Question about Tablets & eReaders
How do I get the back off.
I need to remove the back to try and replace the broken power socket. All repair shops (in the UK) say it will cost nearly as much as a new tablet, but I have found some replacement sockets on ebay for only a few quid. Is this a simple enough process?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 188 Answers
Google it. There are u-tube videos dedicated to this type of thing/ better than any answer you'll get here. Don't forget MODEL & SERIAL number if possible!
Posted on Apr 06, 2015
Testimonial: "Thanks. Have already tried and can find the answer for just about all other models of the Archos 101 but not for the Neon which appears to be different."
  • Trevor Turner Apr 06, 2015
    Not that you won't get a good answer here; just that a video step by step would be much better! :)
    Then do what I do: start poking around until things start coming apart! Everything comes apart with a little patience and prying! (And praying) good luck.
No power when plugged in? What did I do?
If you have a volt-ohm meter check that you have voltage at the plug to the computer. If no voltage, the power supply is bad or the socket does not have power (circuit breaker) change to a known working 120vac socket. Dobble check your laptop's power supply. If still bad, see if you can barrow one, or take laptop to repair shop and ask them to try their power supply. Then you will know to purchase a replacement.
Mar 31, 2015 | ASUS R1E-B1 Tablet PC
My almost new under warrenty galaxy android 10.5 tablet: usb cable end will not fit into the port anyhmore..it used to..is the port hole broken?
Do you have an Android phone?
If so compare the charging ports.
There should be a small plastic bar in the port with connectors on it.
If this bar is missing or damaged, then it would need replacing.
Most phone repair shops can repair this but from past experience it will probably cost between £100 and £200 to repair.
It is NOT covered by warranty unless you have a very helpful staff member from where you bought it.
Samsung usually class this as user damage and will not repair for free.
See picture for the plastic section which may be damaged.
Feb 06, 2015 | Tablets & eReaders
When a tablet has a mark like this ! on a battery what does it mean?
Simply, it means that either the battery has failed and must be replaced - OR the charger is not working properly and is not charging it. Simple test is, does the tablet run OK when plugged into the charger, but not when running on the battery? If so, it's the battery. If it won't run even on the charger, then it's most probable that the charger is broken and will need to be replaced - or the DC input socket on the Tablet has broken internally or come loose from the circuit board, which is a repair shop fix I'm afraid.
Jan 02, 2015 | Tablets & eReaders
My screen is broken. How do I fix it?
In all warranties, broken screens are excluded. Unless you can prove it is induced by an error made during manufacturing.
Repair of a broken screen is dune by replacing the complete screen and sometimes not only the touch screen must be replaced, the display has to be replaced to.
The best way to go is, visit a phone repair shop, and ask them if it can be done and what it will cost. If it is complicated and it would take more than an hour, the repair could cost more then buying a complete new tablet.
Dec 29, 2014 | Polaroid 7-in. Internet Tablet - Other
Old charger was broken and just got the new one. Was taking the charge in the store when we tried it out and then when I got home it is stuck on the battery screen and is no longer charging. I tried t
thy a second power socket in your hope, try reset the phone disconnect switch off and back on or remove battery and replace before connecting it back onto the charger. then let it charge up for a couple of hours before switching it on again.
Dec 18, 2014 | Samsung Galaxy Tab 2 Wi-Fi
Kindle won't hold the plug to charge anymore. I have tried differenct chargers, they don't work.
Once the internal connector of the tablet is broken (which is what you are describing), there is no hope but to find someone willing to replace or repair the connection. The device was not designed to be repaired and nobody has been specificly trained to do that repair except the fellow in China who works on the production line doing that exact task on production "fallouts". There may be an "old school" electronics technician somewhere who could do the job but very tough to find one. It will be cheaper and easier to buy a new tablet.
Sep 19, 2014 | Amazon Kindle Fire HD
How do I fix the power button on a Nabi Jr
no it isn\'t that hard a little finickally unless you\'ve broken the button inside in that case it will be a mongrel and near impos to do it sorry
Jul 01, 2014 | FUHU nabi Jr. 5" Capacitive Touch Android...
My dragon touch model: Y88 tablet was working fine for a while. i was watching a movie on it then i pressed the sleep button n since then it wont turn back on. when i plug the charger in it i get a warm...
I'm sorry the charging circuit seems to have broken down. You need a new logic board. You should always try to replace a broken part yourself first. search model name plus "repair guide" on any search engine. There are other websites that sell all the replacement parts, one of the bigger ones is http://portatronics.com (646) 797 2838. Then for the repair itself you can venture to do it yourself, or better ask a friend who has done a similar repair before.
Jan 06, 2014 | Android Tablets & eReaders
The charger is broken and i need another charger also the pieces of the charger is stuck where you are suppose to put the charger
You can charge your tablet through the USB port on your desktop computer. Just plug it in with the USB cable that came with your unit. It's slower charging but who cares?
Those pins are delicate. Be careful when inserting and removing.
The USB is designed to power on first and then the data is transferred.
Forget about taking it to a repair shop. The charges will be more than the tablet is worth and it's not likely they will have the part.
Dec 30, 2013 | Proscan 10.1-Inch Internet Tablet,...
I have a problem with one of the the charging plug ins
The socket will need replacing. A computer repair shop will do it. Is there a standard round pin charger socket?? If so you'll need to purchase a charger for it
May 30, 2013 | ZEEPAD Tablets & eReaders
Tablets & eReaders Logo
37 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
