Question about GE Refrigerators
HOW TO CHANGE refrigerator GE ARCTIC PS123SGNA water filter
  • GE Master
  • 473 Answers
Filter should be in the fresh food section top right back corner. It unscrews to the left about a 1/4 to 1/2 turn and pulls down. Reverse procedure to install. Not hard at all.
Posted on Apr 10, 2015
Ge profile arctica model #ps123sgna bs, leaking water from fresh food side?
Plugged or frozen drain pan located under the evaporator (cooling coil), located in the freezer.
Aug 31, 2014 | GE Profile PSW26P Stainless Steel Side by...
GE Profile Arctica PS123SGNA every fall the water dispenser stops working although the ice maker continues to work. Any ideas??
Strange, obviously the colder days dont effect the ice harvest so water is still coming in, has to be the water dispenser itself or the water filter may be freezing up stopping the flow.
Nov 24, 2013 | Refrigerators
I have a refrigerator that uses the GE SMART filter. When the filter needs to be changed, the water stops working. I changed the filter -- still no water, yet it makes ICE....any thoughts?
The water valve has two sides. One side is for the ice maker and one side is for the dispenser. If the dispenser side fails you have to change the complete dual water control valve. What is the model number of your GE Refrigerator? Sea Breeze
Jan 10, 2013 | GE Refrigerators
Filter light will not turn off
Resetting your Refrigerator filter indicator light after changing your water filter
Some people are not aware that after you change your refrigerator water filter, there are two more steps that should be taken to complete the water filter change process.
Step 1:
Reset your water filter indicator light - Most new refrigerators come equiped with an indicator light that notifies you when it is time to change your water filter. This light does not automatically reset when you change your water filter. Here is a list of refrigerator manufacturers and how to reset the indicator light.
GE General Electric Refrigerators - Press and Hold the Reset Button for around 8 Seconds.
Step 2:
Flush a couple of gallons of water through your new filter. Since most refrigerator water filters are made of carbon, some carbon residue is present in the first gallon or two of water. This will leave a bitter taste and residue in your water. If you continue to have these problems after flushing a couple of gallons through the filter, it is possible that you have a defective water filter.
Nov 11, 2012 | GE PFSS9PKy Refrirator
We have a GE profile ps123sgna bs side by side that is around 10 years old. Niether side is staying cold enough and frost is accumulating in the freezer. Does this model have a defrost timer? If so,...
The defrost timer is part of the control board. If the unit is not defrosting, you will need to replace the board. Here is the part to order.
The part comes with a 365 day, any part, any reason return policy.
Nov 10, 2012 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Where are the duel water inlet valves located on ge fridge arctic profile
unless you have a water dispenser, top mount refrigerators usually only have a single inlet water valve. Either way, the valves will be located in the back on the machine and covered by the lower portion cover, but will have a small area for the water line to hook up. Just remove the lower panel in the back and you will be able to see it
May 22, 2012 | GE Profile Arctica Stainless Steel Top...
Freezer n refrigerator is warm at 78 degrees
If the compressor is running it either has broken valves or the refrigerant has leaked out. Without knowing more than the information you've provided I would start with the basics. Does the fridge have power? Can you hear both the condenser and evaporator fans running? Have you checked the coils under the fridge to see if they are clean?
Jun 21, 2010 | GE Profile Arctica Stainless Steel Top...
How do I change the water filter on GE side by side TFX25CRWW?
Here is a link to a free downloadable owners' manual. Go to page 6 for complete instructions on how to change the water filter...
http://genet.geappliances.com/DocSearch/pdf/49-6953.PDF
Sep 16, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water Filter Freezes
The filter is building up ans excess of water. When this waters freezes it expands and breaks the filter. Do you have a way to extend tubin, and install filter on the outside of unit?
Jul 20, 2009 | GE Profile Arctica 25.4 Cubic Feet...
HOW CAN I CLEAN MY GE PROFILE ARCTIC REFRIGERATOR WATER LINE?
If the yuck is in the dispenser area pop off the bezel around the buttons very carefully and remove 4 small screws and clean with an old tooth brush. Install in reverse manner
May 07, 2008 | GE Profile¿ Arctica® Energy...
Refrigerators Logo
71 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
