Question about Video Game Consoles & Games
Where can I buy a rubber band for the AKAI DP4006 disk drive?
  • 1,087 Answers
Take one off a donor CD/DVD rom
Posted on Apr 07, 2015
Disk will notcome out
Hi Carol,
This is an educated guess but if your deck is older there are eject mechanisms on them. They are belt driven if they are stretched out or broken the disc will not eject on most of them.
Depending on age the belts which are glorified rubber bands last about 10 years or less then need replacement so my best guess is the drive band for the ejector is in pieces in your deck.
Replacement bands are available on ebay, this is not the only possibly answer to your problem but my best guess from your limited description. Note you cannot replace a broken band with an o ring or rubber band or a similar band as they will not work correctly...
Apr 11, 2014 | Sony CMT-HP7 CD Shelf System
Akai dp4006
make sure the audio output format to optical or coax is set to either pcm(pulse code modulated) or dolby surround 5.1,6.1 7.1 etc. for both dvd and amp........may be in user menu for both......meder's tv service
Nov 10, 2013 | Televison & Video
Where to buy Sony MHC-RG40 rubber band
You just need to measure the diameter of the belt (approx) in MM. Then put "XX MM diameter Drive Belt" into Google. Get the one nearest your measurment.
Dec 17, 2012 | Sony MHC-RG40 CD Shelf System
The CD tray wont open on my xbox 360
Do not attempt this fix ur self if your not familar with the dvd drive parts . The problem is the band on the dvd drive motor under the disc tray is slipping . To fix this use a rubber band. Step 1 Remove your dvd drive unscrew all 4 screws , 2 remove green board carefully . 3 unscrew any screw under the disc tray and remove this disc tray , step 4 get a rubber band a small rubber band and replace the band thats slipping put your dvd drive back together and ur good to go . If you do NOT want to do this your self you can go to Solomodsdotcom and they will fix the dvd drive for you . Google search to to replace rubber band on 360 dvd drive . You tube has videos on how to but i wouldnt recommend doing it your self if your not familiar with the parts .
Aug 07, 2010 | Microsoft Xbox 360 Console
Looks like thin black rubber band broken...I found it after manually opening the door to the stuck drive tray...is this easily replaced?
Fairly easy to do if have the tools to get the case off and have a band the right size. However for the sake of few £/$ you might as just buy a new drive.
Dec 13, 2009 | Optorite (dd0203 blk) DVD±RW Burner
Rubber band for Akai semi automatic turntable APX1 needs replacing. Where can I buy one in NZ?
Are you sure you have an Akai APX1? I've never known Akai to make turntables. I think you mean AIWA - yes, there is a MAJOR difference.
For the Aiwa APX1 model, you can purchase the belt HERE.
- OPTiC
MasterTech
Digital Analog Therapy
Turntable Parts : Turntable Repairs
Aug 31, 2009 | Audio Players & Recorders
Broken drive rubber band
buy a rubber band at the market
Jan 07, 2008 | Audio Players & Recorders
Tray will not open
put the machine in standby mode (ie switch power button on machine or remote) then, press and hold the STOP and CHANNEL UP buttons simultaneously. This will force the disk tray to open.
Apr 28, 2007 | Panasonic DMR-ES10 DVD Recorder
Video Game Consoles & Games Logo
46 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
