Question about Kenmore Refrigerators
Why does the water continue to drip on my Kenmore Model Number 58782891?
  • Kenmore Master
  • 5,323 Answers
Check ur inlet valve may be damaged
Posted on Apr 21, 2015
applianceboy
  • 77 Answers
SOURCE: Water dripping on GE Fridge model TFX24ZR
check your water filter. water preasure is important in the operation of the water valves. if the filter is ok replace the valve. water filter should be changed at least once every year.
Posted on Sep 26, 2007
mark_37388
  • 100 Answers
SOURCE: Need to replace water filter, can't locate where.
Look down at the grill at the bottom of the frig under the freezer door will be a section of the grill the looks like the grill but has a ring around it twist it counter clock wise and the filter will twist out and the grill front slide off the old filter on to the new filter good luck.
Posted on Apr 02, 2009
woodchuck789
  • 4059 Answers
SOURCE: Our Kenmore side by side model number 10653382300
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
Posted on Jan 08, 2010
  • 401 Answers
SOURCE: Water dripping out of water dispenser tube
SOUND LIKE YOU HAVE A BAD INTAKE VALVE. IF THE WATER DRIPS ALL THE TIME.
Posted on Jan 12, 2010
blueextc3221
  • 15935 Answers
SOURCE: kenmore elite model 106.54606300 side by side
It appears your defrost timer has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 30, 2010
I have the Kenmore top-mount 106.76232402 leaking
hi.turn water supply to fridge first.cont drip might be a faulty valve.hope this helps.Ali
Jun 26, 2012 | Kenmore Refrigerators
Our Kenmore side by side model number 10653382300 is having a problem with the water/ice dispenser. The water dispenser continues to drip and I can not get it to stop. How can I fix this problem?
Jan 08, 2010 | Refrigerators
No ice from icemaker model kenmore number of fridge is 106.56152500
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don’t refill with water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Nov 17, 2009 | Kenmore Refrigerators
Water continously drips from somewhere under console into the tub
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Look at the components for the Rear Panel. It could be that your "Inlet Valve" is worn.
See the following for how to remove the cabinet:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131
And a diagram of the console with the inlet valve.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=138
Following is a set of diagnostic troubleshooting tips for top load direct drive washers.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=133
Oct 17, 2009 | Kenmore 24032\24036 Top Load Washer
My Kenmore icemaker seems to be leaking water under the icemaker and it drips and freezes
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
Aug 10, 2009 | Kenmore Refrigerators
The water dispensor is dripping water, what do I need to do to fix this thanks
On back of refrigerator there is a water control valve. One goes to ice maker and the other goes to the water dispenser. Unplug the one that goes to the dispenser and if the water continues to flow then you will need to replace the control valve. If you could find the model number near floor and behind the fresh food section door, I could tell you which part number you need, Let me know what you find, Thanks, Sea Breeze
Jul 18, 2009 | Kenmore Refrigerators
Apr 02, 2009 | Kenmore 57029 Side by Side Refrigerator
Refrigerators Logo
57 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
