Question about NEC PlasmaSync 42MP3 42 in. Television
Is this just a monitor or is it a television as well?
    Top Expert:
  • NEC Master
  • 75,157 Answers
This is a monitor only. You have had a tuner unit to get on-air stations. Electro help
Posted on Apr 06, 2015
Got a 19" LG LCD
To convert a LCD Monitor into a TV
Instructions
    • 1
      Compare internal and external TV tuners that are designed for use with computers. See if the tuner supports HD, DVI, component video, S-video, stereo, surround sound or other features you might like to use. Ensure that any internal devices will work with the expansion slots in your computer.
    • 2
      Purchase a regular TV tuner if your monitor has S-video, coaxial or RCA inputs. These can be seen at the back of the monitor. S-video should be clearly marked; coaxial is a large round port, and RCA inputs are typically smaller and brightly colored. If your monitor does not have these inputs, purchase a special TV tuner designed just for computer monitors. If you would like to use the tuner with your computer and monitor, choose an internal TV tuner. If you're using your computer monitor as a television on its own, select a stand-alone external tuner. Install the internal TV in your computer, if applicable.
    • 3
      Connect the TV tuner to the monitor with the proper cable. Select S-video as the connection option if both your tuner and monitor support it. Choose RCA component video as your next option. Use coaxial only if your monitor and tuner do not have the aforementioned connections. If your monitor has none of these connections, use a standard VGA cable to connect the tuner and monitor.
    • 4
      Connect the tuner's audio outputs to your monitor's speakers. If your monitor has no speakers directly attached, connect external speakers to the TV tuner. This can usually be achieved using regular audio or RCA cable.
    • 5
      Install an HD antenna high on a wall if you will be picking up free over-the-air television signals with your monitor. If you will be using satellite or cable TV with your monitor, simply plug the satellite or cable set top box into the tuner using RCA or coaxial cables. Then connect the tuner directly to the monitor.
    • 6
      Set your tuner to the channel you use to pick up television stations. If you receive free over-the-air television, this channel will be 3 or 4. If you have satellite or cable TV, this station is determined by your television service provider. Check the documentation that came with your system to determine which channel to set the tuner on. You will probably need to change channels using the satellite or cable box rather than the TV tuner.
May 09, 2011 | Televison & Video
I have a E22/13B-GW-TCD-UK logik television that I want to use as a monitor for my computer. Do I need a driver?
Typically you will not need a driver to use any monitor. Ensure that the monitor output of your computer is compatible with the video input of the television.
Mar 05, 2011 | Televison & Video
Can I use the Panasonic PT-53X54J as a computer monitor?
U have a HDMI hub on this tv?Yes,than u can used it as a monitor.No HDMI hub,can't used as a computer monitor.
Sep 30, 2010 | Panasonic PT-53X54 53" Rear Projection...
Where is the cable port to put in the back of the tv
The 42DPC85 is erroneously refferred to as a television when it is in fact a monitor; ie. it has no built-in tuner. You will have to connect a VCR to the monitor and use the VCR's tuner for cable or antenna viewing. You may notice that the monitor does not have any 'channel' buttons.
The remote that comes with the monitor has 'channel' buttons but they are for external devices.
Sep 12, 2010 | Toshiba 42DPC85 42 in. EDTV-Ready Plasma...
Blue line on lcd monitor Is it a user problem or
If its a single blue pixel sized line, then its the monitor. It has a bad panel.
Apr 06, 2010 | Vizio Gallevia GV42LF 42 in. LCD...
Monitor not recognized
You have to go to graphic software on computer and manually select extended Monitor
Nov 23, 2009 | Syntax Olevia 327V 27 in. LCD Television
Is this monitor compatible with other computers besides gateway?
Most monitors are compatible with most monitors. A monitor for Mac may be incompatible with a monitor for Windows and vice versa.
Hope it helps
Sep 27, 2009 | Gateway FPD2185W 21 in. LCD Television
When used as a comp monitor it's blurry
i would check the resoulution settings in your computer
Nov 29, 2007 | Hisense LCD1504 15 in. Television
Top left side of the monitor asking for a key dats monitor locking so i need to open the lock plesae help me
Try holding the menu button down, this works for most monitors, just hold it down for at least 1 minute or so
Mar 16, 2007 | Thomson 20LCDB03B 20 in. Television
NEC PlasmaSync 42MP3 42 in. Television Logo
44 people viewed this question
Top NEC Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a NEC Televison and Video Expert? Answer questions, earn points and help others
