Question about Dishwashers
Dishwasher has no power to control panel and fused spur arcing
Fused spur has 13 amp fuse which does not blow. Power is coming through but on/off switch does nothing, was intermittant but now permanent
  • 473 Answers
You state that the fused area was arcing. Any time you have arcing, in time that area will carbon up and stop working. Sound like a loose fuse holder or bad connection in that area. Shut off power, remove fuse and clean area completely. make sure fuse fits tight in holder. Check all connections where you noticed the arcing for black areas that are burned.
Posted on Apr 06, 2015
Samsung dishwasher no power/display off
The Samsung DMR57LFS Dishwasher has a 15 Amp/250VP Volt Fuse located on the lower right side of dishwasher behind an aluminum panel held by two screws. Pull dishwasher out from counter, remove lower rectangular aluminum panel, and it is just inside underneath. Unscrew fuse holder and replace fuse. I had to pay a Samsung Authorized Repairman $109.70 to replace a simple fuse. I learned the hard & expensive way. Samsung won't tell you to check the fuse underneath the unit. They won't even tell you that there is a fuse underneath on the right side. The fuse protects the Printed Circuit Board or Blue LED Control Panel in the event of a power surge or lightning strike.The less than $4.00 fuse will blow first.
Jan 27, 2013 | Samsung DMR57LFS Stainless Steel Builtin...
No power or light, plus power supply keeps blowing fuse
you have a short most likely on the power supply but could be on the mainboard, inverter board, av/input board. The T-con board is fused and should blow its fuse before blowing the fuse on the power supply. I'm going with a faulty power supply, most likely a shorted Mosfet.
Sep 24, 2011 | Philips Magnavox 42MF521D/37 Television
Hi I have a jacuzzi. I would like to connect it DIY
You can get 2 types of Jacuzzi baths, 1 with just a pump which just jets the water via a small pump or 1 with the pump and elements that heats the water aswell as pumps the water through the jets. Because the 1 with the elements has a higher amp rating you need to run a cable from your distribution board to your bath but the 1 without the elements you will be able to tap off the nearest socket to the bath, you will be coming from your socket to a fused spur outlet, it would be better to get a switched fused spur outlet as you will be able to isolate the bath when not in use just by switching off the switch. from the spur outlet you will be wiring it into your motor on the bath, it should say the rating of the pump in amps on the tally plate of the motor or on the manual. For example if it says the motor draws 2 amps you will be putting a 3 amp fuse into your spur outlet so if there is a fault with the motor the fuse will blow instead of tripping the whole socket circuit. All jucuzzi baths has to be connected to the RCD side of your distribution board. If you are tapping off a socket don't worry about the RCD because all sockets should be on the RCD anyway, to check that the socket is connected to the RCD plug something into the socket you are tapping off of and press the test button on the RCD, the RCD should trip and while this is tripped check the lamp or whatever you plugged in shoud be off. The Fused spur should be fitted outside of the bathroom.
Mar 29, 2011 | Whirlpool Home
Does the Whirlpool Gold dishwasher have a fuse?
The fuse is in the control panel on the right hand side after you open the panels 6 screws.
The replacement fuse kit comes with a wire harness that must be used to prevent the new fuse from blowing.
Jan 24, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
CAN I CONNECT A CREDA 2000W PLINTH HEATER USEING A FUSED PLUG?CREDA 2000W PLINTH FAN HEATER
Yes ,you can and fuse at 13amp.
Although the correct way would be to terminate the plinth heater in a switched fused spur or an unswitched fused spur fused at 13 amp
This can either replace a single or double socket or it can be taken of the socket by using 2.5mm2 twin and earth cable.
All parts availiable from hardware store or electrical retailer
Oct 06, 2009 | Creda C362E Electric Kitchen Range
Electrical fan connection
Firstly, yes the fused spur should be earthed. You should wire from the fused spur to the fan L,N & E.
Your light switch should be in line on your light live supply wire.
If you wish to use the light switch to turn on the light and fan at the same time you should also run a live switch wire to the fan L1.
This should FixYa.
Please remember to rate this solution.
Dec 09, 2008 | Dryers
Fuse location
Follow power wires (power unplugged), from timer toward power cord entry. If they go to a fused board then there is the fuse, if the unit is not fused, either the timer has blown, or often you find a fused board near the motor and pump assembly, inside the bottom part of the appliance.
Aug 26, 2008 | Maytag PAV2300 Top Load Washer
Whirlpool Dishwasher Not Working
Change the thermal fuse in the control and door switches. The thermal fuse is designed to fail if there is a problem with the switches.
May 17, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Rangemaster cooker hood. model no.LEIHDC120SC/
hood should be connected to a fused spur outlet which you havent found. try removing the chimney and you may find it there. chimney only held by 2 screws at top usually.the fuse in the outlet sometimes goes when bulbs blow
May 31, 2007 | Rangemaster Broan 614804 BALLISTA 48IN...
Dishwashers Logo
114 people viewed this question
Top Dishwashers Experts
