Question about Alpine Car Audio & Video
How can i reset my pin code for the bluetooth on my alpine cde-w235bt
simplemitch
  • 752 Answers
SOURCE: Alpine CDE-9843
Page 16 of the manual:
http://vault.alpine-usa.com/products/documents/CDE-9841,%2043,%2045%20OM.PDF
Setting Time
1 In the Clock priority mode, press and hold
TITLE for at least 2 seconds while the time is
displayed.
The time indication will blink.
2 Turn the Rotary encoder (CDE-9845/CDE-9843
only) or press
4 and 3 (CDE-9841 only) to adjust
the hours while the time indication is blinking.
3 When the hour has been adjusted, press the
Rotary encoder (CDE-9845/CDE-9843 only) or
press MODE (CDE-9841 only).
4 Turn the Rotary encoder (CDE-9845/CDE-9843
only) or press
the minutes while the time indication is blinking.
The time is automatically set 5 seconds after the minute
adjustment. The time can also be manually set by
pressing the Rotary encoder (CDE-9845/CDE-9843 only)
or press MODE (CDE-9841 only).
• To synchronize the clock to another clock/watch or radio time
announcement, press and hold the Rotary encoder (CDE-9845/
CDE-9843 only) or press and hold MODE (CDE-9841 only) for at
least 2 seconds after setting the “hour.” Minutes will reset to 00. If
the display shows over “30” minutes when you do this, the time
will advance one hour.
Posted on Aug 05, 2008
SOURCE: Connecting High Speed IPOD Cable to Alpin CDE-9874
Best Buy solved my problem.
Posted on Oct 02, 2008
JustJeeps
  • 74 Answers
SOURCE: Alpine CDE 7853 removal
remove the face and then the trim ring for face you should see 2 little pins on either side of the radio slide them up and it should slide right out
Posted on Nov 28, 2008
etirbynnor
  • 655 Answers
SOURCE: Alpine CDE-102 w/usb port: will not
Hello desoren,
The receiver may not be set to recognize MP3 files.
Press and hold "sound setup" until the unit enters setup mode. Rotate the volume knob to "play mode" and press "enter". Check that the setting is CD/MP3 (not CD/MA), or rotate the volume knob to change the setting to CD/MP3 and press enter again. Press and hold "sound setup" again until the unit exits sound setup.
If the files are still not recognized, I'd try using a different USB drive, a different computer to write the MP3's, and/or a different application to download or rip the original music content.
Hope this helps.
Posted on Sep 23, 2009
etirbynnor
  • 655 Answers
SOURCE: i am getting a DC error on my alpine cde-102 head
Hello christo12385,
The DC error is most likely caused by a shorted or grounded speaker wire. Check all speaker wires, correct the problem, and then go into the sound setup settings and reset the POWER IC to ON.
Hope this helps.
Posted on Sep 25, 2009
I have an Alpine CDE-SXM145BT car stereo. that will not play Bluetooth devices.
Have you had the battery removed at any time before this happened or been jump started ?
Apr 09, 2017 | Alpine Car Audio & Video
Why I have no sound on Alpine CDE-111R. After six years appeared an option which it never appeared before, "BT AUDIO".After that is no sound anymore
Seems that you activated Bluetooth audio for playing music from a Bluetooth device. If you google alpine cde111 manual you will get a link to the owners manual which gives step by step instructions on how to disable Bluetooth audio
Aug 12, 2016 | Alpine Car Audio & Video
How to set up to run
If you don't have the owner's manual, get to the Alpine website to ask for assistant. Often you can download instructions or manuals free.
https://supportalpineusa.custhelp.com/app/home
Jun 07, 2015 | Alpine CDE W235BT Radio / CD / MP3 player...
How do i get code for bluetooth
First make sure that Bluetooth is on on the CDE-143BT. Press and hold Audio/Setup (below and to the right side of the rotary encoder dial until you enter the Setup mode. Use the rotary dial to get to Bluetooth. Press the Search/Enter button (the center of the rotary dial). Then use the rotary encoder to go through the Bluetooth Settings menu. Press Search/Enter to toggle the current value. After Bluetooth is on, go to Visi M setting and make sure that it is on. Now, you need to go to the Bluetooth settings area of your cell phone when it is within range of the receiver. Tell it to pair with the receiver. Then when it asks for the code enter "0000". This code is hard encoded into the unit. See page 23 of the manual for the CDE-143BT for the code. The manual is available here: http://vault.alpine-usa.com/products/documents/OM_UTE-42BT_CDE-SXM145BT_CDE-143BT_EN.pdf . Surrounding pages show setting the other Bluetooth settings.
Note: the receiver will be acting like a Bluetooth headset. That's why you need to enter the receiver's PIN on the phone.
I hope this helps.
Oct 10, 2014 | Alpine CDE-143BT Advanced Bluetooth CD...
My car stereo speakers shut down every 2-3 minutes forapproximately 3-10 seconds
The "installer" should suspect that you are driving the Bose amplifier too hard and it is going into thermal shutdown periodically.
Mar 06, 2014 | Alpine CDE W235BT Radio / CD / MP3 player...
My Alpine CDE-W235BT bluetooth has stopped working after a failed update. How do I fix it?
Sounds to me like the firmware is damaged, try flashing it with another firmware, or maybe updating it with the same update but successfully if possible.
Aug 01, 2013 | Car Audio & Video
Alpine cde-126bt bluetooth connection issues, only connects with 1 phone, second device fails at connecting when using pin.(0000). software ver is 3.80
Hi, same problem (v3.80), but finally conected. I would say that is related with bluetooth name length of the phone.
Try setting the phon's name to something smaller.
Jordi.
Conected with an android device, Motorola MB200 (DEXT)
Jun 23, 2011 | Alpine CDE126BT Car CDMP3 Player
Nov 20, 2008 | Alpine CDE-7853
Alpine CDE-9841
Have one solution which might work.
Remove head display unit and press reset dutton usins a pin.
now connect head display unit. now insert CD. make sure the CD is in good shape.
Cheers
Alex Victor
Jul 26, 2008 | Alpine CDE-9841 CD Player
Alpine CDE-9843
Setting Time
displayed.
only) or press
only) or press
Apr 26, 2008 | Alpine CDE-9843 CD Player
Car Audio & Video Logo
47 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
