Question about Russell Hobbs Marco Pierre White
It is ''locked'' how do i unlock it? - Russell Hobbs Marco Pierre White
  • Anonymous Apr 06, 2015
    Actually it is a Marco Pierre MICROWAVE
Top container doesn't lock anymore. It's only 6 weeks old.
If you mess with it you could void your guarantee so I would advise take it back and use your guarantee.
Jan 31, 2016 | KitchenAid Diamond Vortex 5-Speed Blender,...
Why won't my food processor work? It is assembled correctly and it is still not working
Make sure you didn't trip your breaker to the power source .
Check to make sure when you put your bottom on and lock it that it is hitting the safety switch hope this helps.
Aug 07, 2015 | Cuisinart Smart Power Duet Blender/Food...
How do I unlock my Juicer. It became locked while using it.
When you say it became locked do you mean the motor locked down and it won't spin or do anything ?
Feb 03, 2015 | Breville Juice Fountain Compact Electric...
My single serve won't lock in place so it will not work what can I do? I have only had it for two months
If it is still under warranty. Get a replacement or you will be forever trying to fix it.
Dec 14, 2014 | Blenders
Cup wont lock into place
I am having the same problem and have only been using mine for a week!!
Jan 08, 2014 | Magic Bullet Nutribullet Blender
Samsung unlock code free
You need to specify the Phone's model,Country and current network name to get exact answer . Anyway,You can get unlock code for some old model Samsung phones for free from Unlocking4Free.com .
May 26, 2013 | Morphy Richards Food Fusion Hand Blender...
When ever i insert a sim card. It ask me for restriction code. And now i cannot use the phone since i got it.
If the Phone asks for Restriction code means it locked to network .It's Nokia ? You can get the Restriction code for Nokia Phones from Theunlockspot.com/nokia/rs10wp8/ and unlock it.
Jun 02, 2012 | DeLonghi Blenders
How to change clutch in Hamilton Beach blenders
You need a screwdriver and soft hummer. Secure the screwdriver on one teeth of the cluch and lower the screwdriver to have un angle of around 60 degrees. Now you hit a little fast the scredriver with the hummer in order to unlock and unscrew the clutch. Then it will be easy to unscrew with your fingers. This is a litle bit triky so you may need to try some times in order achieve it.
Please remeber that you it unscrew reverse than it rotates.
The new one need only to screw in place and it will lock by itself as soon as you will use the blender.
Good Luck
Aug 02, 2010 | Hamilton Beach 908 Commercial Work Top...
Filter replacement
Hi and welcome FixYa. I am Kelly.
I have to assume we are talking about a refrigerator. The question listing is under blenders and if so that is one fancy blender.
On most refrigerators the filter is in the lower left side of the floor grill. The will be lable that says press to release. Then you turn the filter cap counter clock wise to unlock the filter. When installing the new filter you must swap the cap from the old filter to the new one then press in hard and turn Clockwise until it locks in place. (see the instruction sheet with the new filter)
Thanks for using FixYa,
Kelly
Apr 24, 2010 | Blenders
Blender base won't unlock
Try calling B&D at 1-800-544-6986 There might be a recall also.
Jul 14, 2007 | Black & Decker BL675 ProBlend Work Top...
Russell Hobbs Marco Pierre White Logo
116 people viewed this question
Top Russell Hobbs Blenders Experts
eyecam
Are you a Russell Hobbs Blender Expert? Answer questions, earn points and help others
