Question about Pool & Spa
What does error 1 mean on my winer amc 2210 hot tub
  • 1,631 Answers
Is this one of those Internet hot tubs?
An import from china?
don't know about the fault code, maybe check the owners manual?
As far as the spa, what is it doing or not doing, besides the fault code?
Posted on Apr 16, 2015
Hot tub pump will not start back up after cleaning hot tub
When you say the pump won't start back up, do you mean the electrical side of things and there is just no power going to the pump. Or are you saying that the pump is on but not pumping water.
I am going to think you mean the pump is on but not moving water. This is common after you clean and drain your hot tub. You have what is referred to as an airlock in your hot tub line. It is easy to remove the airlock by simply opening one of the unions near the pump. This will allow the air to release and water flow to begin again.
Make sure also that you have cleaned the hot tub filters, if they are dirty and reduce water flow that could shutdown your hot tub pump as well.
If it is the electrical side of things make sure your GFCI has not tripped and maybe you just need to reset this. If it is anything further on the electrical side make sure you involve a professional.
  • open a union to release any airlocks.
  • clean your hot tub filters.
  • check to make sure your GFCI is not tripped.
Hot Tub Repair 101 What is an E6 or Error 6 Code Mean
You may have to change your hot tub filters as well and can find an assortment of filters here. The filters should be changed yearly, and cleaned monthly.
Hot Tub Filters
Jan 30, 2016 | Pool & Spa
Display shows E, and will not operate
AMC Error Codes
faq.cncroutershop.com/us/amc-support/amc-error-codes/
Error 5 - The system has detected an E-Stop or hit a limit sensor during the running ...Error 33 - Attempt to run a function 3 on a tool that does not have a Z-axis. ... Error52 - AMC did not receive feedback from the drill indicating that it has fired.
[PDF]Troubleshooting Guide - Sargent and Greenleaf
www.sargentandgreenleaf.com/pdf/Trbl_Shtng_Guide.pdf
Apr 1, 2004 - The Sargent & Greenleaf line of electronic combination locks is not ... safe must be opened by drilling, S&G recommends you contact the safe manufacturer first. ... the safe handle turned fully to the locked position, enter the code .... The lock willoperate with this wire broken, but it will not beep and the LED.
Case IH Troubleshooting Support Information
Dec 15, 2015 | Drills
What does code ic mean?
I have not seen an ic error code. I have seen ICE several times. So either you do not have the original pack that came with the spa or your display may be malfunctioning.
What is your hot tub doing while the ic code is pressent?
Portable Hot Tubs and Spas On Sale
Apr 12, 2015 | Dream Maker Spas Dream Maker Ez Spa Hot...
What does error code -0.3 mean on an Aruba Hot tub
Don't think that's an error message? Could be letting you know heat is bypassed for Max setting?
Feb 11, 2015 | Qca Spas Majestic Series Aruba Xl Hot Tub
What does the E6 error mean
Hi Cheyenne,
Most of the time an E6 error code refers to a restriction of water in your power pack. When you don't have enough water flow the power pack shuts itself down so it does not over heat.
Possible reasons are dirty filters, air locks, restrictions of water flow,
Solutions are to make sure your water flow is as best as possible, clean your filters often, remove debris from your hot tub, and remove air locks from your power pack.
Dec 18, 2014 | Jilong Inflatable Hot Tubs: Prompt Set...
Error code 11 lavazza blue
Lavazza LB 2210 error 82/84
Aug 20, 2013 | Lavazza 2210
Does manufacturers of hot tub cover offer warranty?
Some do but most make it very difficult. The two best companies for covers and after sale service is www.costco.com and http://www.hottubworks.com/
Oct 26, 2012 | Qca Spas Dream Series Mystic Hot Tub with...
Will a flow switch stop the tub of any operation
Is the board getting power, is the control lighting up?
Do you see any error codes on the top side control?
Improper flow will give you an error code, caused by flow issues or a faulty flow switch. Make sure all gate valves are open and the water can flow freely.
If not then check your Hi Limit sensor. This is the overheat safety sensor if it fails the tub will not function at all.
Sep 23, 2012 | Dream Maker Spas Dream Maker Ez Spa Hot...
AMC-2070 owner's manual
Same questions over and over again this site has well gone down the pan
Dec 29, 2011 | Cars & Trucks
Pool & Spa Logo
223 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
