The error code H 01 in Shows my washing machine(panasonic na-f70gs)
  • 156 Answers
Http://www.ukwhitegoods.co.uk/help/fix-it-yourself/fault-codes/laundry-fault-codes/3328-panasonic-na-series-washing-machine-fault-codes.html
H01
Pressure sensor or level switch detected as out of range
  • Check wiring to level sensor
  • Check pressure switch is not defective
  • Replace pressure sensor
  • Replace main power PCB
Posted on Apr 06, 2015
2 Suggested Answers
richroth
  • 9472 Answers
SOURCE: The error code U12 shows
The "U12" is due to the magnet that is attached at the tip of the lid. the magnet acts as a sensor that give info whether the lid is closed or open. Either the magnet has come off or it is not aligned properly.
Posted on Jul 31, 2011
Why the Panasonic Washing Machines error code "h 02" displaying?
Google "panasonic washing machine error codes"
Jun 11, 2016 | Washing Machines
What is Error Code H44 on Panasonic Washing Machine?
sad to say there is no H 44 listed o the 4 places I looked
Jun 17, 2014 | Washing Machines
Error code h41 on panasonic washing machine model na-168vx2
U11
The washing machine cannot drain
  • Check that filter is not blocked or obstructed
  • Check drain hose is clear of any blockage or obstruction
  • Check wiring to drain pump
  • Check drain pump is not defective
  • Check level sensor or switch
Feb 15, 2011 | Washing Machines
Please I have got error code H 43 on display monitor of Panasonic washing machine model NA-14VX1, If you please may I know what is meaning this code and where is the problem. Thanks in Advance
This is a code for an internal leak. Same happened to us today 2 weeks after buying the machine from John Lewis. We had a small pool of water appear in front of trhe machine. Waiting for Panasonic to sort out a repair.
Feb 05, 2011 | Washing Machines
The water inlet does not stop during the entire cycle of washing in our NA F70GS Panasonic washing Machine. How to solve this problem?
Its simple..just follow step by step as below:-
  1. Switch off and unconnected both power & water supply.
  2. Lay the unit with the back side facing up.
  3. remove the back & bottom panel
  4. you will see the valve on the bottom tub.
  5. Unscrew the valve cap.
  6. Dismantle the valve by release the connector between steel bracket & hook (white plastic 'T' shape) using small 'playar'
  7. Then you will see a 20 cents coin ( keep into your tabung gajah)
  8. Use the old toothbrush to clean the black rubber valve.
  9. Assemble everything.
  10. Thats all.
Sep 06, 2009 | Washing Machines
Got error code u11
u11 is not a valid error code - please recheck.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 12, 2009 | Washing Machines
Panasonic washing machine stops prior to spin cycle
First my washer stopped working during the spin cycle, and some of the water still in the tub,i have to wait for about half an hour to have the whole process done after continuing the washing process,then after 2 weeks not doing any laundry, when i tried to switch on the on/off button,it doesn't do anything at all!I tried changing the plug fuse(thinking maybe it needed to be changed after 4 years using it) but nothing happened.please help me . TQ
Mar 20, 2008 | Washing Machines
Washing Machines Logo
360 people viewed this question
Top Washing Machines Experts
