Question about Freezers
Hot point chest freezer , inertial fan is running constantly and only the top half of freezer is frozen
    Top Expert:
  • 6,702 Answers
I hope the cooling fluid is not leaking out of the system. When the inside is becoming warmer every day, you can be sure it is. Then check what is bas, replacing the cooling aggregate (it is through the whole freezer) or buying a new one. For household freezers it is better and cheaper to buy a new one, because new freezers use less power. When it is now running 24 hours a day, quick replace it.
Posted on Apr 06, 2015
4 Suggested Answers
fridgetech
  • 473 Answers
SOURCE: Freezer is freezing but the outer wall are extremly hot
This is a normal condition.  The condensor coils are in the cabinet and their job is to remove heat which is why it is hot.  You will want to make sure the freezer isn't in a tight spot where air from the room can't flow across it.  Without good air flow it will become too hot and not cool properly and lead to the compressor failing too soon.
Posted on Oct 13, 2007
bobotfel
  • 236 Answers
SOURCE: kenmore chest freezer power problem
Try to unplug the the unit power supply to reset the error. But if the error persist you have to call for a qualified technician,
Posted on Dec 28, 2007
  • 1314 Answers
SOURCE: Freezer is running constantly and sides and top are hot.
first whirlpool makes a good product as far as the sides being hot good sign the condensing coils are in the sides are supposed to be hot worry if its running and they are cold then not working right ok as far as running modern units useing 134a do have long run times but are not using but same enegry as 100watt light bulb otay
Posted on Dec 30, 2007
Why are the sides of my frostfree freezer so hot?
check to see if you have a fan down by the compressor if so make sure it is running. if no fan you are starting to loose freon
Jul 25, 2014 | Frigidaire 13.7 cu. ft. / 388 liter...
Only top section of chest freezer is freezing
Hi
Normally what causes the refrigerator/lower chest not to be cold enough is that the fan that pulls the air from the freezer is not working.
Check to make sure it is working, if not then you will have to replace it.
If it is working then check you defrost timer, it could be faulty.
I will include these two websites for parts.
partselect.com/
appliancepartspros.com/index.aspx
Please take time to rate me
Bud
Mar 15, 2013 | Freezers
My kenmore 19.7 cu.ft. chest freezer is not running and the compressor is hot
Place a volt meter set for amp draw around one wire of the compressor. If you do not have a constant amp draw replace the start relay on the compressor.
If you do have a constant amp draw the compressor is bad or you have a refrigerant leak.
Apr 25, 2010 | Kenmore 19.7 cu. ft. / 558 liter Chest...
The freezer is hot on the outside
Make sure the evaporator coils on the back or underneath near the compressor are clean. If there is a fan near the coils make sure it's running.
Dec 09, 2009 | Whirlpool 14.8 cu. ft. Chest Freezer...
Freezer not keeping foods frozen
If this freezer is running all of the time and only freezing the walls at the top inside it is a good chance there is deteriation in the piping in the walls eg (rusty pipes) letting the refridgerant escape (common fault) with chest freezers.If it is more than 7 years old it would be advisable to replace it as the repair would probably cost 3 quarters of replacement price.Hope this helps. Kind Regards.
Nov 27, 2009 | Woods 4.3 cu. ft. / 122 liter Chest...
The top half of the freezer does not work
I have a Scandinova chest freezer and the left hand side froze, but not the right side, because the compressor in the box under the right side of the freezer was getting so hot, a small amount of heat was conducting back through into the right side of the freezer and preventing anything on that side from freezing!
I solved this problem by running the compressor outside of the of the freezer box, by taking the air vent off, unbolting the compressor and then pulling out by about 20cm and running it from there.
Aug 22, 2009 | Freezers
Chest freezer not freezing on bottom
Sounds like a circulation problem. Does it have a fan inside the freezer. Should be bdhind the floor or one of the wall panels. There should be a vent for the air to circulat through. If so check to make sure it's running when the compressor runs.
Aug 19, 2009 | Whirlpool 10 cu. ft. Chest Freezer...
Not cold enough?
is this a chest freezer or upright frost free fridge freezer . nead more info
Oct 19, 2008 | Freezers
Oct 13, 2007 | Kenmore 12.8 cu. ft. / 362 liter Chest...
Freezers Logo
93 people viewed this question
Top Freezers Experts
Dennis Boxerman
AJMAL KHAN
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
