55513 55" Rear Projection...
I have a 2004 Saturn Vue that the slave cylinder went out on. Finally got the part put it back together and have no pedal pressure. I have bled it a few times and still have the same thing as before I...
Close the system,make sure you have no leaks,wipe the lines down.(you are suppose to use a vacuum system).with the master filled have some one pump the clutch 3 times (they may have to help bring it up)hold the clutch and open the slave. fluid should drip. do this 3 time and you will get a pedal.If for some reason you dont get a pedal start with the master cyclinder.
Aug 28, 2011 | Saturn Vue Cars & Trucks
How to replace clutch master cylinder and slave cylinder on 2000 hyundai accent?
Starting with the slave , remove the line going to slave then remove the two bolts holding it to the trany and install new one in reverse order, next is the master, from inside the car dissconnect the linkage arm, this is done by removing the clip pin and sliding arm off pedal pin, next remove the resivor and hose. leave hose on resivor remove from master.next remove line from the master then remove the two bolts holding it to firewall, you may have to remove a few things to get the master out this all depends on if theres cruise and a vac valve in the way but this is easy to do.you will need to remove the resivior also when installing new master, bolt it in and connect the linkage make sure the linkage is adjusted as close to the old one as you can leave the adjusting nut a little loose for know after it all connected leave line off and fill with brake fluid have someone inside to push pedal they may have to pull up so you the hand to push and pull pedal, next put your finger over the hole the line goes in and have them push pedal to floor the fluid will push through your finger, do this a few times but watch the fluid level so it doesnt empty, a few time is good then with pedal up remove finger and install line tight,refill with fluid,then have them pump peal three times and hold down, open bleeder at slave, close bleeder and pump pedal again and hold and open bleeder do this a few times until you have a good pedal you will see the slave push out. test the clutch if it works good tighten adjusting nut, if it grabs to soon or doesnt go into gear then adjust, hope this helps.johnjohn2_65.jpg
Feb 20, 2011 | 2000 Hyundai Elantra
Clutch went to floor and would not come back up. Replaced the master cylinder and now it is leaking where the line goes into the slave cylinder
It is not uncommon to replace both items at the same time. There is no real fix other than doing just that. When you remove the line, inspect the flare for cracks and imperfections. If any are detected, You can cut and reflare the steel line which will take special tools. Usually can be rented/borrowed at local parts stores. If it is rubber, replace the line. When you replace the slave, bleed the same as when you replace the master. Be sure to gravity bleed first, which means: open the bleeder and allow the brake fluid/clutch fluid to drain for a few minutes which will reduce the amount of air and ease in bleeding.
Dec 15, 2010 | Ford F-150 Cars & Trucks
S-10 2002 the clutch pedal sometimes goes all the way down and its hard to shift but then it goes back to normal like if nothing was wrong with the clutch . is there an adjustment i can make on it.
CHECK CLUTCH SLAVE MASTER CYLINDER FLUID IF LOW CHECK FOR FLUID LEAKS AROUND THE LINES FIX. ADD BRAKE FLUID TO SLAVE MASTER CYLINDER.BLEED THE HYDRAULIC CLUTCH SYSTEM.IF FLUID LEVEL OKAY.SLAVE CYLINDER FAULTY OR YOU HAVE BROKEN RELEASE BEARING OR FORK.
Sep 17, 2010 | 1988 Chevrolet S-10
When I turn my TV on it plays just fine for about 10 minutes. Then it goes to black and white. If I turn it off for a few minutes and then turn it back on, the color returns for a few minutes and them goes...
The tube harnesses may be a little loose and when tube warms they short. Try adjusting the wiring harnesses. (Only attempt to do so if you have electronics knowledge.)
Nov 20, 2009 | Philips Magnavox 27MS343S 27" TV
Sticky clutch
slave cyl is sepreate from master cyl you have air in the clutch hydraulic system replace slave and inspect clutch master for leaks on drivers floor board area pull carpet back and make sure to bleed system properly!!!!!!!
Feb 26, 2009 | 1992 Honda Accord
Blue screen of death on a tv??
this could be three differnt things
1. the crt itself could be bad
2.the vertical ic on the crt board
3. the focus pack or focus block
Sep 19, 2007 | Sony KP-53V45 53" Rear Projection...
Televison & Video Logo
43 people viewed this question
Top Vision Televison & Video Experts
D. E. Hev
shaun taylor
Are you a Vision Televison and Video Expert? Answer questions, earn points and help others
