Question about JVC HD-52G786 52" Rear Projection HDTV
Chanels locked just brought the tv second hand from a rent a center and the channels are locked and it ask for a code, when don't have a book it is order. How can I unlock the channels
  • janet330 Apr 22, 2008
    Bought a TV at a local yard sale, and can not access cannot acces certain channels without the lock code, because it exceeds certain rating limits
Page 49 of the instruction book tell you how to reset the parental codes. You can go to to download the instruction book. Or call the customer support number listed on the site.
Posted on May 11, 2008
Disables by rent it center need 4 digit pin
Samsung Galaxy S4: Rent A Center Disable Locked it: Need 4 digit code to unlock:
Hello. The unlock code you need is specific to that phone. The only way to get the pin to unlock is from RAC. They have remote locked it. The files for this remote lock are hidden and embedded within the firmware. So, even if you factory reset and wipe the dalvik cache, it will still be locked.
From what I understand.. as time goes by, the debt you owe will be transferred to a Debt Collector and your credit will suffer from the derogatory for seven years
If you really want to use this phone.. There is a way.. You will not be able to use the Samsung firmware software that runs on the phone any more.. but you can wipe all data on it, and put on another ROM firmware, but it will be virgin Android. Meaning basic Android phone options.. See the attached link for instructions to do this:
Reference Link:
rent center locked galaxy s5
Jan 28, 2016 | Samsung GALAXY S4
How do i finde auto chanel seargh
Auto channel search is how your tv finds channels that are available. Under settings in the menu should be initial set up. There you will find channel search.
Feb 20, 2015 | Insignia Televison & Video
Restore to factory setting brought second hand now locked
Since the only option to restore the phone is by using the lock code, you might need to re-install the OS of the phone to break the lock.
Nov 12, 2013 | Cell Phones
Remote code for Sabre TV on Cox Universal Remote
I had the same problem and I found out that the philips universal remote works! What you will do is follow the instructions in the book and your channel will change to the same channel. The instructions are: Hold the select button for about three seconds and click the TV button. After this you will hit the channel button until the channel on the TV appears in the upper right hand corner. After this you will hold the mute button for about 3 seconds and the release. This should work! Hope this helps you out!!!
Mar 31, 2009 | Televison & Video
Need Unlock channels
I called Philips Magnavox at 1 888 744 5477 and they told me the default ACCESS CODE number is 0711. It works on my TV though it didn't solve MY problem of the TV defaulting to Chanel 9 every time I turn it on. Drats. Hope this helps.
Jan 01, 2009 | Philips TP2784C TV
Radio code
ok the only thing you can do is call the dealer with the vin number and they will give you the code ask for service dept
Nov 23, 2008 | 1994 Volvo 850
Parental lock
Child Lock
--Should have original remote. Press and hold the power button for 6 to 10 seconds
Combo Model T25208, V-Chip Forgotten Password
If you forget your password, simultaneously press VOLUME down on the TV/VCR front panel and the 0 number button on the remote for a few seconds. This resets the password and you can enter a new one.
Combo Model 13TVR62, V-Chip Forgotten Password
If you forget your password, press STOP/EJECT on the TV/VCR front panel and MENU on the remote simultaneously. This resets the password, but not the limits you’ve set.
Televisions with Parental Lock Feature
If you forgot your password for this feature, press the following buttons on the remote, one at a time. (Note: You must be in the password entry screen) Press, Mute, Display,Clear and Reset, this unlocks parental controls and you can now re-enter a new password.
Press and hold Menu on the TV AND volume down on the remote for 3 seconds. Nothing will appear on the screen, and the Parental Controls will unlock, and you can re-enter a new password with the LOCK PARENTAL CONTROLS
Channels that have been locked can be viewed only when the PARENTAL CTRL function is set to OFF. This can only be done with the remote control-it can not be changed with the buttons on the front of the TV.
Therefore, after you turn on PARENTAL CTRL, you simply hide the remote control so that your children can not watch the locked channels. The locked-out channels will remain unviewable even if the TV is unplugged or the channels are autoprogrammed again. The only way to view locked channels is to use the supplied remote control to set the PARENTAL CTRL function to OFF.
The PARENTAL CTRL and the CHAN CTRL functions work hand-in-hand. The instructions below will first tell you how to turn parental control on or off with the PARENTAL CTRL function and then how to lock desired channels with the CHAN CTRL function.
1. Repeatedly press MENU to select SETUP MENU, and then press + or - to display setup functions. Repeatedly press MENU to select the PARENTAL CTRL function. . When this function is set to ON, PARENTAL CTRL is activated and any channels you locked with the CHAN CTRL function will not be viewable. . When this function is set to OFF, PARENTAL CTRL is deactivated and all channels are viewable.
2. To lock channels, press the MENU button to select the CHAN CTRL function. Select a channel you want to lock by pressing CHANNEL up or down. Then press +. The CHAN CTRL setting will change from NORMAL to LOCKED when that channel is locked. To return the channel to NORMAL, press the - button. Repeat step 2 for each channel you want to lock. If the PARENTAL CTRL function is set to ON while you are locking out channels, each channel will go blank as you lock it. When the PARENTAL CTRL function is set to ON and a channel which has been locked out is tuned, the TV will display the words PARENTAL CONTROL to let your kids know you have locked it.
If the front panel function buttons don't work, (menu, ch up/dn etc.) but the functions work normal with the remote, enter the "Channel" menu with the remote and turn "Parental Control" off.
In the event you have forgotten your password, perform the following procedure:
Press and hold for 3 seconds the TV button on the remote while pressing the menu button on the TV.
This procedure will turn off the parental lock and erase the previous password .
Another Possibility To Try For Various Models: If TV's in the Parental mode and askes for a password that's forgotten, Press menu on the TV, select Parental Lock #4 on menu, then with the remote press Mute, Display, Clear, and Reset buttons in sequence.
TX808 Chassis
If Parental Controls have been set and you don't know the password, do this:
Press and hold the volume down and the channel up buttons at the same time for 5 seconds.
Now you can reset the password to 0000, and using that password you can now access the V-Chip menus.
TV's (Made by Daewoo or possibly Apex, ie. GE model 24GP653)
The factory default pass code of 6688 is also the override code, in case the owner forgets their pass code. If that doesn't work, another place in the owners manual says to push Function and Mute on the remote at the same time. Function is the top right button.
Mar 26, 2008 | RCA TruFlat 27F520T 27" TV
Panasonic TV TC-19LX50 that is Locked
Ask your part time workers what the code was, then enter it into the television.
Mar 24, 2008 | Panasonic CT-24SX12 24" TV
Locked out, channel or child lock how to re-set
I know one code please try if it helps 1 press mute button once on remote control handset. 2 once again press &HOLD remote hand set mute button. 3 while keeping mute button pressed press menu button on tv set. good luck
Sep 17, 2007 | Toshiba CF36G40 36" TV
JVC HD-52G786 52" Rear Projection HDTV Logo
104 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
