Question about Garmin StreetPilot C330 GPS Receiver
Northstar 941X When I turn on my 941X Northstar GPS I get a line across the screen for a couple seconds and the unit shuts off. Help
Re: Northstar 941X - Garmin StreetPilot C330 GPS Receiver GPS Devices
Need to change the LCD
Posted on Mar 06, 2008
0 characters
3 Points
Binatone sat nav - when I turn it on the screen flickers and all i get is lines going across the screen.
hi please try reseting the system and calibrate it a couple of times this should work for you goodluck
Mar 18, 2011 | Toymax Binatone Carrera X350 Car GPS...
The screen displays a vertical group of black and grey lines. Won't shut down?
it seems like its in calibration mode
Turn unit off
Slide Power Key to the right ( lock )
Hold your finger on the screen for approx 30 seconds until calibration screen appears
Follow on screen instruction''
Here is a online Manual for your unit that I found ....
Oct 28, 2010 | Garmin Nuvi 285WT GPS Receiver
Burnt out LCD B&W screen on Northstar 951X GPS.
Electro Mavin ( sell replacement new unused Optrex DMF-50174 Displays units for $25.00. Order one.
Take small screws out of the back of the Northstar 951x and carefully remove the cover, disconnect the old display unit (just one ribbon, one power connector and two screws).
Replace the display with the new one.
Replace cover and screws.
Now take your loved ones on a small holiday with the money you just saved yourself!
Sep 19, 2009 | Northstar 951XD GPS Receiver
Screen goes blank after locating sattilites.
Accordingto Garmin, this problem can be fixed by disabling the WAAS feature in teh set up menu. There is an incompatibility between the old Garmin software and latest WAAS upgrades. Later software from Garmin is supposed to fix this problem.
May 21, 2009 | Garmin eTrex Legend GPS Receiver
Lines across screen
the unit is faulty i would return it and get the money back
Feb 01, 2009 | Tomtom GO 910 GPS Receiver
GPS V at startup it goes to second screen and shuts down leaving a line across the bottom of the screen.
I contacted Garmin and they actually researched the problem and got back to me with a solution a few hours later. I have already instituted it and it works. Here's what they suggested:
Thank you for contacting Garmin International. I will be more than happy to help you with this. The situation you described appears to come from a change in the WAAS system by the government. To correct this issue you must turn the WAAS off. To do this turn the unit on and press the menu button twice. Next highlight setup and press enter. Under the system tab, WAAS is located in lower right hand corner. Scroll down and over to highlight enabled, press enter and change to disabled. Engineering has been informed however due to the discontinued status of this unit we are not sure when ( or if ) a new unit software will be issued to correct this problem. I appologize for any inconvienience.
Hope this helps!
Oct 02, 2008 | Garmin GPS Devices
Garmin GPS 152
I had the same problem so I replaced my 152 with a spare unit. It did the same thing. This led to believe it was the cable. I removed a few kinks and a bend at the unit; and it seems to be fine. Seems too simple and the bends were not that severe, but it is working (for now).
Aug 24, 2008 | Garmin GPS 152 GPS Receiver
Waypoints and nav log
Based on your description I would suspect that the internal memory battery is depleted and needs to be replaced. This battery is required to retain waypoint and route information when the input power is low or turned off. The battery is soldered onto the main circuit board and needs to be replaced by a technician having good soldering skills and access to instructions for the disassembly and reassembly of the unit. There is a list of dealers on the Northstar website. Review the list and make a couple of phone calls to see which ones will do bench work on this unit.
Mar 23, 2008 | Northstar 951XW GPS Receiver
Magellan 2200T won't completely boot up
Reset unit, and then turn off, but hold power button for at least 10 seconds, then power back on, and when ever you turn off unit, hold power button for 10 seconds, had the same problem with mine, this solved it, it seems that just turning off the unit till screen shuts down puts it in a sleep mode. Hope this solves your problem.
Dec 18, 2007 | Magellan RoadMate 2200T GPS Receiver
How to reset
There is a small reset hole on the back of the unit at the top. Press a paperclip into this hole for a couple of seconds and the unit should reset.
Nov 14, 2007 | Tomtom GO 910 GPS Receiver
Garmin StreetPilot C330 GPS Receiver Logo
161 people viewed this question
Top Garmin GPS Devices Experts
Tom Chichester
Jonathon summesfield
Bill Gilhooly
Bill Gilhooly
Are you a Garmin GPS Device Expert? Answer questions, earn points and help others
