Question about Health & Beauty
The battery's are fully charged,but when I drive off it seems ok until I put under load when it stops and I get a continuous beeping.have to switch of then restart
    Champion:
  • 208 Answers
Sounds like a bad connection. Check wiring for loose fitting or ground fault.
Posted on Apr 06, 2015
Ryobi Li-ion strimmer
check that you are using the correct line in the head
if it is too thick , the load will be causing the thermo switch for the motor to stop operation until it cools down
Jun 16, 2017 | Ryobi Drills
My gogo ultra is showing fully charged and horn beeps, when i put key in it beeps fast 10 times and 5 beeps after
5 beeps usually means scooter is out of gear, but since the lever is in the drive position and the scooter gearbox/differential is engaged, it seems that the controller is not sensing the gear change. Possibly a faulty micro switch in the motor housing can be the cause of this, usually the micro switch is pressed down by the drive lever and if the switch is pressed down the motor controller knows the scooter is in gear.
Feb 11, 2015 | Pride Mobility Products GoGo Ultra X...
I am charging my scooter and it is beeping what do i do
Charge without the key on. Make sure your charger is applying power to the scooter. It may have a blown fuse or some other internal problem. If your batteries were totally discharged your charger will not recharge them. You'll have to charge them individually with an automotive style battery charger that is NOT an automatic charger. It may take 3 days continuous charging to recover enough charge before your scooter charger will continue to charge until the batteries are fully charged. If this doesn't work then the batteries will never take a charge nad need to be replaced.
Oct 15, 2014 | Health & Beauty
Compaq presario C700 continous beep when starting up
Potential Hard Drive failure, (Hard drive s.m.a.r.t. beep) or if MB beep it's chassis intrusion..
1. Remove battery + disconnect power
2. Hold down power button for 20 seconds
3. connect power only (no battery)
4. Turn computer on.
If the beeps stopped.. get a new battery, if the beeps continue..
ABANDON SHIP!
Apr 27, 2014 | Compaq Presario 1200,1600, Series CD...
Is transformer of my UPS OK?
The rectifier (Full or 1/2 wave) is not producing normally: as applied under a normal load. My take!
Mar 14, 2014 | Computers & Internet
Car won't start after switching baterries
re move alt. have it re tested i had a signaler problem. tested fine at idle under load alt surged blow batt. also volt regulator may be constantly draining battery voltage regulator is inside alternator
Nov 23, 2012 | Oldsmobile Cutlass Ciera Cars & Trucks
Z612 no power on. Battery klic8000 is ok fully charged. No led flashing. No sand, no water, no drop, any issue. Was working well until yesterday.
As per your description it seems your camera have internal fault (circuit problem) which only get resolved in Kodak Service Center but before that you can check following things:-
  • Clean your battery terminal with soft cloth. (Might be it will filled with dirt or dust )
  • Direction of your battery might be wrong, Check out and put it again.
  • Load new or fully charged battery.
  • Check whether Memory Card/Battery Cover is properly closed.
Thanks....!!
Rating the solution is highly appreciated.
Sep 12, 2010 | Kodak EasyShare Z612 Digital Camera
Tecra M2 doesn't boot is it a processor problem?
given the symptoms, it points to motherboard.. if it was processor, video or ram. it wouldnt boot at all and you'd just get error beeps from your laptop. i'd first try resetting the bios, by removing the bios battery for 30 min, then putting it back in. if that doesnt work try changing it out, usually costs under 8 bucks. if that doesnt work then I would change out the motherboard, if its cost effective.
Mar 03, 2009 | Toshiba Tecra M2-S730 Notebook
Canon 400d will not switch on
it might be a problem with the battery connectors.
They might not touch the battery well.
another reason, it might be the battery is dead or the power button is not working.
Aug 20, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Signal indicator flashes constantly
The following worked when I had what appears to be the same problem. Solution :- Remove batteries, remove power connection, wait 30 minutes, re-connect power and replace batteries then press button on base until it beeps. Both handsets started continuous beeping which eventually stopped and everything was returned to normal. Admittdly this sounds almost identical to the process used by 'versailles' above, but at least it confirms that the technical info given by the BT Helpline does work
Nov 28, 2006 | British Telecom Freestyle 2200 Trio...
Health & Beauty Logo
159 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
