Question about Sentry Fireproof Safe
How to close it with all bars inside up - Sentry Fireproof Safe
    Top Expert:
  • Sentry Master
  • 14,162 Answers
Posted on Jun 23, 2015
What is the parts of windows environment?
This sounds like a "homework" question.
A window has a frame, and controls along the border to move/resize/close the window.
The top-border may have a title-bar, and the bottom-border may have a status area.
There may possibly be scroll-bars, and a movable "thumb", to scroll the contents inside the window.
Jun 26, 2011 | Computers & Internet
A bar in the middle, when two doors are opened, is really hot. and cold storage is not working vey well. please help.
IIRC your refrigerator has an electronic control in the front face of the freezer door. Both sides have 3 buttons in a vertical column. On the left side (standing facing the closed door) the center button is labeled "freeze". Each time you push it the number of horizontal green bars changes. The bars increase in count to the top/maximum, then start over at the bottom with a single bar. This is your freezer setting indicator (the fridge works the same way). The more bars the colder the setting is. Note that if you set the freezer bars too high (IE set the freezer too cold) then the "waterway" heater will come on and stay on to prevent the waterway inside the door itself from freezing up. This heater is wired such that when it comes on so does the "home-bar" (which touches both of the doors when closed) heater, which will also stay on.
Aug 15, 2010 | Samsung RS2530BSH (25 cu ft) Side by Side...
How to install bar ends on a bmx bike
If your grips have closed ends, cut a section off so you have plenty of grip left, but a hole where the bar ends can go through. Follow below procedure with the bar ends.
Bar ends are either have a screw or allen key head. Tap them into the ends of the bars with a rubber mallet. Tighten up the screw/bolt as this will make them expand keeping them inside the bars.
If you need to remove the grips:
Get some hairspray and lift the edge of the handlebar grips up, spray down until the grip is slippy and comes off. (Only use hairspray though, as once it is slippy, it will be very sticky in a minute so it will help when you replace it. Repeat for the other grip. Clean up the bars where the grips were. Refit the grips with more hairspray inside the grip and a little on the bars. Slide them on and leave for a good 6 hours so they stick.
Hope this helps mate, please vote for me :)
Jul 02, 2010 | FEDERAL BMX Bike Grip Red Nylon Bar Ends
Vent Setting for he Haier ESA406J
You push it in to recirculate the air, the reason that you are getting that sound when you open up the vent is because you are sucking air from the outside as well as the inside of the home. Please rate
Jun 04, 2010 | Haier ESA3056 Thru-Wall/Window Air...
2000 pontiac door wont close and latch
not 100%sure what u got going on not seeing it but i think if u look at the inside of the door were the latch hits the bar u will see that its closed causing the bars to hit each other while the door is open take and open the inside handle and take a screwdriver and pull on that bar a bit and it should move down wich will let your door closed if thats not the problem then your door hinge bushing are messed up best bet is to take to a shop to have thiem replaced pretty cheap fix for what u have to do
Mar 21, 2010 | 2000 Pontiac Grand Am GT
Two of the doors won't close after touching the inside of the lock area when unloading
get a pencil or screwdriver and insert it into the door latch behind the lock bar blocking the opening on latch[ on door looks like a sideways " V " ]lift the outside handle and push the latch bar towards inside of car and upward this will set the door latch so u can close it
Mar 05, 2010 | 1998 Volvo S70
The Trunk wont shut and lock
there are a couple of bolts that hold the bar. loosen them and adjust it, and retighten in the right place.
Aug 23, 2009 | 1998 Chevrolet Cavalier
Tailgate latch will not release
Sounds like you have a bar disconnected inside the hatch. You may also need a latch itself. Does it lock and unlock? If it does, most likely a bar off issue. Will be a pain to get the cover off with the door closed, but you will need to remove it to inspect.
May 28, 2009 | 2005 GMC Sierra
Cannot close the back cover back.
when you open the back cover you will seee a metal ber with 4 grey roller on it. There are 2 black plastic bit spanning the rollers (2 each one spnas 2 rollers). these need to be pushed upwards so that the click up (the back of the plastic bits will push past the bar behind as the bar they are on flexes). once you have done this the cover will close. It only took me 2 days to figure it out....
db
Jan 28, 2009 | Samsung CLP 300 Laser Printer
Wii problem: controller or sensor bar
you sensor bar is likely not working write because the wii contrl was going to fast and to close to it at the same time + the impackt must have hurt the main cesor inside of it
hope i helped
chris
Mar 31, 2008 | Nintendo Wii Console
Sentry Fireproof Safe Logo
113 people viewed this question
Top Sentry Home Security Experts
Jim London
Jim London
Computer Repairing
Computer Repairing
Hannah Johnson
Level 1 Expert
Are you a Sentry Home Security Expert? Answer questions, earn points and help others
