Question about Panasonic Kx-tg7731s Dect 6.0 Cordless Phone
How to correct a faulty charger?
On of the chargers does not charge
  • 156 Answers
Faulty charger must be replaced. Repair is not feasible.
Posted on Apr 06, 2015
Afterreplacing house batteries in RV, magnum 2000 shows low battery fault although batteries are charged. Charger seems to work fine.
Are you sure you have batteries wired correctly? They still could be faulty, an have you tried to measure voltage on charger to make sure it's charging. An do you have correct charger for the type of battery your using.?
Jul 18, 2017 | Magnum Cell Phones
Proscan 7044K-C tablet won't charge
Test your charger with a multi-meter, does it output the correct supply? If not you need a new charger.
If your charger is ok, take a look at the charging socket, is it damaged in any way? Does the charger feel loose when it's plugged into the socket? If so you may need to have your charging socket repaired/replaced.
After checking all this the next thing I would try is a new battery. However, most tablets will at least work from main supply, even if the battery is faulty.
Mar 21, 2014 | Tablets & eReaders
Used wrong battery charger
Charge the battery with the correct charger.
If the camera does not work after charging then the camera is faulty.
It maybe cheaper to get a new camera than repairing the Sony Cyber.
Apr 17, 2013 | Sony Cyber-Shot DSC-P150 Digital Camera
I need to find batteries and a charger.
hi, the batteries will not charge correctly if the charger is faulty ? now what is the scooter model ?
regards
Jan 12, 2013 | Health & Beauty
Hi, I have repaired 3 Makita 18V 3Ah Li-Ion batteries recently by removing good cells from other faulty batteries. The Voltages are good now on all 3 and they charge/discharge OK on my own charger but...
Some manufacturers put some chip on their battery so it can be identified by their charger. If you use a generic battery often, it will not charge or work properly. LG does this with their phone batteries! So you have to use another charger to charge them.
Jul 07, 2017 | Makita Drills
My phone won't charge
Hello, when a phone does not charge, it means that the phone charger or the port at which the charger is inserted in the phone is faulty.
Might be due to dust or dirt. You can Clean charging port on the phone with a brush and alcohol to remove dirt.
After cleaning it,if still not charging, you can test charger with another phone to be sure if the charger is working. And if the charger works with another phone,that means the charging port on the phone is faulty and will need to replaced.
Take care.
Sep 14, 2010 | Motorola Mobility RAZR V3
Batteries won't charge
Hi. Sounds like there is a faulty connection somewhere between the charger and the batteries. Are the batteries connected correctly. The charger uses the voltage level in the batteries to regulate itself. If there is a faulty connection, then the charge will not operate. Use a multi-meter to check if the batteries are connected correctly. There should be 24 to 26 volts across both batteries.
This fault can also be caused by a faulty charger socket. Check for any signs of melting or heat damage. There might also be a disconnected wire in the plug on the charger itself.Good luck. Neil.
May 29, 2010 | Drive Medical BLUE 3 Wheel Compact Mini...
I have a golden 3 wheel scooter dose charger
If the charger is working correctly, it should turn itself off automatically (may go into float chrarge depending on type of charger). There should be an LED or an amp meter on the charger to tell you when the charge is complete. When the batteries are charged, you should be able to leave the charger switched on and it should cause no harm UNLESS the charger is faulty, in which case it will continue charging and damage the batteries. You should be able to tell if this is happening as the batteries will become very warm. If the batteries are losing their charge after you have switched the charger off, it is most likely that your batteries need replacing. Failing that, you may have a short somewhere which unfortunately, could be difficult to find.
Mar 10, 2010 | Electric Health & Beauty
Makita dc1804f charger will not charge new i-mh 1834 18v battery
I think your tryiong to charge NIMH batteries oon a charger designed for Lithium Ion batteries. With all the new style batteries such as NICAD, NIMH and LI-ION, charging becomes difficult. Most chargers pre NIMH and LI-ion, were designed for NICAD's. The best advise, match your batteries with the correct charger
Feb 06, 2008 | Makita 18V LXT Lithium - Ion Cordless...
Panasonic Kx-tg7731s Dect 6.0 Cordless Phone Logo
181 people viewed this question
Top Panasonic Lands Phones Experts
john milligan
george  peters
george peters
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
