Question about Electrical Supplies
Wont do anything as soon as you turn on trips main breaker
  • T-Comtech Repairs
    T-Comtech Repairs Jul 24, 2015
    Hi sharon , I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
  • 3,287 Answers
Hi Sharon,
I'm an electrician and can tell you that if you have an appliance or device that is immediately tripping a breaker - there's a serious issue with it. Likely a "dead short circuit" that will be pretty easy to locate. In the case of household (120/240 volt) devices - if you continue to attempt to power it on, you may eventually burn the short circuit away and the device could potentially cause someone to be hurt, shocked or even killed.
You need to disconnect the device you're turning on from the outlet, etc. and have it properly serviced before attempting to use it again. Even on 12 v auto circuits - repeatedly causing shirt circuits can lead to melting insulation - and creating a bigger repair job than it could have been.
Posted on Jul 24, 2015
5 Suggested Answers
  • 225 Answers
SOURCE: Siemens Main Breaker 125 Amp gets warm and trips
sounds like a loose connection ,or possibly a weak main breaker.
Posted on Jul 15, 2009
  • 1949 Answers
SOURCE: Our main breaker trips in our trailer before any
if u have some larger brakers like double30s or some thing close to the main u need to move them down in the box other than that u need to repace the main or u just have it over loaded
Posted on Jan 09, 2011
ghostmaker
  • 6 Answers
SOURCE: Kitchenaid Dishwasher trips the 60-amp main breaker but not 20-amp.
Its possible that there may be load on that circuit from other appliances. Had an issue myself with stove and laptop on same circuit.
Check other appliance attached to the 60amp circuit (microwave, stove, kettle etc)
Posted on May 13, 2012
  • 5089 Answers
SOURCE: my main bryant 200amp breaker is tripping aft 10 15min.
Yes they get weak over time.
The main will trip when it senses heat.
Use hand to feel if main breaker is getting hot.
http://waterheatertimer.org/Troubleshoot-household-electricity.html#stress
http://waterheatertimer.org/How-to-replace-circuit-breaker.html
Posted on Oct 08, 2012
What's youI just wired in my J-300 Jacuzzi hot tub. The GFI trips every time I reset it. I took the GFI out of the equation and the tub runs fine, does not trip the breaker at the main breaker box
#1. DO NOT GET INTO TUB FULL OF WATER WITH A GROUND FAULT.
2. There is a short. You need to get multimeter and start checking each part for current running to ground wire.
3) Power is ON. Connect power without GFCI.
4) Tape tester leads to wood sticks to keep hands away from power.
5) Do not touch anything directly or you will become the ground rod.
6) Ground wire must be present, and bonded back to main panel box.
7) Do not sit or touch directly on cement or bare ground. Do not touch or lean into anything made of metal.
8) Body and parts must be on sheet of plywood, or similar non-conductive dry surface.
9) Test each part with spa, but also test electric line coming from main box.
10) GFCI will also trip with any fault detected on line. So the wire coming to spa may have the fault.
11) Add a new dedicated line from main box to spa.
http://waterheatertimer.org/How-to-wire-GFCI.html
http://waterheatertimer.org/See-inside-main-breaker-box.html
Oct 02, 2012 | Electrical Supplies
E442 Fridge Was noisy, now trips mains power :(
Sounds like the compressor is grounded out causing the breaker to trip, but it could also be wiring, but if I recall most things in those type of machines reduce down to 12vdc and that wouldn't blow the breaker.
Jun 03, 2012 | Fisher and Paykel Refrigerators
Brand new main breaker doesnt stay in on position
Turn the handle all the way to the OFF position, then turn it to ON. If it is tripping, then turn OFF all breakers, then turn ON the main. Turn ON each individual breaker until you find the one that is tripping the main. No offense, but you should consider calling a qualified electrician.
Nov 04, 2011 | Cutler Hammer 100 Amp Main Breaker...
I was doing a small load of laundry when the breaker tripped
Sounds like an electrical short somewhere in the washer. Needs to be checked out by qualified service tech.
Feb 04, 2010 | Washing Machines
Hotpoint washing machine keeps tripping electric
First unplug your washer. Check the ground on the washer and make sure it isn't loose; this would be a good time to inspect the wiring harness for any problems. Next check the outlet (turn off the electric to that breaker first) make sure all the wires are tight and are making good contact; pay special attention to the neutral (white) wire. If that seems fine, and you are comfortable with going into you breaker panel, turn off that breaker and check the hot (the wire on the breaker) to make sure it isn't loose and then check the neutral wire. If either of these wires seem loose tighten them down....a loose wire will move when a load is put on it and cause the breaker to trip. If all seems normal and washer is still tripping the breaker you might want to replace the breaker.....they can go bad. Good luck!
Aug 26, 2009 | Hotpoint Washing Machines
When turning on central air, our main electrical breaker is tripping. This is a brand new home barely over 1 year old. Should the AC have a warranty not covered by a builders contract??
Builders give a one year warranty but your air conditioner has five years on all parts. Anything outside the unit is not covered under the ac warranty. Breakers,stopped up drain and dirty coils.
Jun 09, 2009 | Weather King 10AJA6001AH Air Conditioner
Triping breaker as soon as it is plugged in. can anyone tell me what usually is the cause of this problem when as soon as i plug the power cable in to the outlet, it would trip the breaker? no power to the...
try pluging it in on another outlet with an extension cord must be a diffent cerciut breaker if it happens again the microwave has a short. if not its that breaker or outlet.
Mar 31, 2009 | KitchenAid KCMC155J Convection/Microwave...
Neff U1421 main oven trips the circuit breaker.
It might be that the breaker is overloaded and it's no longer supporting the load of all the appliances together.If you do not want to change your breaker you can still use your oven by switching off other appliances that is running while you are using the oven
Feb 04, 2009 | Neff U1421 Double circotherm Electric Oven
Turn washer dryer on ok, then close door then curcuit trips
check the wiring and make sure nothing metal is on the motor because your dryer has a short in it somewhere
Dec 23, 2008 | Hotpoint Ariston Aquarius WD420 Front Load...
Ricoh Aficio SP C410dn
Unplug other apliances connected to the same circuit.
Oct 03, 2008 | Ricoh Aficio SP C411DN Laser Printer
Electrical Supplies Logo
507 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
