Question about Hoover Washing Machines
Hoover vt716d21 shows e3 code but pump etc is working fine.always stops 8 minutes before the end of sequence
    Genius:
  • Hoover Master
  • 1,585 Answers
Could b on rince hold ????????
Posted on Apr 19, 2015
SOURCE: Hoover CA230 1300 Special Edition Washing Machine
Should you have to use un due force to get the filter undone on the Hoover 1300 special deition washing machine
Posted on Feb 02, 2008
  • 3 Answers
SOURCE: ERROR CODE E3
Here is what it says in Maytag's Technical Info Guide: Machine control is
attempting to drive the
motor but is not seeing any
tach response. Visual
check shows motor is not
moving. (Locked, Hall
Sensor fault)
Here is the web site for the guide:
http://www.servicematters.com/maytag_library/docs/16026736.pdf
Try this: take off the back panel and check the motor connections. Unplug them and look for any corrsion.
Hope this helps.
Posted on Jun 16, 2008
jyackle5
  • 8197 Answers
SOURCE: Code E3
The Machine control is attempting to drive the motor but is not seeing any tachometer response or motor action. It could have a failed tachometer/hall sensor which is part of the motor, failed motor or machine control. It could be a loose wire connection at the motor or at the machine control board. This type of failure will require a technician to diagnose and repair your washer. I recommend calling a service technician.
Posted on Jan 10, 2009
I had the same problem. My husband checked the carbon brushes attached to the motor and ran the machine on spin. The brushes were sparking so he assumed they were worn and replaced them and hey presto machine works fine now. The brushes cost 23.99 and were just bought from a local shop but can be bought online cheaper. Hope this helps solve your problem. Essex
Posted on Apr 08, 2009
BADBOYJAY
  • 264 Answers
SOURCE: Washer stops with 8 minutes to go in the spin
that sounds like brushers on the moter
Posted on Oct 23, 2010
What does e3 code ?
The machine can't drain the water away Should the error code E3 appears it is warning that the machine is not draining. You can easily fix this problem by removing any blockages from the drain pump situated at the front of the machine for easy access.
Apr 10, 2015 | Hoover Washing Machines
Treadmill FN 10282 shows code E3
Try to RUN the software calibration for diagnostic, troubleshooting and fix it.
2( However LUBE the deck belt, very IMPORTANT
3) LUBE the rollers bearing too.
4) Test the input voltage motor, if there are the motor need repair, see my persona TIPS.
5) test the output voltage board, for input voltage motor, if there are NOT the board is faulty. see the block diagram
God bless you
Sep 20, 2012 | Proform Performance 400 Treadmill Exercise...
Hoover nextra washer was showing fault code 3. on inspection i found a ten pence piece in the in hard plastic pipe of the pump. removed blockage and set it to cycle. machine was showing fault code 1. i...
Hoover Nextra fault code 1 actually decodes as 'door interlock/door switch' (???!!)
Fault code 2 states' fill time-out or solenoid valve etc'
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Jun 19, 2011 | Hoover Washing Machines
Mar 08, 2009 | GE S8000E
My hoover dt999 dishwasher shows E3 error code, I've cleaned out all the filters, spray arms etc. I know the heater element is OK so has anyone got any suggestions
hi there dave 2 things i have for you first you cant always go by earthloop reading on heaters you have to do a insulition test to that can afect (PCB) power control board if that is ok you are looking at a new board £100 plus unless you can find one on ebay or maybe i can find 1 for you. i hope this is of sevis to you noffie.........
Apr 08, 2008 | Dishwashers
Error e3
Drain pump probably not working. Put machine on cycle 7 and it should turn on the drain pump straight away. you can hear this near the bottom of the machine. if it is silent hten the pump probably needs replacing. I repaired mine be removing it and then dismantle the magnet from the tube then give it a good clean out.
Feb 03, 2008 | Hoover 24 in. HD97E Free-standing...
Jan 14, 2008 | GE S8000E
Hoover Whisper HD97E
Try checking the water level, and level switch? Is the outlet hose high enough of the floor? If you tip the machine back you should see one or two clear plastic tubes, take one end of these and blow through them and the do it the other way round.
Nov 26, 2007 | Hoover 24 in. DT999 Free-Standing...
Washing Machines Logo
76 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
